Protein gel results of a receptor tyrosine kinase?
  • Thread starter Violagirl
  • Tags
    Protein
In summary: So the only thing we need to worry about is which protein is phosphorylated. If you see the "kinase dead mutant" get phosphorylated, you know that the kinase domain of that receptor is active and can phosphorylate tyrosines. If you see the truncated form get phosphorylated, you know that its kinase domain is also active. And if you see neither of those forms get phosphorylated but the wild type does, then you know that the tyrosine residue is necessary for autophosphorylation.In summary, the conversation discusses the investigation of the nature of autophosphorylation in a receptor tyrosine kinase. Three forms of the receptor are constructed in an expression vector and expressed in a cell line
Violagirl
114
You are studying a receptor tyrosine kinase and want to investigate the nature of the
autophosphorylation of this protein. To do this, you construct three forms of the receptor in an
expression vector: 1) a normal form with an active kinase domain and one tyrosine that is
phosphorylated upon activation, 2) a “kinase-dead” mutant that is larger than wildtype and carries an inactivating mutation in the kinase domain, and 3) a truncated form that has an active kinase domain but is missing the tyrosine residue (see Figure below). You express these forms in a cell line that lacks expression of this receptor (that is, there is no endogenous receptor at the plasma membrane in these cells). To test whether cis or trans phosphorylation occurs, you express the forms singly and in pairs (see lanes on gel below). You then treat these cells with ligand and radioactive ATP (32P on the γ-P) and then immunoprecipitate the receptor proteins from a cell extract. You analyze expression of the receptors by immunoblotting with an antibody that recognizes all three forms of the receptor and you detect phosphorylation by autoradiography. Your expression results are shown in the first blot
on the attached document.
Draw what the autoradiography results would look like if the receptor autophosphorylates in trans and in cis in two separate diagrams.
  • Protein Gel.docx
Do you understand what the question is asking when it talks about autophosphorylation occurring "in trans" vs "in cis"?
I do. I know that autophosphorylation refers to how the enzyme can phosphorylate itself to isomerize to both cis and trans structures. In the cis state, its kinase activity is off and can only be turned on upon binding to a ligand, which would allow it to isomerize into a trans state and allow for it to act as a catalyst for the phosphorylation of other proteins. I didn't understand how you would go about showing the trans and cis structures would look like on an audioradiogram.
Actually, that's not what cis and trans are referring to here. Receptor tyrosine kinases act as dimers, so two receptor molecules will come together to bind the ligand. These receptors can either be identical and form a homodimer or be two different variants of the receptor and form a heterodimer. When the dimer binds ligand, the kinase domains phosphorylate a tyrosine in the intracellular portion of the receptor, activating the receptor.
Let's call the two receptors in the dimer receptor A and receptor B. The question here is whether the kinase domain in receptor A phosphorylates the tyrosine in receptor A (the "in cis" model since the autophosphorylation occurs in an intramolecular reaction) or whether the kinase domain in receptor A can phosphorylate the tyrosine in receptor B (the "in trans" model since the autophosphorylation occurs in an intermolecular reaction).
Does this help?
That clarifies a lot for me, thank you! So in terms of thinking of how it would look on an gel assay, you would consider whether is it a homodimer or a heterodimer, right? So in terms of drawing expected autoradiography results for autophosphorylation of a receptor in a trans structure and if they only appear upon phosphorylation, would that mean you could only see the blots that show the expression of the "kinase dead mutant" that lacks the ligand binding site and truncated form containing the active kinase region but lacking the tyrosine residue and an absence of any homodimer structures forming? And vice versa for showing just the cis structures? I apologize for all the questions, thanks so much for going through this with me!
Cis and trans do not refer to homodimer vs heterodimer in this case. Autophosphorylation in cis means that the autophosphorylation reaction occurs in an intramolecular reaction (the receptor phosphorylates its own tyrosine). Autophosphorylation in trans means that the autophosphorylation occurs in an intermolecular reaction (the receptor phosphorylates its neighbors tyrosine).
Perhaps consider the following analogy. Imagine a world where a law exists saying that everyone must tie their own shoes (all shoe tying must happen in cis). In this case, someone who lacks hands will never have their shoes tied. However, if you can ask your neighbor to tie your shoe (i.e. shoe tying can occur in trans), then the person lacking hands can have his shoes tied provided that his neighbor has hands as well.
The western blot will tell you which proteins get phosphorylated. Whether the proteins form homodimers or heterodimers is unimportant in the case of the gel since the SDS in the gel breaks apart the dimers.
Related to Protein gel results of a receptor tyrosine kinase?
1. What is a protein gel and how does it work?
A protein gel is a laboratory technique used to separate and analyze proteins based on their size and charge. This is done by applying an electric current to a gel matrix containing the proteins, causing them to migrate through the gel at different rates based on their physical properties.
2. What is a receptor tyrosine kinase?
A receptor tyrosine kinase (RTK) is a type of cell surface receptor that plays a crucial role in cell signaling and communication. These receptors are activated by specific ligands and initiate a cascade of biochemical reactions that can ultimately lead to changes in cell behavior.
3. How are protein gel results of a receptor tyrosine kinase interpreted?
The protein gel results of a RTK experiment can be interpreted by comparing the size and intensity of the protein bands to known standards or controls. The location and intensity of the bands can provide information about the size, abundance, and potential modifications of the RTK protein.
4. What factors can affect the results of a protein gel experiment?
The results of a protein gel experiment can be affected by various factors, including the type and purity of the protein sample, the running conditions (such as voltage and gel concentration), and the staining and imaging techniques used. It is important to carefully control these variables in order to obtain accurate and reproducible results.
5. What can protein gel results of a receptor tyrosine kinase tell us about cellular processes?
The protein gel results of a RTK experiment can provide valuable insights into the cellular processes involving this particular receptor. For example, changes in the abundance or activation of the RTK protein may indicate alterations in cell signaling pathways or response to external stimuli. Additionally, the interaction of the RTK with other proteins can also be studied using protein gel techniques.
  • Biology and Medical
