Propositions for recursive functions
  • MHB
  • Thread starter evinda
  • Tags
    Functions
In summary: I don't remember seeing anything other than a function after the phrase "a Turing machine computes". And I don't really care about what you write with words. You can give whatever definitions you see fit. The important thing is that you can formulate precise statements and write them using...words.
evinda
MHB
3,836
Hello! (Wave)
I want to show the following two propositions:
  • The domain of a recursive function is recursively enumerable.
  • The range of a recursive function is recursively enumerable.
I have thought the following in order to prove the first proposition.
Suppose that we have a recursive function $f$. Then we know that there is an algorithm $A$ that computes $f$.
So if $m \in dom(f)$ then we know that the algorithm $A$ with input $m$ terminates, giving output "yes".
Since $m$ is arbitrary, we deduce that the domain of a recursive function is recursively enumerable.
Is my idea right? If so, can't we also deduce from that that the domain of a recursive function is recursive since the algorithm always terminates for the elements of the domain? (Thinking)
By "recursive function" do you mean partial recursive function?
Since $A$ computes $f$, it outputs whatever $f$ outputs and not necessarily "yes".
I don't see how it follows, but it may depend on the definition you are using. Please remind the definition of a recursively enumerable set. Also please write the facts (similar to the statements from this problem) that you may use.
I mean a total recursive function.
Yes, now I think so too that I am wrong.A subset $A$ of $\mathbb{N}^k$ is recursively enumerable iff there is a Turing machine $T$, such that $\forall x \in A$, $T$ with input $x$ halts , giving output $1$ and $\forall x \notin A$, $T$ does not halt, i.e. $T$ computes the function
$\phi(x)=\left\{\begin{matrix}
1 & \text{ if } x \in A \\
\infty & \text{ if } x \notin A
\end{matrix}\right.$
A subset $A$ of $\mathbb{N}^k$ is recursive iff $A$ and $A^c$ are recursively enumerable.
So you are not sure how to show that $\mathbb{N}^k$ is r.e.? Since the domain of a total function is $\mathbb{N}^k$.
Oh yes, that's true. Maybe we have to show the statement for both total and partial recursive functions. (Thinking)
Having $\mathbb{N}^k$ as the domain , we can write a program that checks if a vector contains only natural numbers and so $\mathbb{N}^k$ is recursively enumerable. Right?
The domain of a partial recursive function is indeed r.e.
Yes.
Suppose that we have a partial recursive function $f$. Then there is a Turing machine $A$ that computes $f$.
We construct a Turing machine $M$ such that if $A(m)$ terminates for some $m \in \mathbb{N}$ then $M$ terminates giving output $1$ and otherwise $M$ does not terminate. Then $M$ computes the domain of $f$ and thus the domain of $f$ is recursively enumerable.
Is my idea right?
I would not say "$M$ computes the domain of $f$". Usually one says "computes a function". Otherwise I agree.
Then $M$ computes the characteristic function of the domain of $f$ and thus the latter is recursively enumerable. Right?
No, a characteristic function is total.
A Turing machine can also compute a statement, right? So can we say that then $M$ computes the statement "is the element an element of the domain of $f$", deducing in this way that the domain of $f$ is recursively enumerable?
I don't remember seeing anything other than a function after the phrase "a Turing machine computes". And I don't really care about what you write with words. You can give whatever definitions you see fit. The important thing is that you can formulate precise statements and write them using formulas.
Writing this I was thinking about an answer of yours, at an other post of me, namely this one:
It is important that "$A(m)$ terminates within $n$ steps" is a decidable statement. That is, there is a Turing machine $M$ (or a Java method, C function, etc.) that for given $m$ and $n$ will always terminate and return "yes" or "no" depending on whether this statement is true or false.
So I think that I didn't formulate it correctly. Is it more clear as follows?
We construct a Turing machine $M$ such that if $A(m)$ terminates for some $m \in \mathbb{N}$ then $M$ halts giving output $1$, otherwise $M$ does not halt. So we see that the statement "$x$ is an element of the domain of $f$" is recursively enumerable and so the domain of $f$ is recursively enumerable.
This is OK. Usually the term "r.e." is applied to sets, but it can be applied to predicates (as you are writing) if you explicitly define what it means. I would simply say after defining $M$ that the domain of $f$ is r.e. by definition.
Ok.
For the second proposition I have thought the following:
Suppose that $f$ is a recursive function. Let $y \in image (f)$. We construct $M$ like that:
We run $f$ on $0,1,2, \dots$ and if $f(n)=y$ for some $n \in \mathbb{N}$ then $M$ terminates giving input $1$, otherwise $M$ loops forever. So the range of a recursive function is recursively enumerable.
Am I right?
Does it also hold that if $A$ is recursively enumerable then $A$ is the range of some recursive function?
If so, how can we find a function whose range is $A$?
If $y \in image (f)$, then the second option is impossible.
Or $A=\emptyset$.
It was discussed in https://driven2services.com/staging/mh/index.php?threads/19389/.
Oh yes, that's right... It should be as follows, right?
Suppose that $f$ is a recursive function. We construct $M$ like that:
Or $A=\emptyset$.
I see.
Given input $y$, $M$ runs
Thus, $M$ terminates on elements of the image of $f$ and only on them, i.e., the image of $f$ is r.e.
I see... Thanks a lot! (Smile)
FAQ: Propositions for recursive functions
What is a recursive function?
A recursive function is a function that calls itself within its own definition. This allows for the function to repeat a specific set of steps or calculations until a base case is reached.
What is a base case in a recursive function?
A base case is a condition that, when met, signals the end of the recursive function. It is necessary to prevent the function from infinitely calling itself and causing a stack overflow.
How do recursive functions differ from iterative functions?
Recursive functions differ from iterative functions in that they repeatedly call themselves, while iterative functions use looping structures to repeat a set of steps a certain number of times. Recursive functions are often more elegant and concise, but may also be less efficient for certain problems.
What are some examples of problems that can be solved using recursive functions?
Some examples of problems that can be solved using recursive functions include calculating the factorial of a number, finding the nth term in a Fibonacci sequence, and traversing a binary tree data structure.
Are there any limitations to using recursive functions?
Yes, there are some limitations to using recursive functions. One limitation is that they may require more memory and time to execute compared to iterative functions. Additionally, if the base case is not reached, the function will continue to call itself indefinitely, leading to a stack overflow error.
