Is the Function \( f(x,y) \) Continuous on \( \mathbb{R}^2 \)?
  • MHB
  • Thread starter i_a_n
  • Tags
    Function
In summary, the function is continuous on the domain and this is proved by showing that for all points within the domain, the function is continuous by showing that for all points within the domain, the function is continuous using the $\delta- \varepsilon$ way.
i_a_n
83
Prove that
$f(x,y)=\left\{\begin{matrix}
e^{-1/|x-y|},x\neq y\\
0,x=y
\end{matrix}\right.$
is continuous on $\mathbb{R}^2$.
Can I conclude since $e^{-1/t}$ is continuous then for $x$,$y\in \mathbb{R}^2$, $x\neq y$,$e^{-1/|x-y|}$ is continuous on $\mathbb{R}^2$ since here $t=|x-y|$? And how to prove it when $x=y$, using the $\delta- \varepsilon$ way? Thank you a lot!
Re: Prove a function is continuous
We have to show that the function is continuous at each point of $\Bbb R^2$. Your argument threats the case of points of the form $(x,y),x\neq y$. So now, fix $x_0$. We have to show that $\lim_{(x,y)\to (x_0,x_0)}=0$.
Hint: use $e^{-u}\leqslant \frac 1{1+u}$ for each non-negative real number $u$.
girdav said:
Hint: use $e^{-u}\leqslant \frac 1{1+u}$ for each real number $u$.
Surely is a typo, I suppose you meant for each real number $u$ close to $0$.
Another way: denoting $\Delta=\{(t,t):t\in\mathbb{R}\}$ (diagonal of $\mathbb{R}^2$), in a neighborhood $V$ of $(0,0)$ we have:
$\displaystyle\lim_{(x,y)\to (x_0,x_0)\;,\;(x,y)\in V-\Delta}f(x,y)=\displaystyle\lim_{(x,y)\to (x_0,x_0)\;,\;(x,y)\in V-\Delta}e^{-\dfrac{1}{|x-y|}}=e^{-\infty}=0$
$\displaystyle\lim_{(x,y)\to (x_0,x_0)\;,\;(x,y)\in V\cap\Delta}f(x,y)=\displaystyle\lim_{(x,y)\to (x_0,x_0)\;,\;(x,y)\in V\cap\Delta}0=0$
In a finite partition of $V$ all the limits coincide, so $\displaystyle\lim_{(x,y)\to (x_0,x_0)}f(x,y)=0$ .
The definition of continuity for a function is {lim x-> a} f(x) = f(a). For this function we only need to worry about when |x - y| -> 0, since the exponential function is continuous everywhere. So in other words we need to show that
{lim |x - y|-> 0} f(x,y) = f(x,x) = f(y,y)
Now f(x,x) = f(y,y) = 0 so we just need to show that
{lim |x - y| -> 0} f(x,y) = 0.
Since |x - y| > 0, -1/|x - y| -> infinity so f(x,y) -> 0 and we're done.Is a proof like this correct?
Yes, you can conclude that $e^{-1/t}$ being continuous implies that $e^{-1/|x-y|}$ is continuous for $x,y \in \mathbb{R}^2$, $x \neq y$. This is because the function $e^{-1/|x-y|}$ is a composition of two continuous functions: the absolute value function $|x-y|$ and the exponential function $e^{-t}$.
To prove that $f(x,y)$ is continuous at points where $x=y$, we can use the $\delta-\varepsilon$ definition of continuity. Let $(x_0,y_0)$ be a point in $\mathbb{R}^2$ where $x_0=y_0$. We want to show that for any $\varepsilon > 0$, there exists a $\delta > 0$ such that for all points $(x,y)$ in the domain of $f$ satisfying $|x-x_0|<\delta$ and $|y-y_0|<\delta$, we have $|f(x,y)-f(x_0,y_0)|<\varepsilon$.
Since $x=y$ at $(x_0,y_0)$, we have $|x-y| = |x_0-y_0| = 0$. This means that $e^{-1/|x-y|} = e^{-1/0}$, which is undefined. However, we can see that as $|x-y|$ approaches 0, the function $e^{-1/|x-y|}$ approaches the limit $e^{-1/0} = e^{-\infty} = 0$. This can be verified by taking the limit as $|x-y|$ approaches 0:
$$\lim_{|x-y|\to 0} e^{-1/|x-y|} = e^{-1/\lim_{|x-y|\to 0}|x-y|} = e^{-1/0} = e^{-\infty} = 0$$
Therefore, for any $\varepsilon > 0$, we can choose $\delta = \frac{1}{-\ln(\varepsilon)}$ (note that this is a positive number since $\varepsilon < 1$) and we have:
$$|f(x,y)-f(x_0,y_0)| = |
FAQ: Is the Function \( f(x,y) \) Continuous on \( \mathbb{R}^2 \)?
What does it mean for a function to be continuous?
A function is continuous if there are no abrupt changes or breaks in its graph. This means that the function can be drawn without lifting your pencil from the paper.
How do you prove that a function is continuous?
To prove that a function is continuous, you need to show that the limit of the function at a point is equal to the value of the function at that point. This can be done using the epsilon-delta definition of continuity or by showing that the function satisfies the three conditions of continuity: the function is defined at the point, the limit exists, and the limit is equal to the value of the function at that point.
What is the epsilon-delta definition of continuity?
The epsilon-delta definition of continuity states that a function f is continuous at a point x = a if for any positive number ε, there exists a positive number δ such that for all x within δ of a, the value of f(x) is within ε of f(a).
Can a function be continuous at a point but not on an interval?
Yes, a function can be continuous at a point but not on an interval. This means that the function satisfies the conditions of continuity at that point, but may have breaks or abrupt changes on other points within the interval.
Are all continuous functions differentiable?
No, not all continuous functions are differentiable. A function can be continuous but not differentiable at points where there are sharp turns or corners in the graph. In order for a function to be differentiable, it must be continuous and have a well-defined derivative at each point within its domain.
