Prove ##5^n+9<6^n## for ##n\epsilon N|n\ge2## by induction
In summary, the proof shows that if ##5^k+9<6^k## for ##k\epsilon \mathbb{N}|k\ge2##, then ##5^{k+1}+9<6^{k+1}##.
McFluffy
37
Prove ##5^n+9<6^n## for ##n\epsilon \mathbb{N}|n\ge2## by induction.
None
The base case which is when ##n=2##:
##5^2+9<6^2##
##34<36##
Thus, the base case is true. Now for the induction step.
Induction hypothesis: Assume ##5^k+9<6^k## for ##k \epsilon \mathbb{N}|k\ge2##
Induction step: To show that ##5^k+9<6^k## implies ##5^{k+1}+9<6^{k+1}##, I'll start with the induction hypothesis:
##5^k+9<6^k##
##5(5^k+9)<6(6^k)## since we have an inequality and not an equation, I can add numbers that are bigger to one side and not violate inequality. With this in mind, since ##5<6##, I'd multiplied 5 on the smaller side and 6 on the bigger side.
##5^{k+1}+45<6^{k+1}##
Multiply one side by a bigger number than the other side is what makes this proof possible. And I think this is a logical thing to do because we're dealing with an inequality and not an equation. Are my steps justified?
None
##5^2+9<6^2##
##34<36##
##5^k+9<6^k##
Yes. Only your presentation could be improved. E.g.
##5^{k+1} + 9 < 5^{k+1}+45 = 5\cdot (5^k+9) <_{I.H.} 5 \cdot 6^k < 6 \cdot 6^k = 6^{k+1}##
Likes McFluffy
None
##5^2+9<6^2##
##34<36##
##5^k+9<6^k##
Yes it is all correct. Multiplication here is just adding and you can always add smaller term to a side and larger term to other side without flipping the sign.
Also you may want to use ##\in## (\in) instead of ##\epsilon##.
Sorry I did not see the post by @fresh_42 , it did not get updated on page.
Likes McFluffy
Yes, but you can show it mathematically, with less words: ##5(5^k+9)<5(6^k)<6^{k+1}##
Also, you can write in the last step ##5^{k+1}+9<5^{k+1}+45<6^{k+1}##
Likes McFluffy
What are the general guidelines that I should follow when writing a proof like this? I'm still quite new to proofs.
Good question. I think the important part is to always make clear what follows from what. Start with what you have, in this case ##5^k+9<6^k## and either ##5^{k+1}+9## and make it bigger, or ##6^{k+1}## and make it smaller. Personally I find it easier to read when it get's bigger, but this is a matter of taste. If you write your expressions from one line to the next and always handle both sides, it is more difficult to see whether you follow a path or simply write down some expressions. If both sides ##5^{k+1}+9## and ##6^{k+1}## appear in the same line, then it's hard to tell, whether you still deal with the claim or already entered the proof.
Of course you can do this in a draft and order the terms afterwards for the final version. Imagine if it were you to read it. A proof should lead from what is given to what has to be shown and the steps in between should show the implications needed. As I said, it wasn't wrong what you've written, only a bit confusing to read. You have @ehild's and mine example. Compare them with yours.
As I learned it, I followed a short template.
Condition: Given facts.
Statement: What has to be shown.
Proof: ... and in case it was an indirect proof, I wrote. Assumption: (the opposite of what has to be shown)
Now come the steps ##\Rightarrow## ... ##\Rightarrow## ...
And at the end a sign that it is the end, like a small box or so. And sure, I abbreviated these underlined words.
Likes McFluffy
Related to Prove ##5^n+9<6^n## for ##n\epsilon N|n\ge2## by induction
1. How do you use induction to prove a statement?
To use induction, you must first prove that the statement is true for a base case. Then, you assume that the statement is true for some arbitrary value of n, and use this assumption to show that the statement is also true for n+1. This completes the inductive step, and proves that the statement is true for all values of n.
2. What is the base case for this proof?
The base case for this proof is n=2, as this is the smallest value of n that is greater than or equal to 2.
3. How do you show that the statement is true for n+1?
To show that the statement is true for n+1, you must use the assumption that the statement is true for n and manipulate the expression to show that it is also true for n+1. In this proof, you would substitute n+1 for n in the expression 5^n+9<6^n and show that the resulting expression is also true.
4. What is the inductive hypothesis for this proof?
The inductive hypothesis for this proof is that the statement is true for some arbitrary value of n, which is assumed to be true for the inductive step.
5. Can induction be used to prove any statement?
No, induction can only be used to prove statements that can be expressed as mathematical equations or inequalities. It cannot be used to prove statements that involve subjective or qualitative concepts.
