Prove f has maximum value in R
In summary: Also, I'm not sure what you mean by "dividing ##\mathbb{R}## into intervals." You don't need to do that to apply the theorem about the existence of a maximum.In summary, we are given a continuous function f on ℝ such that f(x) approaches 0 as x approaches -∞ and f(0)=2. We want to prove that f has a maximum value in ℝ. By the theorem, if f is continuous on a closed interval [a,b], then f has a maximum and minimum on [a,b]. We can show that f has a maximum by considering the intervals [a,3] and [3,∞). On [a,3], since a<
lep11
380
Let f: ℝ→ℝ be continuous function such that f(x) approaches 0 when x---> -∞ and f(0)=2. In addition, f is decreasing when x≥3. Prove f has a maximum (greatest value) in ℝ.
Theorem: If function f is continuous on a closed interval [a, b], then f has maximum and minimum in [a, b].
3. The Attempt at a Solution
Because f(x) approaches 0 when x ---> -∞ then there exists a<0 such that a<0 ⇒ |f(x)-0|=|f(x)|<2. So a<0 ⇒ f(x)<2. Because f is continuous in ℝ, it's also continuous on a closed interval [a,3]⊂ℝ and there's the theorem in our lecture notes that says now ∃x0∈[a,3] such that f(x)≤f(x0) ∀x∈[a,3]. Since a is negative, 0∈[a,3] and therefore f(x0)≥f(0)=2. Because f is decreasing when x≥3, f(x)≤f(x0), when x>x0≥3.
The idea is to divide ℝ into intervals so that we get closed interval to apply the theorem.
In a summary:
##a<0 ⇒ f(x)<2≤f(x_0)##
##x∈[a,3] ⇒f(x)≤f(x_0)##
##x≥3 ⇒f(x)≤f(x_0)##
∴ f has greatest value/maxima in ℝ.
Is this proof correct and rigorious enough? I think I have made a mistake in the end when it comes to the fact that f is decreasing when x≥3.
I think you have the right idea. I would change your last inequality to$$
x\ge 3 \implies f(x) \le f(3) \le f(x_0)$$to make it explicit where you use the fact that ##f## is decreasing on ##[3,\infty)##.
Likes lep11
Related to Prove f has maximum value in R
1. What does it mean for a function to have a maximum value in R?
Having a maximum value in R means that the function, f, has a point or set of points in the real number line where the output (y-value) is the largest it can be compared to all other points in the domain.
2. How do you prove that a function has a maximum value in R?
To prove that a function, f, has a maximum value in R, you must show that there exists a specific point or set of points in the domain where the function's output is the largest compared to all other points. This can be done through various mathematical methods, such as finding the critical points or using the first or second derivative tests.
3. Can a function have more than one maximum value in R?
Yes, a function can have more than one maximum value in R. This occurs when there are multiple points or sets of points in the domain where the function's output is the largest compared to all other points.
4. Does every function have a maximum value in R?
No, not every function has a maximum value in R. Some functions may have an unbounded range, meaning that the output can increase or decrease infinitely without reaching a maximum value. Other functions may have a maximum value in a restricted domain, but not in the entire real number line.
5. What is the importance of proving a function has a maximum value in R?
Proving that a function has a maximum value in R is important in understanding the behavior and properties of the function. It allows us to identify the largest possible output value and the corresponding input value, which can be useful in optimization problems or determining the range of a function. It also helps us understand the shape and characteristics of the graph of the function.
