Prove $40ac<1$ Given $a, b, c$ Real Positive Numbers
  • MHB
  • Thread starter anemone
In summary, the problem states that if $a+\sqrt{b+\sqrt{c}}=c+\sqrt{b+\sqrt{a}}$, then $40ac<1$. If $b=3$, then $40ac<1$ for any $c>0$.
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c$ be three distinct positive real numbers such that $a+\sqrt{b+\sqrt{c}}=c+\sqrt{b+\sqrt{a}}$, prove that $40ac<1$.
Mathematics news on Phys.org
must have a typo ,I think it should be:
prove that: $ac<1$
check :$b=3,c=1$ and we get $0.5<a<1$
if $(a\neq c=1)$
prove that: $ac<1$
if $(a\neq c=1)$
Hi Albert,
I just checked with my source and no, there is no typo and although I can't provide an example to show that $40ac<1$ is true under the given condition, I suppose the problem is correct, judging from the solution that I have at hand...
But, if $b=3$, I then checked with wolfram (solve x'+'sqrt'{'3'+''\'sqrt'{'y'}''}''='y'+'sqrt'{'3'+''\'sqrt'{'x'}''}' - Wolfram|Alpha) and I hoped to obtain at least one set of solution for $(a,\,3,\,c)$ to show that $40ac<1$ is true, I realized the second relationship between $a$ and $c$ is what I wanted, and by plugging $a=1$, it returned a negative $c$, that has thrown me off. $c$ can't be a negative...:confused:
Perhaps $b$ lies in certain interval and it certainly can't be a 3...
anemone said:
Hi Albert,
Perhaps $b$ lies in certain interval and it certainly can't be a 3---
To this problem it only said $(a\neq b \neq c)$, and $(a,b,c>0)$
if $b$ can't be 3 ,you should point out the interval of $ a,b,c$ first
I'm not seeing the issue here. The problem clearly asks to prove that $40ac < 1$ whenever $a + \sqrt{b + \sqrt{c}} = c + \sqrt{b + \sqrt{a}}$ holds for distinct reals $a, b, c > 0$. That equation is what gives the necessary restrictions on $a$, $b$ and $c$, as not all triplets of positive reals $(a, b, c)$ satisfy the equation. If $b$ can't be 3 for the equation to hold then that just means that there is nothing to prove for triplets of the form $(a, 3, c)$, and the fact that $40ac < 1$ fails to hold for these particular triplets is immaterial.
[sp]The problem is symmetric in $a$ and $c$, so we may assume that $a>c$. Then $a-c = \sqrt{b+\sqrt a} - \sqrt{b+\sqrt c}$ and so $$ \begin{aligned} (a-c)\bigl(\sqrt{b+\sqrt a} + \sqrt{b+\sqrt c}\bigr) &= \bigl(\sqrt{b+\sqrt a} - \sqrt{b+\sqrt c}\bigr)\bigl(\sqrt{b+\sqrt a} + \sqrt{b+\sqrt c}\bigr) \\ &= \bigl(b+\sqrt a\bigr) - \bigl(b+\sqrt c\bigr) = \sqrt a - \sqrt c. \end{aligned}$$ Therefore $(a-c)\bigl(\sqrt{b+\sqrt a} + \sqrt{b+\sqrt c}\bigr) = \bigl(\sqrt a - \sqrt c\bigr)\bigl(\sqrt a + \sqrt c\bigr)\bigl(\sqrt{b+\sqrt a} + \sqrt{b+\sqrt c}\bigr) = \sqrt a - \sqrt c$. Since $a\ne c$, we can divide through by $\sqrt a - \sqrt c$ to get $$\bigl(\sqrt a + \sqrt c\bigr)\bigl(\sqrt{b+\sqrt a} + \sqrt{b+\sqrt c}\bigr) = 1.$$ For that to have a solution with $b>0$ we must have $\bigl(\sqrt a + \sqrt c\bigr)\bigl(\sqrt[4]{ a} + \sqrt[4]{c}\bigr) < 1.$ Thus $$\tfrac12\bigl(\sqrt a + \sqrt c\bigr) \cdot\tfrac12\bigl(\sqrt[4]{ a} + \sqrt[4]{c}\bigr) <\tfrac14.$$ By GM-AM, that implies $\sqrt[4]{ac}\,\sqrt[8]{ac} < \frac14$, so that $(ac)^{3/8} < \frac14$ and hence $4^{8/3}ac < 1$. But $4^{8/3} \approx 40.3$, so we conclude that $40ac<1.$[/sp]
anemone said:
Let $a,\,b,\,c$ be three distinct positive real numbers such that $a+\sqrt{b+\sqrt{c}}=c+\sqrt{b+\sqrt{a}}----(1)$, prove that $40ac<1$.
putting $b=3,c=1$ to (1) and simplify , I get :
$a^4+4a^3-9a+4=0=(a-1)(a^3+5a^2+5a-4)$
since $a \neq 1 ,\therefore a^3+5a^2+5a-4=0----(2)$
the only solution for (2) is $a\approx 0.5115$
this leads to $ac<1$
how to explain it?
how to explain it?
If $a = 0.5115$, $b=3$ and $c=1$ then $a + \sqrt{b + \sqrt c} = 0.5115 + \sqrt4 = 2.5115$. But $c + \sqrt{b + \sqrt a} \approx 1 + \sqrt{3 + 0.7152} \approx 1 + 1.9275 = 2.9275 \ne 2.5115.$ So the value found for $a$ is a spurious result, not a solution of the original equation. It may have been introduced by squaring at some stage.
Thanks Opalg,:) for participating in this challenge and thanks too for the explanation that answered to Albert's question.
FAQ: Prove $40ac<1$ Given $a, b, c$ Real Positive Numbers
1. What does the statement "Prove $40ac<1$ Given $a, b, c$ Real Positive Numbers" mean?
The statement means that we must prove that the product of 40, $a$, and $c$ is less than 1, given that $a$, $b$, and $c$ are all real positive numbers.
2. How do we prove this statement?
We can prove this statement by using mathematical principles and logic to show that the product of 40, $a$, and $c$ is always less than 1, given that $a$, $b$, and $c$ are all real positive numbers.
3. Can we assume anything about the values of $a$, $b$, and $c$ in this statement?
Yes, we can assume that $a$, $b$, and $c$ are all real positive numbers. This means that they are greater than 0 and do not include any imaginary numbers or negative numbers.
4. Is this statement always true for any values of $a$, $b$, and $c$?
Yes, this statement is always true for any values of $a$, $b$, and $c$ as long as they are all real positive numbers. This can be proven using mathematical principles and logic.
5. Why is proving this statement important?
Proving this statement is important because it helps us understand the relationship between the product of 40, $a$, and $c$, and the number 1. It also allows us to use this relationship in future mathematical equations and proofs.
