Prove Divisibility of $a^3+b^3+c^3$ Using $(a-b)^2+(b-c)^2+(c-a)^2=abc$
In summary, the formula for proving divisibility of $a^3+b^3+c^3$ using $(a-b)^2+(b-c)^2+(c-a)^2=abc$ states that if $a$, $b$, and $c$ are integers, then the expression $(a-b)^2+(b-c)^2+(c-a)^2$ must be divisible by $abc$. This formula is derived from the expansion of $(a+b+c)^3$ and plays a crucial role in proving divisibility. It can also be used to prove the divisibility of other expressions as long as they can be manipulated into a form that is divisible by $abc$. Additionally, the formula has a geometric interpretation as the sum of
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c$ be integers such that $(a-b)^2+(b-c)^2+(c-a)^2=abc$. Prove that $a^3+b^3+c^3$ is divisible by $a+b+c+6$.
Mathematics news on Phys.org
we have $a^3+b^3+c^3-3abc$
=$\dfrac{1}{2}(a+b+c)(a^2+b^2+c^2 - ab - bc- ca)$
= $\dfrac{1}{2}(a+b+c)(2a^2+2b^2+2c^2 - 2ab - 2bc- 2ca)$
= $\dfrac{1}{2}(a+b+c)((a-b)^2 + (b-c)^2+ (c-a)^2)$
=$\dfrac{1}{2}(a+b+c)(abc)$
hence
$a^3+b^3+c^3 = \dfrac{1}{2}(a+b+c+6)(abc)$
now $(a+b+c+6)$ is a factor if $\dfrac{abc}{2}$ is integer
or atleast one of a,b,c is even.
all a,b,c cannot be odd then in the given condion
$(a-b)^2 + (b-c)^2 + (c-a)^2$ shall be even and abc shall be odd . so atleast one of a,b,c is even and so $\dfrac{abc}{2}$ is integer and hence given expression is divisible by $(a+b+c+6)$
FAQ: Prove Divisibility of $a^3+b^3+c^3$ Using $(a-b)^2+(b-c)^2+(c-a)^2=abc$
What is the formula for proving divisibility of $a^3+b^3+c^3$ using $(a-b)^2+(b-c)^2+(c-a)^2=abc$?
The formula for proving divisibility of $a^3+b^3+c^3$ using $(a-b)^2+(b-c)^2+(c-a)^2=abc$ is as follows: If $a$, $b$, and $c$ are integers, then $(a-b)^2+(b-c)^2+(c-a)^2$ must be divisible by $abc$.
How does the formula $(a-b)^2+(b-c)^2+(c-a)^2$ help prove divisibility of $a^3+b^3+c^3$?
The formula $(a-b)^2+(b-c)^2+(c-a)^2$ is derived from the expansion of $(a+b+c)^3$. It helps to simplify and manipulate the expression $a^3+b^3+c^3$ into a form that is easily divisible by $abc$.
What is the significance of the expression $(a-b)^2+(b-c)^2+(c-a)^2$ in the proof of divisibility of $a^3+b^3+c^3$?
The expression $(a-b)^2+(b-c)^2+(c-a)^2$ represents the sum of squares of the differences between any two of the three integers $a$, $b$, and $c$. This expression plays a crucial role in proving the divisibility of $a^3+b^3+c^3$ by $abc$.
Can the formula $(a-b)^2+(b-c)^2+(c-a)^2=abc$ be used to prove divisibility of other expressions?
Yes, the formula $(a-b)^2+(b-c)^2+(c-a)^2=abc$ can be used to prove the divisibility of other expressions, as long as those expressions can be manipulated into a form that is divisible by $abc$.
Is there a geometric interpretation of the formula $(a-b)^2+(b-c)^2+(c-a)^2$ in relation to proving divisibility?
Yes, the formula $(a-b)^2+(b-c)^2+(c-a)^2$ can be interpreted geometrically as the sum of the squares of the lengths of the three sides of a triangle with side lengths $a-b$, $b-c$, and $c-a$. This can help visualize and understand the proof of divisibility of $a^3+b^3+c^3$ using $(a-b)^2+(b-c)^2+(c-a)^2=abc$.
