MHB Prove an expression is rational
The discussion focuses on proving that the expression $\sqrt{(c−3)(c+1)}$ is rational under the condition that $a, b, c$ are rational numbers with non-zero sums $a+bc$, $b+ac$, and $a+b$. The proof begins by manipulating the given equality $\dfrac{1}{a+bc} = \dfrac{1}{a+b} - \dfrac{1}{b+ac}$ to derive a relationship between $a$, $b$, and $c$. It shows that $ab = \left(\dfrac{a+b}{c-1}\right)^2$, leading to $\sqrt{ab} = \left|\dfrac{a+b}{c-1}\right|$, which is rational. Finally, it concludes that $(c-3)(c+1)$ can be expressed as $\dfrac{(a-b)^2}{ab}$, confirming that $\sqrt{(c-3)(c+1)}$ is indeed rational.
anemone
MHB
POTW Director
The rational numbers $a,\,b,\,c$ (for which $a+bc$, $b+ac$ and $a+b$ are all non-zero) satisfy the equality $\dfrac{1}{a+bc} =\dfrac{1}{a+b}-\dfrac{1}{b+ac}$.
Prove that $\sqrt{(c−3)(c+1)}$ is rational.
Mathematics news on Phys.org
[sp]Write it as $\dfrac{1}{a+b} = \dfrac{1}{a+bc} + \dfrac{1}{b+ac} = \dfrac{(a+b)(1+c)}{(a+bc)(b+ac)}$. Then $$(a+b)^2(1+c) = (a+bc)(b+ac) = ab(1+c^2) + (a^2+b^2)c,$$ $$(a+b)^2 + 2abc = ab(1+c^2),$$ $$(a+b)^2 = ab(c-1)^2.$$ This shows that $ab = \Bigl(\dfrac{a+b}{c-1}\Bigr)^2$. In other words, $\sqrt{ab} = \Bigl|\dfrac{a+b}{c-1}\Bigr|,$ which is rational.
Also, $c-1 = \dfrac{\pm(a+b)}{\sqrt{ab}}$, so that $c-3 = \dfrac{\pm(a+b)}{\sqrt{ab}} - 2 = \dfrac{\pm(a+b) - 2\sqrt{ab}}{\sqrt{ab}}$, and $c+1 = \dfrac{\pm(a+b)}{\sqrt{ab}} + 2 = \dfrac{\pm(a+b) + 2\sqrt{ab}}{\sqrt{ab}}.$
Therefore $(c-3)(c+1) = \dfrac{(a+b)^2 - 4ab}{ab} = \dfrac{(a-b)^2}{ab}$, from which $\sqrt{(c-3)(c+1)} = \dfrac{|\,a-b\,|}{\sqrt{ab}}$, which is rational.[/sp]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
