Prove 2coth^(-1)(e^x) = ln[cosech x + coth x]
  • Thread starter Thread starter DryRun
To prove the equation 2coth^(-1)(e^x) = ln[cosech x + coth x], the initial approach involves manipulating the left-hand side (LHS) by expressing it in terms of tanh^(-1). The transformation leads to ln[(1+(e^-x))/(1-(e^-x))], but progress stalls at this point. A suggestion is made to work from the right-hand side (RHS) and use the substitution u = e^x to simplify the process. This substitution is expected to clarify the relationship between the two sides of the equation. The discussion emphasizes the importance of strategic manipulation in proving the identity.
DryRun
The attempt at a solution
I'm starting with the L.H.S. first, which is conventional, i think.
2coth^(-1)(e^x)
= 2tanh^(-1)(e^-x)
= 2[1/2 ln [(1+(e^-x))/(1-(e^-x))]
= ln [(1+(e^-x))/(1-(e^-x))]
I'm stuck.
So, i tried to cheat a little, by expanding the R.H.S. and see if i could find a way to convert the last step above into the R.H.S. but my copybook has become something of a painting.
2coth^(-1)(e^x)
= 2tanh^(-1)(e^-x)
I'm stuck.
Hints: work from the RHS, and substitute u = e^x. Will make everything much clearer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
