Prove ##a + b = b + a## using Peano postulates
  • Thread starter Thread starter issacnewton
    Peano
issacnewton
Peano postulates
Following is a set of Peano postulates I am using as defined in the book "Th real numbers and real analysis" by Ethan Bloch.
There exists a set ##\mathbb{N}## with an element ##1 \in \mathbb{N}## and a function ##s: \mathbb{N} \rightarrow \mathbb{N} ## that satisfy the following three properties.
1) There is no ##n \in \mathbb{N}## such that ##s(n) = 1##
2) The function ##s## is injective.
3) Let ##G \subseteq \mathbb{N}## be a set. Suppose that ##1 \in G##, and that if ##g \in G## then ##s(g) \in G##. Then ## G = \mathbb{N} ##I have to prove the Commutative Law for addition ## a + b = b + a## using Peano postulates, given that ##a, b\in \mathbb{N}##. Now define the set
$$ G = \{ x \in \mathbb{N} |\forall\; y \in \mathbb{N} \quad (x + y) = (y + x) \} $$
I have proven previously, that for ## a \in \mathbb{N}##, we have,
$$ 1 + a = s(a) = a + 1 \cdots\cdots (1) $$
So, for some ##y \in \mathbb{N} ##, we get ## 1 + y = y + 1 ##. That proves that ## 1 \in G ##. Now, suppose that ## r \in G##. This means that
$$ \forall\; y \in \mathbb{N} \quad (r + y) = (y + r) \cdots\cdots (2) $$
We need to prove that
$$ \forall\; y \in \mathbb{N} \quad s(r) + y = y + s(r) $$
Let ## y \in \mathbb{N} ## be arbitrary. From ##(2)##, we get ## (r + y) = (y + r)##. It follows that ##s(r + y) = s(y + r) ##. Now, addition function is defined as follows in this book
There is a unique binary operation ##+: \mathbb{N} \times \mathbb{N} \to \mathbb{N} ## that satisfies the following two properties for all ##n, m \in \mathbb{N} ##
$$ n + 1 = s(n) $$
$$ n + s(m) = s(n + m) $$
Using this, we get, ## s(r + y) = y + s(r)##. Now, using ##(1)##, we have, ## 1 + (r + y) = y + s(r) ##. I have also previously proven Associative Law for Addition. So, using that, we get, ## (1 + r) + y = y + s(r) ##. Again using ##(1)##, this becomes ## s(r) + y = y + s(r) ##. Since ## y \in \mathbb{N} ## is arbitrary, ## s(r) \in G##. So, for some ## r \in G## it implies that ## s(r) \in G##. From Peano postulates, this means that ## G = \mathbb{N} ##.
Now let ##a, b \in \mathbb{N}## be arbitrary. So, ## a \in G##. It follows that ## (a + b) = (b + a) ##
Is this a sound proof ?
Thanks
Be more precise. The equality ##1+y=y+1## must hold for all ##y\in\mathbb N##, then it follows that ##1\in G##. You can show the identity holds by induction using ##s(1+n) = 1+s(n)##.
Show explicitly how ##1+(r+y) = y+s(r)## follows from associativity. Otherwise, you make a remark about associativity and it's up to the reader to realise that's how you concluded that equality. Leave that ambiguous style to math authors, you have the luxury of writing things out in detail.
You have already fixed ##r\in G##, there is no need to requantify it. It's confusing the reader.One might condense the induction argument as follows, label the equalities and explain them separately. Keep things concise. It holds that ##1\in G##. Let ##r\in G## and ##y\in\mathbb N##. We have that
<br /> s(r)+y \overset{1.}= (1+r)+y \overset{2.}= 1+(r+y) \overset{3.}= (r+y)+1 \overset{4.}= (y+r)+1 \overset{5.}= y + s(r).<br />
  1. Definition of ##s(n)##
  2. Associativity of ##+##
  3. ##1\in G##
  4. Induction assumption
  5. Associativity of ##+## and definition of ##s(n)##
Thanks
I agree with @nuuskur. This isn't as good as your previous proof of the associativity of ##+##. You should try to be more positive and direct.
Thanks nuuskur. I will modify the proof.
