Prove a triangle is equilateral
  • MHB
  • Thread starter anemone
  • Tags
    Triangle
In summary, the conversation discusses a challenge problem involving a triangle with sides $a,\,b,\,c$ and opposite angles $A,\,B,\,C$. The goal is to show that if $ab^2\cos A=bc^2\cos B=ca^2\cos C$, then the triangle is equilateral. While waiting for a solution, a hint is given to solve the problem using an elementary method. Another participant mentions using linear algebra, but realizes that an analytical approach is just as effective.
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c$ be the sides and $A,\,B,\,C$ be the opposite angles angles of a triangle.
Show that if $ab^2\cos A=bc^2\cos B=ca^2\cos C$ then the triangle is equilateral.
Mathematics news on Phys.org
Let's try.
From the equalitys we got \(\displaystyle \left\{\begin{array}{c}ab cos A - c^2cos B = 0 \\ b^2 cos A - ac cos C =0 \\ cbcos B-a^2cos C=0 \end{array}\right.\).
Given any constants, \(\displaystyle a, b, c>0\) we can consider the matrix \(\displaystyle M=\left(\begin{array}{ccc}ab & -c^2 & 0\\
b^2 & 0 & -ac \\ 0 & cb & -a^2\end{array}\right)\)
Then \(\displaystyle rank(M)=2\) and it's easy to see that \(\displaystyle kernel(M)=<(1,1,1)>\) and any solution of \(\displaystyle Mx=0\) should be in the kernel.
Hence, \(\displaystyle cos \ A= cos \ B= cos \ C\) and the triangle is equilateral.
Wait, this is not correct, mixed two different things over the paper, i will try to fix it.
Fallen Angel said:
Let's try.
Hi Fallen Angel,
Let me first thank you for participating in this challenge of mine!:)
But, I must tell you that I am out of my depth in linear algebra and hence, I might not be available to comment on your solution.:(
While we're still waiting for Fallen Angel's second submission to this challenge problem:eek:, I would like to reveal a hint to solve for it using elementary way:
Relate the given equality with the Law of Cosines.
Hi,
Sorry, at first I thought that working with linear algebra would give a pretty solution, but now I see it's essentially the same than doing it analitically but in a longer way.
$$\cos A=\frac{b^2+c^2-a^2}{2bc}$$$$\cos B=\frac{a^2+c^2-b^2}{2ac}$$$$\cos C=\frac{a^2+b^2-c^2}{2ab}$$$$ab^2\cos A=\frac{abc}{2}+\frac{ab^3}{2c}-\frac{a^3b}{2c}$$$$bc^2\cos B=\frac{abc}{2}+\frac{bc^3}{2a}-\frac{b^3c}{2a}$$$$a^2c\cos C=\frac{abc}{2}+\frac{a^3c}{2b}-\frac{ac^3}{2b}$$Hence we have$$\frac{ab}{2c}(b^2-a^2)=\frac{bc}{2a}(c^2-b^2)=\frac{ac}{2b}(a^2-c^2)$$For an equilateral triangle, equality holds.$$\text{ }$$For a triangle with $a>b=c$, the middle term is zero and the other two terms are non-zero, so equality does not hold.$$\text{ }$$For a triangle with $a>b>c$, the first term is negative and the third term is positive, so equality does not hold.$$\text{ }$$Thus, equality only holds if $a=b=c$, i.e. if triangle $ABC$ is equilateral.
Hi greg1313! Thanks for participating and your solution is correct! Well done!:)
Or we could also prove it using the method below:
$\dfrac{ab(bc\cos A)}{c}=\dfrac{bc(ac\cos B)}{a}=\dfrac{ac(ba\cos C)}{b}$
$\dfrac{ab(b^2+c^2-a^2)}{2c}=\dfrac{bc(c^2+a^2-b^2)}{2a}=\dfrac{ac(a^2+b^2-c^2)}{2b}$
$\dfrac{b^2+c^2-a^2}{c^2}=\dfrac{c^2+a^2-b^2}{a^2}=\dfrac{a^2+b^2-c^2}{b^2}$
Therefore we get
$a^2b^2+a^2c^2-a^4=c^4+a^2c^2-b^2c^2\implies a^2b^2+b^2c^2=a^4+c^4$---(1)
$b^2c^2+a^2b^2-b^4=a^4+a^2b^2-a^2c^2\implies b^2c^2+a^2c^2=a^4+b^4$---(2)
$a^2c^2+b^2c^2-c^4=b^4+b^2c^2-a^2b^2\implies a^2c^2+a^2b^2=b^4+c^4$---(3)
Adding the equations (1), (2) and (3) up yield $2a^2b^2+2a^2c^2+2+b^2c^2=2a^4+2b^4+2c^4$
Equivalently $(a^2-b^2)^2+(b^2-c^2)^2+(c^2-a^2)^2=0$
So it must be $a^2=b^2=c^2$ and $a=b=c$.
FAQ: Prove a triangle is equilateral
How do you prove a triangle is equilateral?
To prove a triangle is equilateral, you must show that all three sides of the triangle are equal in length. This can be done by measuring the lengths of each side and comparing them to each other.
What are the properties of an equilateral triangle?
An equilateral triangle has three equal sides and three equal angles, each measuring 60 degrees. It also has three lines of symmetry, meaning it can be folded into three equal parts.
Can a triangle be equilateral if it has a right angle?
No, a right angle triangle cannot be equilateral. An equilateral triangle must have three equal angles, but a right angle triangle has one angle measuring 90 degrees, making it impossible for the other two angles to also measure 60 degrees.
Is it enough to prove two sides of a triangle are equal to prove it is equilateral?
No, proving two sides are equal is not enough to prove a triangle is equilateral. In addition to having three equal sides, an equilateral triangle also has three equal angles.
Are there any special formulas or theorems to prove a triangle is equilateral?
Yes, there are several theorems and formulas that can be used to prove a triangle is equilateral. These include the Angle Bisector Theorem, the Pythagorean Theorem, and the Law of Cosines. However, these methods may not be applicable in all cases, so it is important to understand the properties of an equilateral triangle and use them in combination with these theorems.
