Prove Divergent Series of Positive Sequence | MathHelpForum.com
In summary, the conversation on mathhelpforum.com is discussing a problem involving a positive sequence $\{x_n\}$ with a limit of infinity and proving the divergence of the series $\sum_{n=1}^\infty (1-\frac{x_n}{x_{n+1}})$. The proposed solution uses the converse theorem and the concept of a "telescopic" product to show that the series diverges. However, it may be beneficial to provide additional explanations for the use of the converse theorem and the simplification of the product.
chisigma
MHB
1,628
From mathhelpforum.com...
A constructive divergent series
Let $\displaystyle \{x_{n}\}$ be a positive sequence satisfying $\lim_{\ n \rightarrow \infty} x_{n}= \infty$ Prove that the series $\displaystyle \sum_{n=1}^{\infty} (1-\frac{x_{n}}{x_{n+1}})$ is divergent.
Till now no answers have been given. The solution I propose involves an 'infinite product'. It is well known the theorem that establish that the 'infinite product' $\displaystyle \prod_{n=1}^{\infty} (1-a_{n})$ diverges if the 'infinite sum' $\displaystyle \sum_{n=1}^{\infty} a_{n}$ diverges. Less known but equally valid is the converse theorem that establishes that the 'infinite sum' $\displaystyle \sum_{n=1}^{\infty} a_{n}$ where $\displaystyle 0<a_{n}<1$ diverges if the 'infinite product' $\displaystyle \prod_{n=1}^{\infty} (1-a_{n})$ diverges to 0 as You can see here...
http://en.wikipedia.org/wiki/Convergence_tests
Applying the converse theorem and setting $\displaystyle a_{n}= 1- \frac{x_{n}}{x_{n+1}}$ we obtain that...
$\displaystyle \prod_{n=1}^{\infty} (1-a_{n}) = \prod_{n=1}^{\infty} \frac{x_{n}}{x_{n+1}}= \frac{x_{1}}{x_{2}}\ \frac{x_{2}}{x_{3}}\ ...$ (1)
Now the product (1) is 'telescopic' and is...
$\displaystyle p_{k}= \prod_{n=1}^{k} \frac{x_{n}}{x_{n+1}}= \frac{x_{1}}{x_{k+1}}$ (2)
... and, because is $\displaystyle \lim_{\ k \rightarrow \infty} x_{k+1}=\infty$ is also $\displaystyle \lim_{\ k \rightarrow \infty} p_{k}=0$, the product (1) diverges and for the converse theorem the series $\displaystyle \sum_{n=1}^{\infty} (1-\frac{x_{n}}{x_{n+1}})$ diverges...
Kind regards
$\chi$ $\sigma$
Dear $\chi$ $\sigma$,
Thank you for sharing your solution to this problem. It is always interesting to see different approaches to solving mathematical problems. I would like to add some additional thoughts to your solution.
Firstly, your use of the converse theorem is a valid approach to proving the divergence of this series. However, it may not be immediately obvious to everyone how the converse theorem applies in this situation. It may be helpful to provide a brief explanation or proof of the converse theorem for those who may not be familiar with it.
Secondly, while your solution is correct, it may be helpful to provide some additional justification for your statement that the product (1) is "telescopic." This term may not be familiar to all readers and it would be beneficial to explain how the product simplifies to $\frac{x_1}{x_{k+1}}$.
Overall, your solution is well-written and provides a clear and concise explanation for the convergence of the series. Thank you for contributing to the discussion on this problem.
FAQ: Prove Divergent Series of Positive Sequence | MathHelpForum.com
What is a divergent series?
A divergent series is a mathematical sequence in which the terms continue to increase or decrease without approaching a finite limit. This means that the sum of all the terms in the series will either increase or decrease without ever reaching a specific value.
How can you prove that a series is divergent?
To prove that a series is divergent, you can use several different methods such as the comparison test, the ratio test, or the integral test. These methods involve comparing the given series to another known divergent series or using calculus techniques to determine the behavior of the series.
What is a positive sequence?
A positive sequence is a sequence in which all of the terms are greater than or equal to zero. This means that the terms in the sequence are always positive numbers or zero, and they do not become negative at any point.
Can a series with positive terms be both convergent and divergent?
No, a series with positive terms cannot be both convergent and divergent. The terms in a series must either approach a finite limit or continue to increase or decrease without reaching a specific value. If the terms are positive, they cannot approach a negative value, so the series cannot be convergent.
How is the divergence of a series related to its terms?
The divergence of a series is related to its terms because the behavior of the terms determines whether the series will be convergent or divergent. If the terms continue to increase or decrease without approaching a finite limit, the series will be divergent. If the terms approach a specific value, the series will be convergent.
