Protein Dynamics By Raman Spectroscopy
In summary, the conversation discusses methods for monitoring the dynamics of specific protein domains, such as using Raman spectroscopy and labeling with isotopes. It is possible to study these dynamics without any modifications to the protein, but often mutant proteins are used for more accurate results. The conversation also mentions a study on OmpA as an example. The speaker also asks about the possibility of performing differential analysis and the significance of aromatic residues in the analyzed domains.
carxtal
Can one monitor dynamics of a specific protein domain (helix, strand etc) by Raman Sp? If one labels a specific residue with an isotope, like in NMR, can one use that to monitor the dynamics of the region that encompasses this residue?
Chemistry news on Phys.org
From my understanding (or lack thereof), you do not need any specific modifications to a protein in order to study a specific area in dynamic raman spec. studies (provided that the area(s) of interest are identifiable and show strong enough absorbance/signal). However, more often than not dynamics studies in proteins that monitor specific areas of a protein utilize some form of mutant proteins (some truncated, a residue here and/or there swapped, etc.).
Perhaps, this study of the folded and unfolded states of OmpA may be of use to you http://galileo.ucsd.edu/pdf/sanchez_jpcb_08.pdf
Please let me know if this helps.
Thanks much!
Therefore, if i have 2 mutants to a WT protein I should be able to measure dynamics of these 3 proteins. Can I localize the analysis of the dynamics to a specific domain? Say a single helix? Can one perform a differential analysis to compare WT->mutant 1 and WT->mutant2? Simply put, can one subtract spectra in a statistically significant manner?
Fianlly, I understand that residues with aromatic sidechains like tryptophans are more significant spectra. Will it be an issue of the domains in question do not have such aromatic residues?
Thanks again!
Related to Protein Dynamics By Raman Spectroscopy
1. What is protein dynamics?
Protein dynamics refers to the movements and fluctuations of a protein molecule, including its internal motions, conformational changes, and interactions with its surroundings.
2. How does Raman spectroscopy measure protein dynamics?
Raman spectroscopy uses a laser to excite the molecules in a protein sample, causing them to vibrate and emit light at specific wavelengths. By analyzing the intensity and frequency of this emitted light, scientists can gather information about the protein's structure, dynamics, and interactions.
3. What are the advantages of using Raman spectroscopy for studying protein dynamics?
Raman spectroscopy is a non-destructive and non-invasive technique, meaning it does not alter or damage the protein sample being studied. It also provides high-resolution information about the protein's dynamics at the molecular level, making it a powerful tool for understanding biological processes.
4. What types of protein dynamics can be studied with Raman spectroscopy?
Raman spectroscopy can be used to study a wide range of protein dynamics, including changes in conformation, folding, stability, and interactions with other molecules. It can also be used to investigate how these dynamics are affected by factors such as temperature, pH, and ligand binding.
5. Are there any limitations to using Raman spectroscopy for studying protein dynamics?
Raman spectroscopy is limited by the size and complexity of the protein molecule being studied. It may also be challenging to interpret the collected data, as Raman signals can be affected by factors such as solvent effects, fluorescence, and overlapping peaks. Additionally, Raman spectroscopy may not be suitable for studying very fast or short-lived protein dynamics.
  • Chemistry
  • Atomic and Condensed Matter
  • Biology and Medical
  • Chemistry
