Prove 2-D Lorentzian Metric is Locally Equivalent to Standard Form
In summary, you can change coordinates to a set of coordinates that diagonalise the metric locally. This should just be an exercise in diagonalising a 2x2 matrix.
Pentaquark5
Hi, how can I prove that any 2-dim Lorentzian metric can locally be brought to the form
$$g=2 g_{uv}(u,v) \mathrm{d}u \mathrm{d}v=2 g_{uv}(-\mathrm{d}t^2+dr^2)$$
in which the light-cones have slopes one?
Thanks!
By changing coordinates to a set of coordinates that diagonalise the metric locally. This should just be an exercise in diagonalising a 2x2 matrix.
Your notation is a little mixed up. Typically, we would write:
[itex]ds^2 = \sum_{u v} g_{uv} dx^u dx^v[/itex]
where [itex]ds[/itex] is the line element, sort of an infinitesimal length, and [itex]u, v[/itex] range over the indices for your coordinate system, and [itex]g_{uv}[/itex] is a component of the metric tensor in that coordinate system. There is no factor of [itex]2[/itex], and it doesn't make sense to write [itex]g_{uv} (dt^2 - dx^2)[/itex]. [itex]u[/itex] and [itex]v[/itex] are dummy indices, while [itex]t[/itex] and [itex]x[/itex] are specific coordinates. It would make sense to write:
[itex]ds^2 = g_{tt} dt^2 + g_{xx} dx^2[/itex]
using [itex]t[/itex] and [itex]x[/itex] as both the coordinates and the indices, or you can write it as:
[itex]ds^2 = g_{00} (dx^0)^2 + g_{11} (dx^1)^2[/itex]
where [itex]x^0 \equiv t[/itex] and [itex]x^1 \equiv x[/itex]
Let's not prejudice ourselves by writing [itex]x[/itex] and [itex]t[/itex], but instead start with arbitrary coordinates [itex]u[/itex] and [itex]v[/itex]. Then we can write it as a matrix problem:
[itex]ds^2 = \left( \begin{array} \\ du & dv \end{array} \right) \left( \begin{array} \\ g_{uu} & g_{uv} \\ g_{vu} & g_{vv} \end{array} \right) \left( \begin{array} \\ du \\ dv \end{array} \right) = g_{uu} du^2 + g_{uv} du dv + g_{vu} dv du + g_{vv} dv^2 [/itex]
Then the issue is to change coordinates from [itex]u, v[/itex] to [itex]x, t[/itex] via a transformation matrix [itex]K[/itex]:
[itex]\left( \begin{array} \\ du \\ dv \end{array} \right) = \left( \begin{array} \\ K_{ut} & K_{ux} \\ K_{vt} & K_{vx} \end{array} \right) \left( \begin{array} \\ dt \\ dx \end{array} \right)[/itex]
Then you want to choose [itex]K[/itex] such that [itex]\tilde{g} \equiv K^T g K[/itex] is diagonal (as a matrix equation), where [itex]K^T[/itex] means the transpose of [itex]K[/itex]. Then in terms of [itex]\tilde{g}[/itex], you have:
[itex]ds^2 = \left( \begin{array} \\ dt & dx \end{array} \right) \left( \begin{array} \\ \tilde{g}_{tt} & 0 \\ 0 & \tilde{g}_{xx} \end{array} \right) \left( \begin{array} \\ dt \\ dx \end{array} \right) = \tilde{g}_{tt} dt^2 + \tilde{g}_{xx} dx^2 [/itex]
Once the metric is diagonal, you can get it into the form: [itex]ds^2 = g_{tt} (dt^2 - dx^2)[/itex] by just scaling [itex]x[/itex]: [itex]x \rightarrow \frac{\sqrt{g_{tt}}}{\sqrt{-g_{xx}}} x[/itex]
Note, that all of this is taking place at a single point. That is, you can always pick coordinates so that [itex]g_{xt} = 0[/itex] at a single point. I'm actually not sure if it's always possible to make the metric diagonal at every point.
The given metric is in light-cone coordinates where there is only one term (remembering that the metric tensor is symmetric) since both coordinate directions are null. The corresponding metric component is ##g_{uv} = g_{vu}##. The problem is to rewrite this in another set of coordinates such that the metric components become ##g_{tt} = -g_{xx} = 2g_{uv}##.
Edit: Note that physicists will often write ##2 du\, dv## when they really mean ##du\otimes dv + dv\otimes du##.
The metric is symmetric. It is always possible to find an orthogonal basis to a real symmetric matrix.
Likes cianfa72 and vanhees71
That wasn't the question.
It's certainly true that for any specific point [itex]\mathcal{P}[/itex] there is a coordinate system [itex]x, t[/itex] such that [itex]g_{x t} = 0[/itex] at point [itex]\mathcal{P}[/itex]. But it doesn't obviously follow from that that [itex]g_{x t} = 0[/itex] everywhere.
Ah. I misunderstood. I thought that there was an implicit summation going on, so that [itex]g_{uv} du dv[/itex] meant a sum over all possible [itex]u[/itex] and [itex]v[/itex].
Sorry, I read your post a bit fast. I was already in "local mode" since it was mentioned in the OP.
Thanks everybody for your help!
I got thrown off by a Hint that said "use coordinates associated with right-going and left-going null geodesics." which made it sound much more complicated than it was.
##u=r-t## and ##v=r+t##
Related to Prove 2-D Lorentzian Metric is Locally Equivalent to Standard Form
1. What is the 2-D Lorentzian Metric?
The 2-D Lorentzian Metric is a mathematical representation of the curvature of spacetime in two dimensions. It is used in the study of General Relativity and is based on the principles of the Lorentz transformation in Special Relativity.
2. How is the 2-D Lorentzian Metric different from the standard form?
The standard form of the Lorentzian Metric is a diagonal matrix with the elements representing the spacetime intervals in different directions. The 2-D Lorentzian Metric, on the other hand, is a non-diagonal matrix that takes into account the curvature of spacetime in two dimensions.
3. What does it mean for the 2-D Lorentzian Metric to be locally equivalent to the standard form?
Local equivalence means that the 2-D Lorentzian Metric can be transformed into the standard form at a specific point in spacetime. This is important in General Relativity as it allows for the smooth transition between the two metrics and helps in the understanding of the curvature of spacetime.
4. How is the local equivalence of the 2-D Lorentzian Metric to the standard form proven?
To prove the local equivalence, one must use the Lorentz transformation equations to transform the 2-D Lorentzian Metric into the standard form at a specific point. This involves calculating the spacetime intervals in both metrics and showing that they are equal at that point.
5. What are the applications of proving the local equivalence of the 2-D Lorentzian Metric to the standard form?
Understanding the local equivalence of the 2-D Lorentzian Metric to the standard form is crucial in the study of General Relativity and the curvature of spacetime. It allows for a better understanding of the effects of gravity and the behavior of objects in the presence of massive bodies. It also helps in the development of mathematical models and calculations in cosmology and astrophysics.
