Prove a fraction is a perfect square
In summary: I'm not sure what else to say. Thanks for taking the time to read and comment!In summary, Albert has shown that every perfect square can occur as a value of \frac{x^2+y^2}{1+xy}. That is a neat result. But it does not answer the given problem, which is to show that perfect squares are the only natural numbers that can arise in this way.
anemone
MHB
POTW Director
3,883
115
If $x,\,y$ are positive integers such that $\dfrac{x^2+y^2}{1+xy}$ is an integer, then $\dfrac{x^2+y^2}{1+xy}$ is a perfect square.
Mathematics news on Phys.org
anemone said:
If $x,\,y$ are positive integers such that $\dfrac{x^2+y^2}{1+xy}$ is an integer, then $\dfrac{x^2+y^2}{1+xy}--(1)$ is a perfect square.
let :$x=\left | k^3 \right |,\,\ y=\left | k\right |$
or: $x=\left | k \right |,\, y=\left | k^3 \right |$
then :$(1)\,\,becomes :\,\, k^2$
where $ k \in Z$
and $k\neq 0$
Thanks for participating, Albert!
But I don't see how we can relate $x$ and $y$ in $k$ in such a manner. Do you mind to explain it for me? Thanks.:)
let :$\dfrac {x^2+y^2}{1+xy}=k^2$
we have:$x^2+y^2=k^2(1+xy)$
$=x^2(1+\dfrac {y^2}{x^2})$
let $x^2=k^2$ then $\dfrac {y^2}{x^2}=xy$
or $y=x^3$
for $x,y \in N$
we get :$x=\left | k \right | $
$y=\left | k^3 \right |$
because of symmetry $x ,\,and,\, y$ are interchangeable
Ah, I see what you meant now, thanks for the response. And thanks again to participating in my challenge.
or $y=x^3$
for $x,y \in N$
by choosing the expression to be $x^2$ we are not considering all possible cases hence the given solution is wrong
Hmm...while I do have a solution that approached the problem quite different than Albert's, I think what Albert did is justifiable. :eek: But I could be wrong.
Do you have something, an example in mind to say that Albert has not included all possible cases in this problem? :)
And welcome back, kaliprasad! I was, initially, afraid you have gotten old of seeing my challenges and your return to MHB makes me very happy!
I have not claimed that other value is possible but without proving that other value is not possible we cannot assume so
Albert has shown that every perfect square can occur as a value of \(\displaystyle \frac{x^2+y^2}{1+xy}.\) That is a neat result. But it does not answer the given problem, which is to show that perfect squares are the only natural numbers that can arise in this way. I have tried hard, without any success, to prove that result, which is in a sense the converse of Albert's result. I should very much like to see a solution of it.
if $\dfrac {x^2+y^2}{1+xy}=m\in N$
we have $x^2-mxy+y^2-m=0---(*)$
consider it as a polynomial respect to x with degree 2
then $x=\dfrac {my\pm \sqrt {m^2y^2-4(y^2-m)}}{2}$
for $x,y\in N$
we obtain $m=y^2$ and $x=my=y^3$
if we took (*) as a polynomial respect to y with degree 2 we have $m=x^2$ and $y=x^3$
for $x,y\in N$
What about the solution $(8, 30)$? In that case we have:
$$\frac{8^2 + 30^2}{1 + 8 \cdot 30} = \frac{964}{241} = 4 = 2^2$$
Yet $8^3 \ne 30$. Below is a dump of all the admissible values of $x$ and $y$, written as $(x, y)$ with $x < y < 1000$:
Code:
(1, 1)
(2, 8)
(3, 27)
(4, 64)
(5, 125)
(6, 216)
(7, 343)
(8, 30)
(8, 512)
(9, 729)
(27, 240)
(30, 112)
(112, 418)
As you can see, most of the pairs here are of the form $(u, u^3)$, but there are four "rogue" pairs that are not of that form. I observe that each positive integer $u$ spawns a unique chain of solutions. And, in fact, starting from any integer $u$ and its associated trivial solution $(u, u^3)$, those chains of solutions obey a simple recurrence of the form:
$$(m, n) \implies (n, u^2 n - m)$$
For instance, taking $u = 2$, we get:
$$(2, 8) \implies (8, 30) \implies (30, 112) \implies (112, 418) \implies (418, 1560) \implies \cdots$$
And note that $2^2 \cdot 8 - 2 = 30$, $2^2 \cdot 30 - 8 = 112$, $2^2 \cdot 112 - 30 = 418$, $2^2 \cdot 418 - 112 = 1560$.
Another example, with $u = 3$, we get:
$$(3, 27) \implies (27, 240) \implies (240, 2133) \implies \cdots$$
And, as expected, $3^2 \cdot 27 - 3 = 240$, $3^2 \cdot 240 - 27 = 2133$.
