Prove: All Derivatives of f at 0 = 0 if Lim f(x)/x^n = 0 as x --> 0
  • Thread starter Thread starter stukbv
    Derivatives
The discussion centers on proving that all derivatives of a function f at 0 equal 0 if the limit of f(x)/x^n approaches 0 as x approaches 0, given that f is infinitely continuously differentiable and f(0) = 0. Participants consider using induction but suggest that the Taylor expansion might be a more effective method for the proof. There is a consensus that while induction can work, it may complicate the process. The Taylor expansion approach is recommended to help evaluate the limit more clearly. Overall, the conversation emphasizes the importance of choosing the right mathematical strategy for the proof.
stukbv
if f is infinitely continuously differentiable and f(0) = 0 then prove that all derivatives of f at 0 are 0 iff lim f(x)/x^n = 0 as x --> 0
I didnt know whether to use induction on this,
I tried a base case so said that f'(0)=0 iff lim (f(x)/x) = 0 as x--> 0
But then it gets messy..
Think i might be on the wrong lines.
Thanks a lot
Yes, induction should be the way to go here. Did you already prove the base case? It shouldn't be too hard...
I don't think induction is the best approach. Try using the Taylor expansion of f instead.
EDIT: never mind, induction also works.
If you do Taylor expansion then you necessarily need to do induction. Note that f doesn't necessarily equal it's Taylor series!
Yeah i can do the base case and that's all proved etc but then i get stuck
For the induction hypothesis, try to calculate
\frac{f(x)}{x^n}
by taking the Taylor expansion at 0. This will help you to evaluate the limit.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
