MHB Prove Existence of $n$ for Integer $\sqrt{n^3+xn^2+yn+z}$
  • Thread starter Thread starter anemone
    Challenge Integer
For any integers x, y, and z, it can be proven that there exists a positive integer n such that the expression √(n^3 + xn^2 + yn + z) is not an integer. The discussion highlights that modular arithmetic can be utilized to demonstrate this property effectively. Participants explore various approaches and examples to illustrate the existence of such an n. The consensus is that the proof hinges on specific modular conditions that lead to non-integer results. Overall, the thread emphasizes the role of modular arithmetic in solving this problem.
anemone
MHB
POTW Director
Prove that for any integers $x,\,y,\,z$, there exists a positive integers $n$ such that $\sqrt{n^3+xn^2+yn+z}$ is not an integer.
Mathematics news on Phys.org
Solution of other:
Let $f(n)=n^3+xn^2+yn+z$. Find an integer $a$ large enough that $8a^3$ exceeds both $(x^2-4y)a^2-xa-z+\dfrac{1}{4}$ and $(4y-x^2)a^2-xa+z-\dfrac{1}{4}$, i.e.
$\begin{align*}f(4a^2)&=(4a^2)^3+x(4a^2)^2+y(4a^2)+z\\&=64a^6+16a^4x+4a^2y+z\end{align*}$
$\begin{align*}\left(8a^3+xa-\dfrac{1}{2}\right)^2&=64a^6+16a^3\left(xa-\dfrac{1}{2}\right)+x^2a^2-xa+\dfrac{1}{4}\\&=64a^6+16a^4x-8a^3+x^2a^2-xa+\dfrac{1}{4}\end{align*}$
$\begin{align*}\left(8a^3+xa+\dfrac{1}{2}\right)^2&=64a^6+16a^3\left(xa+\dfrac{1}{2}\right)+x^2a^2+xa+\dfrac{1}{4}\\&=64a^6+16a^4x+8a^3+x^2a^2+xa+\dfrac{1}{4}\end{align*}$
and
$-8a^3+x^2a^2-xa+\dfrac{1}{4}<4a^2y+z$ which gives $(x^2-4y)a^2-xa-z+\dfrac{1}{4}<8a^3$
whereas
$8a^3+x^2a^2+xa+\dfrac{1}{4}>4a^2y+z$ which gives $8a^3>(4y-x^2)a^2-xa+z-\dfrac{1}{4}$
therefore we get
$\left(8a^3+xa-\dfrac{1}{2}\right)^2<f(4a^2)<\left(8a^3+xa+\dfrac{1}{2}\right)^2$
So if $f(4a^2)$ is a square, then $f(4a^2)=(8a^3+xa)^2$, i.e., $(x^2-4y)a^2=z$. This cannot hold for more than one value of $a$ unless $4y=x^2$ and $z=0$. But then $f(n)=n\left(n+\dfrac{x}{2}\right)^2$; this is not a square if $n$ is a non-square different from $-\dfrac{x}{2}$.
this can be solved using modular arithmetic as below
If we can show that it cannot be for n = 1,2,3,4 then we are through
for n = 1 we have $f(1) = 1 + x + y+ z\cdots(1)$
for n= 2 we have $f(2) = 8 + 4x + 2y + z\cdots(2)$
$f(3) = 27 + 9x + 3y + +z\cdots(3)$
$f(4) = 64 + 16x + 4y + z\cdots(4)$
if f(1) and f(3) are perfect squares then from (1) and (3) we get $26+ 8x+ 2y \equiv 0 \pmod 4$ or $2y \equiv 2 \pmod 4\cdots(5)$
if f(2) and f(4) are perfect squares then from (2) and (4) we get $56+ 12x+ 2y \equiv 0 \pmod 4$ or $2y \equiv 0 \pmod 4\cdots(6)$
(5) and (6) cannot be satisfied at the same time so for n = 1 to 3 it cannot be a perfect square
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
