Prove Continuity of f(x+y) = f(x) + f(y)
Can you use this to prove continuity at b?In summary, the problem states that if f(x+y) = f(x) + f(y) for all x,y∈ℝ and f is continuous at a point a∈ℝ, then f is continuous for all b∈ℝ. To prove this, you can use either the definition of a limit or the property given in the problem. You can also let x be equal to a in your proof. Another way to define continuity is by using the limit as h approaches 0. You can use this definition to prove continuity at b.
strahi
f(x+y) = f(x) + f(y) for all x,y∈ℝ if f is continuous at a point a∈ℝ then prove that f is continuous for all b∈ℝ.
lim{x->a}f(x) = f(a)
I do not understand how to prove the continuity, does f(x) = f(a) or does f(x+y) = f(a)
Write down what you need to prove for the continuity at b. See if you can simplify it using the property of f that is given. Then see if you can rewrite it with a and use the continuity at a.
if it is continuous at b then lim{x->b)f(x) = f(b) right?
Yes, that is one way to say it; but it is not the only way, and maybe not even the most useful way in this particular problem.
sequential characterization then, or the proper definition of a limit?
Put that in the ε, δ form of the definition of a limit.
It would help us as readers and you for understanding, if you used some punctuation and clarifying words.
In this problem it's given that f(x + y) = f(x) + f(y). It is also assumed that f is continuous at a real number a. You need to show (prove) that f is continuous at an real number b.
You can let x be a, your call.
Another way that continuity is defined is this: ##\lim_{h \to 0} f(a + h) = f(a)##.
Likes FactChecker
Related to Prove Continuity of f(x+y) = f(x) + f(y)
What is continuity?
Continuity is a mathematical concept that describes the smoothness and connectedness of a function. A function is continuous if its output value changes continuously as its input value changes.
What does it mean to prove continuity of a function?
To prove continuity of a function, we must show that the function satisfies the definition of continuity. This means that the function is defined at a particular point, the limit of the function exists at that point, and the limit is equal to the value of the function at that point.
How do you prove continuity of a function?
To prove continuity of a function, we must use the definition of continuity and show that the limit of the function at a particular point is equal to the value of the function at that point. This can be done using various techniques such as the epsilon-delta method or the sequential approach.
What is the importance of proving continuity of a function?
Proving continuity is important because it allows us to determine the behavior of a function at a certain point and its surrounding points. It also enables us to make predictions and solve problems involving the function.
Can you prove continuity of a function at every point?
In some cases, it is possible to prove continuity of a function at every point. However, there are certain functions, such as discontinuous or piecewise functions, that may not be continuous at every point. In these cases, we can still determine the continuity of the function at specific points using the definition of continuity.
