MHB Prove by induction that the function is injective
The discussion revolves around proving that the function F: {0,1}^ω → ℝ, defined by F((a_n)_{n ∈ ω}) = ∑(2a_n/3^(n+1)), is injective. The proof uses induction to show that if F((a_n)_{n ∈ ω}) = F((b_n)_{n ∈ ω}), then the sequences (a_n) and (b_n) must be identical. It concludes that if ℝ were countable, it would imply that {0,1}^ω is also countable, leading to a contradiction. Thus, the injectivity of F supports the assertion that ℝ is uncountable. The argument effectively demonstrates the relationship between the injective function and the cardinality of the sets involved.
evinda
MHB
Hi! (Wave)
The set $\mathbb{R}$ of real numbers is not countable.
Proof:
We define the function $F: \{0,1\}^{\omega} \to \mathbb{R}$ with the formula:
$$(a_n)_{n \in \omega} \in \{0,1\}^{\omega} \mapsto F((a_n)_{n \in \omega})=\sum_{n=0}^{\infty} \frac{2a_n}{3^{n+1}}$$
Show that $F$ is 1-1 and thus if $\mathbb{R}$ is countable then the set $\{0,1\}^{\omega}$ would also be, that is a contradiction.So we pick $(a_n)_{n \in \omega}, (b_n)_{n \in \omega} \in \{0,1\}^{\omega}$ with $F((a_n)_{n \in \omega})=F((b_n)_{n \in \omega}) \Rightarrow \sum_{n=0}^{\infty} \frac{2a_n}{3^{n+1}}=\sum_{n=0}^{\infty} \frac{2b_n}{3^{n+1}}$We will show that it holds using induction.At the base case, we assume that $a_0 \neq b_0$, let $a_0=0, b_0=1$.
So we have $\sum_{n=1}^{\infty} \frac{2a_n}{3^{n+1}}=\frac{2}{3}+\sum_{n=1}^{\infty} \frac{2b_n}{3^{n+1}}$
How could we find a contradiction? (Thinking)
Here's a proof that your function is injective:
I see.. (Nod)
Like that we have shown that the function $F: \{ 0,1 \}^{\omega} \to \mathbb{R}$ with the formula $(a_n)_{n \in \omega} \in \{0,1\}^{\omega} \mapsto F((a_n)_{n \in \omega})=\sum_{n=0}^{\infty} \frac{2a_n}{3^{n+1}}$ is injective.
Now we suppose that $\mathbb{R}$ is countable. That means that there is an injective function $g: \mathbb{R} \to \omega$.
Since $F: \{ 0,1 \}^{\omega} \to \mathbb{R}$ is injective, do we deduce that $g \circ F: \{0,1\}^{\omega} \to \omega$ is injective, that is a contradiction since then that would mean that $\{0,1\}^{\omega}$ is countable, i.e. that $\{0,1\}^{\omega} \sim \omega$ ? (Thinking)
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
