Tsunoyukami
- 215
- 11
I'm having difficulty completing the last problem of an assignment due tomorrow evening. I feel as if I'm missing something; every time I attempt the problem I get stuck or confused.
"22. Use the conclusion of Exercise 21 and Example 13 of Section 6, Chapter 1, to prove that f(z) = log z cannot be analytic on any domain D that contains a piecewise smooth simple closed curve [itex]\gamma[/itex] that surrounds the origin. (Hint: What is the value of [itex]\int_{\gamma} f'(z) dz[/itex]?) (from Complex Variables, 2nd. edition by Stephen D. Fisher)
As this problem refers to both Exercise 21 and Example 13 I will summarize them here as well:
"21. Let [itex]\gamma[/itex] be a piecewise smooth simple closed curve, and suppose that F is analytic on some domain containing [itex]\gamma[/itex]. [Then] [itex]\int_{\gamma} F'(z) dz = 0[/itex]"
"Example 13 Suppose that [itex]\gamma[/itex] is a piecewise smooth positively oriented simple closed curve. The value of the integral
[itex]\frac{1}{2\pi i} \int_{\gamma} \frac{dz}{z - p}[/itex] , p not in [itex]\gamma[/itex] is
[itex]\frac{1}{2\pi i} \int_{\gamma} \frac{dz}{z - p} = 0[/itex], p is outside [itex]\gamma[/itex], or
[itex]\frac{1}{2\pi i} \int_{\gamma} \frac{dz}{z - p} = 1[/itex], p is inside [itex]\gamma[/itex]"
I attempted to show that f(z) = log z is analytic by applying the Cauchy-Riemann equations.
[itex]f(z) = log z = ln|z| + iarg(z) = ln|(x^2 + y^2)^\frac{1}{2}| + i arctan(y/x)[/itex]
[itex]f(z) = u + iv[/itex] with
[itex]u = ln|(x^2 + y^2)^\frac{1}{2}|[/itex] and
[itex]v = arctan(y/x)[/itex]
I then computed the partial derivatives of both u and v with respect to x and y and showed that u and v satisfy the Cauchy-Riemann equations. As a result, I expect f(z) = log z to be analytic.
However, the question asks me to show that f(z) is not analytic...
If I follow the hint given in the question:
[itex]\int_{\gamma} (log z)' dz[/itex]
[itex]\int_{\gamma} \frac{1}{z} dz[/itex]
I'm not too sure where I should go from here...if I simply integrate this I "just" get f(z) back (I'm not sure how to account for integrating over the path...should I write:
[itex]\int_{\gamma} \frac{1}{z} dz = \int_{a}^{b} \frac{1}{\gamma(t)} \gamma'(t) dt[/itex]
But then how should I proceed? I need to show that such an integral does not equal 0, because by exercise 21 if the integral equals 0 the function is analytic...
Any help will be greatly appreciated! Thanks a lot in advance! :)
