Proton / electron mass ratio equation
In summary, the conversation discusses a new formula that claims to calculate the proton/electron mass ratio, but the reasoning behind the use of certain constants is unclear. The source of the formula is also questionable and may be considered as elaborate numerology. There is a debate on whether this formula should be removed or debunked, as it may be seen as stifling scientific progress. However, the formula is based on a predicted proton radius from a controversial figure, making it unreliable. The conversation ends with the suggestion that the thread be closed due to the questionable nature of the formula.
infinite_kitsch
Hi all, I'm new to the forum so I hope this is the right place to pose this question. I've managed to find answers to nearly all of the questions I've had regarding certain aspects of physics on the forums, but haven't seen this addressed anywhere.
According to Wikipedia ( https://en.wikipedia.org/wiki/Proton-to-electron_mass_ratio ), there is a new "formula" that can be used to calculate the proton/electron mass ratio. Personally, I can't find any reasonining behind the use of many of the constants in this formula. Not only that, but the "source" (if it can even be called that) for the formula also doesn't seem to provide any reasoning behind the derivation:
http://phxmarker.blogspot.cz/2015/08/the-razors-edge-muonic-proton-radius-in.html
I'm wondering if this formulation holds any validity whatsoever. I can't put together what the Fine structure or Rydberg constants have to do with the derivation and was hoping somebody here could help make sense of it. To me, it just seems to be elaborate numerology but I'd be happy with any insight people could provide.
thanks!
That's what it is, and that's what's wrong with Wikipedia. Crackpots can write whatever they want.
Thank you for your reply. I'm guessing that these kinds of ideas are so far from being actual science that it's difficult to point out concrete issues. I'm trying to find specific reasons why the Fine structure or Rydberg constants don't apply at all, but it's impossible to even conceive of reasons why they would apply. It seems as though they were just randomly selected, but any additional insight would be appreciated.
Why don't we try to block those false informations?
I don't think that removing it would achieve too much as the people behind it would claim that people were "stifling the science" behind the equation.
It would be more productive to demonstrate why it is incorrect, but the problem is, that it can't even be demonstrated that it is in any way correct in the first place. Even though the numbers match, the reasoning behind it is conspiquously absent. What would seem to be necessary would be to show why these constants have absolutely no relation to this problem, but the issue is that it's such a soup of nonsense that it becomes difficult to even address the initial ingredients.
Not very well. I get 1750 and not 1820.
The Rydberg constant has the electron mass in it. The proton radius has units of inverse mass (in conventional units), and the inventor of the equation liberally sprinkles alphas and pis around.
I agree with your points, but apparently the dichotomy lies in the fact that instead of the "accepted" value of the proton radius, the formula is supposed to use Nassim Haramein's "predicted proton radius" as I've entered here:
http://wolfr.am/9TQG9pBx
This is allegedly supposed to demonstrate that this predicted radius is more accurate than the measured radius as it then leads to a closer match for the proton/electron mass ratio.
Crackpottery on top of crackpottery. I think this thread should be closed.
Done. :smile:
Related to Proton / electron mass ratio equation
1. What is the "proton / electron mass ratio equation"?
The proton / electron mass ratio equation is a mathematical formula used to calculate the ratio of the mass of a proton to the mass of an electron. It is represented as mp/me, where mp is the mass of a proton and me is the mass of an electron.
2. Why is the proton / electron mass ratio important?
The proton / electron mass ratio is important because it is a fundamental constant in physics and has a significant impact on our understanding of the universe. It is used in various calculations and equations in fields such as quantum mechanics and cosmology.
3. How is the proton / electron mass ratio calculated?
The proton / electron mass ratio is calculated by dividing the mass of a proton by the mass of an electron. The mass of a proton is approximately 1.6726 x 10-27 kilograms, while the mass of an electron is approximately 9.1094 x 10-31 kilograms. When divided, the resulting ratio is approximately 1836.152.
4. What is the significance of the proton / electron mass ratio?
The significance of the proton / electron mass ratio lies in its relationship to other fundamental constants, such as the fine structure constant and the gravitational constant. It also plays a crucial role in determining the stability of atoms and the strength of electromagnetic forces.
5. How does the proton / electron mass ratio vary?
The proton / electron mass ratio is considered a constant, meaning it does not vary significantly under normal conditions. However, it has been found that the ratio may differ slightly in different parts of the universe due to variations in the strength of electromagnetic forces.
  • Astronomy and Astrophysics
  • Electromagnetism
