MHB Prove 2x2 Matrix Puzzle: No $S$ Exists for $S^n$
  • Thread starter Thread starter lfdahl
    Matrix Puzzle
There is no 2x2 matrix \( S \) such that \( S^n = \begin{pmatrix} 0 & 1 \\ 0 & 0 \end{pmatrix} \) for any integer \( n \geq 2 \). The matrix \( T \) has rank 1, and its image and null space are both 1-dimensional, leading to \( T^2 = 0 \). If \( T = S^n \), then \( S \) must also have rank 1, as it cannot be rank 2 or 0. This implies that the image and null space of \( S \) are equal, resulting in \( S^2 = 0 \), which contradicts \( T \neq 0 \). Therefore, \( T \) has no \( n \)th roots for \( n \geq 2 \.
lfdahl
MHB
Prove, that there is no $2 \times 2$ matrix, $S$, such that
\[S^n= \begin{pmatrix} 0 & 1\\ 0 & 0 \end{pmatrix}\]
for any integer $n \geq 2$.
Mathematics news on Phys.org
[sp]Let $T = \begin{bmatrix} 0 & 1\\ 0 & 0 \end{bmatrix}$. Then $T$ has rank $1$. Considering $T$ as a linear operator on a $2$-dimensional space, its image and its null space are both equal to the $1$-dimensional subspace spanned by the first basis vector $\begin{bmatrix} 1\\ 0 \end{bmatrix}$ (and hence $T^2 = 0$, as you can easily check by squaring the matrix).
Suppose that $T = S^n$. Then $S$ cannot have rank $2$, because then it would be surjective and so every power of $S$ would also be surjective. Also, $S$ cannot have rank $0$, because then it would represent the zero operator and so $T$ would be $0$. So $S$ must have rank $1$.
If the vector $x$ is in the null space of $S$ then $Tx = S^nx = S^{n-1}Sx = 0$. So the null space of $S$ is contained in the null space of $T$. But since those spaces are both $1$-dimensional, they must be equal.
For any vector $y$, $Ty = S(S^{n-1}y)$. So the image of $S$ contains the image of $T$. But since those spaces are both $1$-dimensional, they must be equal.
Therefore the image and null space of $S$ are equal. So for any vector $y$, $S^2y = S(Sy) = 0$ and thus $S^2$ is the zero matrix. But if $S^2 = 0$ then $S^n = 0$ for all $n\geqslant 2$, contradicting the fact that $T \ne0$.
Thus $T$ has no $n$th roots, for $n\geqslant 2$.[/sp]
Suppose $S$ exists and has eigenvalues $\lambda_1$ and $\lambda_2$ (which could conceivably be complex).
Then $S^n$ has eigenvalues $\lambda_1^n$ and $\lambda_2^n$.
The given matrix is in Jordan Normal Form, showing that $\lambda_1^n=\lambda_2^n=0$, and therefore $\lambda_1=\lambda_2=0$.
So $S$ is either similar to the 0 matrix, or to the given nilpotent matrix.
If $S$ is similar to 0, then $S^n=0$, which is a contradiction.
And if $S$ is similar to the given nilpotent matrix, then $S^n=0$, which is also a contradiction.
Therefore there is no such $S$.
Hi, Opalg! - another excellent contribution from you! Thankyou for sharing your expertice in this challenge/puzzle forum!(Handshake)
Thanks a lot, I like Serena. You are fast on the trigger! - yet still hitting "bulls eye" with this very fine solution of yours. Thankyou for your participation!(Cool)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
