MHB Prove ∠A≤60° if (1/sinB+1/sinC)(−sinA+sinB+sinC)=2
  • Thread starter Thread starter anemone
The discussion presents an unsolved mathematical challenge involving a triangle ABC, where the angles A, B, and C satisfy a specific equation. The goal is to prove that angle A is less than or equal to 60 degrees. A solution approach involves using calculus to analyze the relationship between the sides and angles of the triangle, particularly through the sine rule and cosine rule. The derived equations indicate that angle A must lie within certain bounds, leading to the conclusion that cos A is greater than or equal to 1/2. The final result confirms that angle A cannot exceed 60 degrees.
anemone
MHB
POTW Director
Hello MHB,
This is the first of our "Unsolved challenge" threads, it is a challenge which I found pretty interesting but yet I still couldn't crack it. The posting of this challenge here is meant for you to have a fun attempt at it, but if you choose to attempt it, please don't get frustrated if you can't solve it...we'll just have to wait and see if someone can provide a solution, because as the title of the thread indicates, it is an unsolved challenge! :)
I won't beat around the bush any longer, please allow me to present one of such interesting yet unsolved challenge to you all now:
In a triangle $ABC$, the angles $A$, $B$ and $C$ satisfy the following equation:
$\left(\dfrac{1}{\sin B}+\dfrac{1}{\sin C}\right)(-\sin A+\sin B+\sin C)=2$
Prove that $\angle A \le 60^\circ$.
Mathematics news on Phys.org
[sp]Start with a bit of calculus. If $0<b\leqslant c$ and $f(x) = x(b+c-x)$, then $f(x) \geqslant bc$ whenever $b\leqslant x\leqslant c.$ The reason for that is that the (parabolic) function $f$ has its maximum at $x = \frac12(b+c)$, which lies inside the interval $[b,c]$. The minimum value of $f$ therefore lies at one of the endpoints of the interval. But $f(b) = f(c) = bc$, so that $bc$ is the minimum. [The condition $b\leqslant c$ is actually irrelevant. The result applies equally well if $b\geqslant c$, except that the interval is then $[c,b]$.]
Now let $ABC$ be a triangle, and let $a,b,c$ be the lengths of the sides opposite the respective vertices. Given that $\left(\frac{1}{\sin B}+\frac{1}{\sin C}\right)(-\sin A+\sin B+\sin C)=2$, multiply through by $\sin B\sin C$ to get $$(\sin B + \sin C)(-\sin A+\sin B+\sin C)=2\sin B\sin C,$$ $$(\sin B+\sin C)^2 - \sin A(\sin B+\sin C) = 2\sin B\sin C,$$ $$\sin^2B + \sin^2 C = \sin A(\sin B+\sin C).$$ By the sine rule, each sine is proportional to the length of the corresponding side, so that last equation is equivalent to $$b^2 + c^2 = a(b+c).$$ If that is written as $b(b-a) + c(c-a) = 0,$ it is clear that the terms on the left side must have opposite signs, so that $a$ must lie between $b$ and $c$.
Also, it follows from the cosine rule that $b^2 + c^2 = a^2 + 2bc\cos A.$ Therefore $a^2 + 2bc\cos A = a(b+c)$ and so $$\cos A = \frac{a(b+c-a)}{2bc}.$$ But $a$ lies between $b$ and $c$, so it follows from the calculus result above that $a(b+c-a) \geqslant bc.$ Thus $\cos A \geqslant \frac12$ and therefore $^\angle A \leqslant 60^\circ.$
[/sp]
I can only say thank you, Opalg, for your so insightful and intelligent solution! (Sun)(Cool)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