This, of course, is a strict superset of the solutions given by Albert, and seems to be the dominant structure of the set of solutions. I conjecture that all solutions are of this form (exist in a chain for some $u \in \mathbb{N}$), and will try to find a proof of this. Perhaps an inductive proof might work, after showing that all chains are infinite and disjoint, if they are. I feel that this problem is actually pretty hard, but should we all fail to solve the challenge I look forward to anemone's solution which will without doubt be short and elegant :)
Got it, I think. There are probably a few aspects of the proof that could be clarified or are a bit handwavy, but I think the approach is understandable enough.
First assume $m < n$, without loss of generality, as the only solution of the form $(m, m)$ is $(1, 1)$ since if $1 < m < n$ then $mn < n^2$ hence $m^2 + n^2 \ne 1 + mn$. The other solutions for $m > n$ can be obtained by symmetry. Therefore, suppose we have a solution $(m, n)$ with $1 < m < n$ such that:
$$\frac{m^2 + n^2}{1 + mn} = r > 1 ~ ~ ~ \iff ~ ~ ~ m^2 + n^2 = r(1 + mn)$$
Then it is easy to observe that $(rm - n, m)$ is also a solution, as:
$$(rm - n)^2 + m^2 = r^2 m^2 - 2 r m n + n^2 + m^2 = r(r m^2 - m n + 1) = r((r m - n)m + 1)$$
And $(r m - n)m + 1 \ne 0$ since $r > 1$ and so:
$$\frac{(rm - n)^2 + m^2}{1 + (rm - n)m} = r$$
Thus if we apply this formula repeatedly we can generate a sequence of solutions for which the fraction also equals $r$. We must show that for every solution $(m_k, n_k)$ in the sequence, the property that $0 \leq m_k < n_k$ is maintained. We also prove this by induction, by posing:
$$r = \frac{m^2 + n^2}{1 + mn} = \frac{\frac{m^2}{n} + n}{\frac{1}{n} + m} < \frac{\frac{m^2}{n} + m}{m}$$
Hence:
$$rm < \frac{m^2}{n} + m < n + m$$
Which holds since $m < n$, and therefore:
$$rm - n < m$$
By induction, this holds for every term of the series. Furthermore, the lower bound for $rm - n$ tends to zero as $m$ and $n$ get smaller and thus closer to each other, such that $m_k \geq 0$ in the limit. We have thus shown that the sequence is strictly decreasing, and that we will therefore eventually arrive at a solution of the form $(0, s)$ for some integer $s > 0$. As we have proven, the fraction for this term must equal $r$ too, so:
$$\frac{0^2 + s^2}{1 + 0 \cdot s} = r$$
In other words, $s^2 = r$, and so $r$ was a square.
Interesting and thorough proof,(Yes) thanks Bacterius!
Now it is my turn to show another proof (that I saw somewhere online) here:
Suppose that $\dfrac{x^2+y^2}{1+xy}=k$ is a counterexample of an integer which is not a perfect square, with max $(x,\,y)$ as small as possible. We may assume WLOG that $x<y$ for if $x=y$, then
$0<\dfrac{2x^2}{1+x^2}=k<2$ which forces $k=1$, a perfect square.
Now, $x^2+y^2-k(1+xy)=0$ is a quadratic in $y$, $y^2-kxy+x^2-k=0$. Let $y_1,\,y$ be its roots, so $y_1+y=kx$ and $y_1y=x^2-k$.
As $x,\,k$ are positive integers, suppose $y_1<0$ is incompatible with $x^2+y_1^2=k(1+xy_1)$. As $k$ is not a perfect square, suppose $y_1=0$ is incompatible with $x^2+0=k(1+0\cdot x)$.
Also, $y_1=\dfrac{x^2-k}{y}<\dfrac{y^2-k}{y}<y$
Thus, we have found another positive integer $y_1$ for which $\dfrac{x^2+y_1^2}{1+xy_1}=k$ and which is smaller than the smallest max $(x,\,y)$. This is a contradiction.
It must be the case, then, that $k$ is a perfect square.
FAQ: Prove a fraction is a perfect square
What is a perfect square?
A perfect square is a number that can be expressed as the product of two equal integers. For example, 9 is a perfect square because it can be expressed as 3*3.
How can I prove that a fraction is a perfect square?
To prove that a fraction is a perfect square, you can simplify it to its lowest terms and check if both the numerator and denominator are perfect squares. If they are, then the fraction is a perfect square.
Can a fraction be a perfect square if it has a decimal representation?
No, a fraction cannot be a perfect square if it has a decimal representation. A perfect square must have two equal integer factors, and a decimal representation indicates that the fraction cannot be simplified to two integers.
What is the difference between a square number and a perfect square?
A square number is any number that is the result of multiplying an integer by itself. A perfect square is a special type of square number where both the square root and the number itself are integers.
Can a negative fraction be a perfect square?
No, a negative fraction cannot be a perfect square. Perfect squares are always positive numbers because when we take the square root of a number, we are looking for the positive value that was squared to get that number.
