MHB Prove a number is divisible by 2^{2008}
  • Thread starter Thread starter anemone
The number \(1+\left\lfloor(\sqrt{17}+5)^{2008}\right\rfloor\) is shown to be divisible by \(2^{2008}\) through a recursive relationship involving the roots \(\alpha = 5 + \sqrt{17}\) and \(\beta = 5 - \sqrt{17}\). The sequence \(S_n = \alpha^n + \beta^n\) is established, which satisfies the recurrence relation \(S_{n+2} - 10S_{n+1} + 8S_n = 0\). An induction argument confirms that \(S_n\) is an integer and can be expressed as \(S_n = \lfloor\alpha^n\rfloor + 1\). Further, it is proven that \(S_n\) is a multiple of \(2^n\), leading to the conclusion that \(S_{2008}\) is a multiple of \(2^{2008}\). Thus, the original expression is indeed divisible by \(2^{2008}\).
anemone
MHB
POTW Director
Prove that the number $1+\left\lfloor{}\right(\sqrt{17}+5)^{2008} \rfloor$ is divisible by $2^{2008}$.
Mathematics news on Phys.org
we have
$(\sqrt{17}+5)^{2008}+ (5-\sqrt{17})^{2008}$
is integer and $(5-\sqrt{17}) $ is less than 1 so
given expression is
if we get x = $(5+\sqrt{17}) $
as $(5+\sqrt{17})(5-\sqrt{17}) = 8$
then given expression is
$(x)^{2008} + (\frac{8}{x})^{2008}$
we have $x + \frac{8}{x}=10$
we shall now show it by induction that
$x^{n} + (\frac{8}{x})^{n}$
is divisible by $2^{n}$
for n =1 it is true as it is 10
for n =2
it is $x^{2}+(\frac{8}{x})^2 =(x+(\frac{8}{x}))^2-2 * 8 = 10^2 - 16 = 84 $ divisible by 4
for n = 3
it is $x^{3}+(\frac{8}{x})^3 =(x+(\frac{8}{x}))^3-3 * 8 * (x + \frac{8}{x}) = 10^3- 3 *8 * 10 = 760 $ divisible by 8
so it is true for n = 1,2, 3
not we go for induction step
$(x^{n}+(\frac{8}{x})^n)(x+\frac{8}{x})= (x^{n+1} + (\frac{8}{x})^{n+1}) + 8(x^{n-1} + (\frac{8}{x})^{n-1}) $
hence
$x^{n+1}+(\frac{8}{x})^{n+1}= (x+\frac{8}{x})(x^{n} + (\frac{8}{x})^{n}) - 8(x^{n-1} + (\frac{8}{x})^{n-1}) $
or $x^{n+1}+(\frac{8}{x})^{n+1}= (x+\frac{8}{x})(x^{n} + (\frac{8}{x})^{n}) -2^3(x^{n-1} + (\frac{8}{x})^{n-1}) $
now if $x^{n}+(\frac{8}{x})^{n}$ is divsible by $2^n$
then it is easy to see that 1st term of RHS is disvisible by $2^{n+1}$ and 2nd by $2^{n+2}$ and hence LHS is divsible by $2^{n+1}$
so induction step is proved and hence given expression is divisible by $2^{2008}$
My solution is similar to kaliprasad's.
[sp]Let $\alpha = 5 + \sqrt{17}$, $\beta = 5 - \sqrt{17}$. Then $\alpha + \beta = 10$, $\alpha\beta = 8$, and so $\alpha$ and $\beta$ are the roots of the equation $x^2 - 10x + 8 = 0.$ Then $x^{n+2} - 10x^{n+1} + 8x^n = 0$ (for all $n\geqslant0$).
Let $S_n = \alpha^n + \beta^n$. Then $\alpha^{n+2} - 10\alpha^{n+1} + 8\alpha^n = 0$ and $\beta^{n+2} - 10\beta^{n+1} + 8\beta^n = 0$, so by addition $S_{n+2} - 10S_{n+1} + 8S_n = 0$. It follows by an easy induction argument that $S_n$ is an integer. Since $0<\beta^n < 1$ it then follows that $S_n = \lfloor\alpha^n \rfloor + 1.$
It remains to prove by induction that $S_n$ is a multiple of $2^n$, say $S_n = 2^nT_n$ for some integer $T_n$. Since $S_0 = 2$ and $S_1= 10$, this holds for $n=0$ and $n=1$. Assume that the result is true for $n$ and $n+1$. Then $S_{n+2} = 10S_{n+1} - 8S_n = 10(2^{n+1}T_{n+1}) - 8(2^nT_n) = 2^{n+2}(5T_{n+1} - 2T_n),$ which is a multiple of $2^{n+2}$ as required.[/sp]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
