MHB Prove 1989/2-1988/3+1987/4-...-2/1989+1/1990=1/996+3/997+5/998+...+1989/1990
  • Thread starter Thread starter anemone
The discussion revolves around proving the equation $$\frac{1989}{2}-\frac{1988}{3}+\frac{1987}{4}-\cdots-\frac{2}{1989}+\frac{1}{1990}=\frac{1}{996}+\frac{3}{997}+\frac{5}{998}+\cdots+\frac{1989}{1990}$$. A suggested approach involves converting the expression to algebraic form by substituting $n=995$, simplifying the equation, and testing it for smaller values of $n$. The method includes moving terms from the right side to the left and combining them with corresponding terms to facilitate proof. Verifying the formula for smaller values of $n$ is recommended to build confidence in its validity. This approach aims to clarify the proof process and reduce complexity.
anemone
MHB
POTW Director
Hi members of the forum,
I have been trying so hard to prove the following:
$$\frac{1989}{2}-\frac{1988}{3}+\frac{1987}{4}-\cdots-\frac{2}{1989}+\frac{1}{1990}=\frac{1}{996}+\frac{3}{997}+\frac{5}{998}+\cdots++\frac{1989}{1990}$$
but to no avail and what I couldn't bear was that my approach gave me a tremendously messy bundle of terms everywhere on the paper...
Could you please at least give me some idea on how to prove it?
Thanks in advance.
Mathematics news on Phys.org
Thanks in advance.
I would start by converting this expression from arithmetic to algebra. If you put $n=995$ then the equation becomes $$\frac{2n-1}2 - \frac{2n-2}3 +\frac{2n-3}4 -\ldots - \frac2{2n-1} + \frac1{2n} = \frac1{n+1} + \frac3{n+2} + \frac5{n+3} + \ldots + \frac{2n-1}{2n}.$$ The next thing is to ask whether that formula holds for other values of $n$. I checked that it works for $n=2$ and $n=3$, which makes it seem likely to hold in general.
So, how to prove it? Now that you have got rid of all those numbers, it ought to be easier to see what to do next. Take each term on the right side of the formula over to the left (changing the sign, of course) and combine it with the term having the same denominator on the left side. There is still some way to go, but I think you should be able to verify the formula that way. If in doubt, go back to smaller values of $n$, such as $n=4$, and check what happens there.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
