Prove $\frac{1}{2}<S<1$ in Sequence Challenge
In summary, to prove $\frac{1}{2}<S<1$ in a sequence challenge, the sequence must be shown to converge to a value between $\frac{1}{2}$ and $1$ using techniques such as the squeeze theorem, the ratio test, and the root test. Proving this is important as it verifies the boundedness and convergence of the sequence. An example of a sequence that satisfies $\frac{1}{2}<S<1$ is the harmonic series. When proving this, common mistakes to avoid include assuming boundedness without justification, using incorrect methods, and neglecting to show convergence.
anemone
MHB
POTW Director
3,883
115
Given that $S=1-\dfrac{1}{2}+\dfrac{1}{3}-\dfrac{1}{4} + ...+\dfrac{1}{99}-\dfrac{1}{100}$.
Prove that $\dfrac{1}{2}<S<1$.
Mathematics news on Phys.org
$$S = \left ( 1 - \frac{1}{2} \right ) + \left ( \frac{1}{3} - \frac{1}{4} \right ) + \cdots + \left ( \frac{1}{99} - \frac{1}{100} \right ) > \left ( 1 - \frac{1}{2} \right ) = \frac{1}{2}$$
$$S = 1 - \left ( \frac{1}{2} - \frac{1}{3} \right ) - \left ( \frac{1}{4} - \frac{1}{5} \right ) - \cdots - \frac{1}{100} < 1$$
$\blacksquare$
Good job, Bacterius! And thanks for participating!
FAQ: Prove $\frac{1}{2}<S<1$ in Sequence Challenge
How do you prove that $\frac{1}{2}
In order to prove $\frac{1}{2}
What is the importance of proving $\frac{1}{2}
Proving $\frac{1}{2}
What are some common techniques used to prove $\frac{1}{2}
Some common techniques used to prove $\frac{1}{2}
Can you provide an example of a sequence that satisfies $\frac{1}{2}
One example of a sequence that satisfies $\frac{1}{2}
What are some common mistakes to avoid when proving $\frac{1}{2}
Some common mistakes to avoid when proving $\frac{1}{2}
