MHB Prove $5x+9y=n$ Solutions for $n \ge 32$, $\mathbb{Z}_0^+$
  • Thread starter Thread starter ssome help
The discussion focuses on proving that any amount \( n \ge 32 \) can be expressed as \( 5x + 9y \) where \( x \) and \( y \) are non-negative integers. An initial case is provided with \( n = 32 \) showing \( x = 1 \) and \( y = 3 \) as a valid solution. The proof employs mathematical induction, assuming the statement holds for some integer \( k \ge 32 \) and demonstrating it for \( k + 1 \). The discussion also explores specific cases for \( k + 1 \) based on the values of \( y \), leading to valid constructions for \( n \). The conclusion affirms that all integers \( n \) from 32 onward can indeed be represented in this form.
ssome help
Prove that $n \ge \$32$ can be paid in \$5 and \$9 dollar bills ie the equation $5x+9y=n$ has solutions $x$ and $y$ element $\mathbb{Z}_0^+$ for $n$ element of $\mathbb{Z}^+$ and $n \ge 32$.
Re: $ solutions
ssome help said:
Prove that $n >=(greater than or equal to) 32 can be paid in $5 and $9 dollar bills ie the equation 5x+9y=n has solutions x and y element (Z(sub0)^+) for n element of Z^+ and n >=32.
See a similar problem here.
On this forum, the dollar sign starts a "mathematical mode" where one can use special commands to produce symbols like $\pi$ and $\int$. If you want to write a dollar sign, you can type dollar, backslash and two dollars, like this: $\$$.
Re: $ solutions
Alternatively you can type:
Code:
which comes out as \$.
Re: $ solutions
induction at n for n=32 x=1,y=3
5 + 3(9) = 32
note that 1 = 2(5) - 9
so 33 = 5 + 2(5) + 3(9) - 9
suppose it is true for k>=32 integer there exist a positive integers x,y such that
5x + 9y = k
for k+1
k+1 = 5x + 9y +1
choose 1 = 2(5) - 9, if y>=1
if y = 0
then k multiple of 5 which is 35 or larger, x>=7 so choose
1= -7(5) + 4(9)
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
