Protecting Appliances from Short Power Outages
In summary, home appliances such as air conditioners and refrigerators have a thermal overload sensor that shuts off power to protect the motor from overheating or drawing too much current. The reason for the recommended wait time before restarting the appliance is to prevent damage to the motor due to residual heat and liquid refrigerant that cannot be compressed immediately. This feature is also seen in handheld hair dryers to prevent overheating and potential melting.
kenny1999
235
Are our common home appliances mostly designed to protect itself against tough and unusual conditions like sudden power outage or very short power outage? (i.e. power goes off and resumes within short time)?
I have an AC unit that it is labelled to suggest not to restart the machine after turning it off within three minutes. I'm wondering what is the reason? Could it stress or damage any parts of the appliance?
Thanks
Yes, air conditioners and refrigerators have a thermal overload sensor on the motors that remove power if the motors overheat or draw too much current for a significant time.
The compressors compress the refrigerant gas, which also heats the refrigerant. In normal operation the refrigerant then passes to a 'condensor', essentially a radiator, to cool it enough to condense it into a liquid.
When the compressor stops, the refrigerant gas that is still in the compressor cools down and some of it turns to a liquid.
Now liquids can NOT be compressed. If the compressor comes back on immediately, the motor can't turn. This causes a high current and also heats the motor.
That is when the thermal overload shuts off, similar to what a circuit breaker does. When the temperature goes down, the thermal overload automatically resets and allows another starting attempt.
Cheers,
Tom
p.s. Handheld Hair Dryers also have a thermal overload, that way if the airflow is blocked the heater is shut off before things start melting.
Likes berkeman
Related to Protecting Appliances from Short Power Outages
1. What is a short power outage?
A short power outage is a temporary interruption in the supply of electricity, typically lasting for a few seconds to a few minutes. It can be caused by various factors such as severe weather, equipment failure, or human error.
2. How can a short power outage damage appliances?
Short power outages can cause damage to appliances by disrupting the flow of electricity and causing power surges when the power is restored. This sudden surge of electricity can overload and damage sensitive electronic components in appliances.
3. What are some ways to protect appliances from short power outages?
One way to protect appliances is to use surge protectors or power strips with surge protection. These devices can absorb excess electricity and prevent it from reaching your appliances. Unplugging appliances during a power outage can also protect them from potential damage.
4. Are some appliances more vulnerable to short power outages than others?
Yes, appliances with sensitive electronic components such as computers, televisions, and refrigerators are more vulnerable to damage from short power outages. It is important to take extra precautions to protect these appliances during power outages.
5. Can a backup generator protect appliances from short power outages?
Yes, a backup generator can provide protection for appliances during short power outages. However, it is important to properly install and maintain the generator to ensure it is functioning correctly and does not cause any damage to appliances.
  • Electrical Engineering
