Property of Determinants Answers Check
In summary: Since n is odd, (-1)n = -1, so det(AT) = det(-A) = (-1)ndet(A) = ?What can you conclude from the above?Also, it's better to post one problem per thread.7A2+8A+3I=[0] 7A2+8A = -3IA(7A+8)=-3I
muzziMsyed21
Let A and P be square matrices of the same size with P invertible, Prove detA=det(P-1AP)
Suppose that A and B are square matrices of the same size. Then det(AB)=det(A)det(B)
detA=det(P-1AP)
detA=det(P-1PA)
detA=det(IA)
detA=1*detA
detA=detA
SECOND QUESTION:
Let A be an nxn matrix. Prove that if matrix A satisfies 7A2+8A+3I=[0]
Invertible Matrix Theorem
7A2+8A+3I=[0]
7A2+8A = -3I
A(7A+8)=-3I
From this point I don't know if I am headed towards the correct answer or have the right idea THIRD QUESTION:
Suppose A is an nxn matrix satisfying AT+A=[0], where n is odd. Prove detA=0.
detAT=detA
AT+A=[0]
AT=-A
detAT=det(-A)
since detAT=detA
detA=det(-A)
I think I've got the right idea...
detA=det(P-1AP)
detA=det(P-1PA)
You can't do this (above). Matrix multiplication is not generally commutative, so in general, AP ≠ PA
muzziMsyed21 said:
detA=det(IA)
detA=1*detA
detA=detA
SECOND QUESTION:
Let A be an nxn matrix. Prove that if matrix A satisfies 7A2+8A+3A=[0]
Typo in your equation?
7A2+8A+3A=[0]
Typo?
muzziMsyed21 said:
7A2+8A = -3I
A(7A+8)=-3I
detAT=detA
AT+A=[0]
AT=-A
detAT=det(-A)
since detAT=detA
detA=det(-A)
How does this show that det(A) = 0?
Also, what role does the fact that n is odd play?
sorry for the typos I edited and fixed them
Typo?
that is where i am stumped... is it det(A) = -det(A) then detA=0 ?
IF det(A)=(-det(A)) then det(A)=0, sure. det(-A) isn't always equal to -det(A). What is det(kA) for k a constant?
kndet(A)
muzziMsyed21 said:
kndet(A)
Well, sure. Now put k=(-1) and figure out what n being odd might have to do with it.
det(AT)=det(-A)
det(A)=(-1)ndetA
from here i still don't know how det=0
muzziMsyed21 said:
det(AT)=det(-A)
det(A)=(-1)ndetA
It only has to be zero if n is odd. Then (-1)^n=(-1), right? det is a real number. If a real number x=(-x) then x=0. Can you prove that?
does it have anything to do with additive inverse?
Don't overthink this.
MuzziMsyed21 said:
7A2+8A+3I=[0]
7A2+8A = -3I
A(7A+8)=-3I
The last line should be A(7A + 8I) = -3I
It doesn't make sense to add a number to a matrix.
Rearranging a bit results in this equation.
So A * (-1/3)(7A + 8I) = I
Does this give you any ideas?
Related to Property of Determinants Answers Check
1. What is the "property of determinants"?
The "property of determinants" refers to the mathematical rules and properties that govern the behavior of determinants, which are mathematical objects used to represent certain operations on matrices. These properties include the ability to calculate the determinant of a matrix by multiplying its elements and using certain operations to manipulate the determinant.
2. Why is it important to check the answers for determinants?
Checking the answers for determinants is important because it helps to ensure that the calculations were done correctly and that there are no errors in the results. This is especially important in more complex calculations, where a small error in one step can lead to a significantly different answer.
3. How do you check the answers for determinants?
To check the answers for determinants, you can use various methods such as comparing the results to known values, using algebraic properties to manipulate the determinant, or using technology such as calculators or computer software. It is also helpful to double check the calculations and make sure all steps were done correctly.
4. What are some common mistakes when checking determinants?
Some common mistakes when checking determinants include forgetting to include negative signs, incorrect multiplication or addition, and not following the correct order of operations. It is also important to pay attention to the dimensions of the matrices being used and make sure they are compatible for the desired operation.
5. Can you explain the difference between checking and solving determinants?
Checking determinants involves verifying the accuracy of the answer after the calculations have been done. This is usually a quicker process and does not require as much mathematical knowledge. Solving determinants, on the other hand, involves using various methods and techniques to actually find the value of the determinant. This requires a deeper understanding of the mathematical properties and operations involved.
10K
