Pelion
- 35
Hi to all who might respond,
Consider the 'peculiar' double-slit setup below.
There is a double-slit configuration such that the two slits are never open at the same time. That is: whenever the top slit is open for a certain interval, Ts, the bottom slit is closed for the same interval and vice versa; the configuration toggles continuously between these two states. Let's assume that we have a pulsed sub-single-photon source whose broad-band pulse coherence time, Tp, is much less than Ts. The source targets the double-slit in the following manner: it splits each pulse (which contains at most one photon) into two time bins, synchronized with the opening/closing of the slits, separated by an interval Ts, such that the first time-bin pulse passes at the half-time of when the top slit is open while the second time-bin pulse passes at the half-time of when the bottom slit is open. Thus, a photon never experiences both slits open. Suppose that, just before the detection screen, we place a narrow-band spectral filter such that the coherence time of photons that pass the filter, Tf, is much larger than the slit toggling interval Ts...Will we see an interference pattern, since now it is impossible, even in principle, to determine through which slit a photon passed? Does this gedanken experiment have any implications (positive or negative) pertaining to the 'Standard' or the 'Bohmian' interpretations of QM?
Demetrios
Demetrios
