Prove if ##a\cdot c = b \cdot c## then ##a = b## using Peano postulates
  • Thread starter Thread starter issacnewton
issacnewton
Prove if ##a\cdot c = b \cdot c## then ##a = b## using Peano postulates, given that ##a,b,c \in \mathbb{N}##
The book I am using ("The real numbers and real analysis" by Ethan Bloch) defines Peano postulates little differently.
Following is a set of Peano postulates I am using. (Axiom 1.2.1 in Bloch's book)
There exists a set ##\mathbb{N}## with an element ##1 \in \mathbb{N}## and a function ##s: \mathbb{N} \rightarrow \mathbb{N} ## that satisfy the following three properties.
1) There is no ##n \in \mathbb{N}## such that ##s(n) = 1##
2) The function ##s## is injective.
3) Let ##G \subseteq \mathbb{N}## be a set. Suppose that ##1 \in G##, and that if ##g \in G## then ##s(g) \in G##. Then ## G = \mathbb{N} ##
And addition operation is given in Theorem 1.2.5 as follows
There is a unique binary operation ##+: \mathbb{N} \times \mathbb{N} \to \mathbb{N} ## that satisfies the following two properties for all ##n, m \in \mathbb{N} ##
a. ## n + 1 = s(n) ##
b. ## n + s(m) = s(n + m) ##
Multiplication operation is given in Theorem 1.2.6 as follows
There is a unique binary operation ## \cdot: \mathbb{N} \times \mathbb{N} \to \mathbb{N} ## that satisfies the following two properties for all ##n, m \in \mathbb{N} ##
a. ##n \cdot 1 = n ##
b. ## n \cdot s(m) = (n \cdot m) + n ##
I am also going to assume following results for this proof. I have proven the following results using Peano postulates already.
Identity law for multiplication for ##a \in \mathbb{N} ##
$$ a \cdot 1 = a = 1 \cdot a $$
Distributive law
$$ (a + b) \cdot c= a \cdot c + b \cdot c $$
Commutative Law for addition
$$a + b = b + a$$
Cancellation law for addition
$$\text{ If } a + c = b + c \text{ then } a = b $$
This law
$$ a + b \ne a $$
Also, I am going to assume the following lemma which is proven in the book (Lemma 1.2.3)
Let ##a \in \mathbb{N}##. Suppose that ##a \ne 1##. Then there is a unique ##b \in \mathbb{N}## such that ##a = s(b)##.
with this background, we proceed to the proof. Let us define a set
$$ G = \{ x \in \mathbb{N} | \; y, z \in \mathbb{N}\; \text{ if } (x \cdot z) = (y \cdot z) \text{ then } x = y \} $$
We want to prove that ##G = \mathbb{N} ##. For this purpose, we will use part 3) of Peano postulates given above. Obviously, ## G \subseteq \mathbb{N} ##. Let ##y, z \in \mathbb{N}## be arbitrary. Suppose ## 1 \cdot z = y \cdot z##. Using Identity law for multiplication, we have ##y \cdot z = z##. So, we need to prove that ##y = 1##, so that ## 1 \in G##. Assume ##y \ne 1##. Now using lemma 1.2.3 given in relevant equations, ##y = s(t)## for some ## t \in \mathbb{N}##. So, we have ## s(t) \cdot z = z##. Or ## (t + 1) \cdot z = z##. Now using Distributive law, ##t \cdot z + 1 \cdot z = z##. And using Identity law for multiplication, this becomes ## t \cdot z + z = z##. Using Commutative Law for addition, ## z + t \cdot z = z##. But this violates one of the given equations ## a + b \ne a##. So, our assumption that ##y \ne 1## is wrong and we must conclude that ##y = 1##. So, this proves the implication that if ##(1 \cdot z) = (y \cdot z)## then ## 1 = y##. Since ## 1 \in \mathbb{N}##, and since ##y, z \in \mathbb{N}## are arbitrary to begin with, this proves that ## 1 \in G##. Next thing, we need to prove that if ##r \in G## then ## s(r) \in G##. So, suppose that ## r \in G##. This means that ##r \in \mathbb{N}## and
$$ \forall y,z \in \mathbb{N} \; \bigl[ (r \cdot z) = (y \cdot z) \longrightarrow (r = y) \bigr] \cdots\cdots (1) $$
From the definition of function ##s##, is seen that ## s(r) \in \mathbb{N}##. So, to prove ## s(r) \in G##, we need to prove that
$$ \forall y,z \in \mathbb{N} \; \bigl[ (s(r) \cdot z) = (y \cdot z) \longrightarrow (s(r) = y) \bigr] \cdots\cdots (2)$$
So, let ##y, z \in \mathbb{N}## be arbitrary and suppose that ## s(r) \cdot z = y \cdot z##. Using addition definition, we have ## y \cdot z = (r + 1) \cdot z##. Using Distributive law, ## y \cdot z = r \cdot z + 1 \cdot z ## and using Identity law for multiplication, ## y \cdot z = r \cdot z + z ##. Now if ##y = 1##, then ## y \cdot z = 1 \cdot z = z = r \cdot z + z##. Using Commutative Law for addition, we have ## z + r \cdot z = z ## and this contradicts one of the laws given in relevant equations section (##a + b \ne a##). So, our assumption that ##y = 1## is wrong. So, ##y \ne 1## and using lemma 1.2.3 given in relevant equations section, ## y = s(k)## for some ## k \in \mathbb{N}##. Now, we have ## y \cdot z = r \cdot z + z ##. It implies that ## s(k) \cdot z = r \cdot z + z ##. Using, addition definition and using Distributive law, we get ## (k \cdot z) + z = (r \cdot z) + z ##. Using, Cancellation law for addition, we have ## (k \cdot z) = (r \cdot z)##. Now since ## r \in G##, we can use equation (1) given above to conclude that ## r = k ##. It follows that ## s(k) = y = s(r)##. So, we proved the implication that
## (s(r) \cdot z) = (y \cdot z) \longrightarrow (s(r) = y) ##. Since ##y, z \in \mathbb{N}## are arbitrary, we prove equation (2). It then implies that ## s(r) \in G##. Using part 3) of Peano postulates, it follows that ## G = \mathbb{N} ##. Now since ##a,b,c \in \mathbb{N}##, it follows that ##a,b,c \in G## and it implies that if ##a \cdot c = b \cdot c## then ##a = b##. This proves the final result.
Is this a valid proof ?
Thanks
You could save so much space and the reader's (and your own) sanity by writing things more concisely.
  1. Show by induction on ##n\in\mathbb N## that ##nx=n## implies ##x=1##. I.e
    \left\lbrace n\in\mathbb N \mid (\forall x\in\mathbb N)(nx=n \Rightarrow x=1)\right\rbrace = \mathbb N.
  2. Your ##G## is quantified like this
    G = \left\lbrace n\in\mathbb N \mid (\forall x,m\in\mathbb N)(nx = mx \Rightarrow n=m) \ \right\rbrace .
    Quantifiers are important. Base case follows from 1. Suppose ## n\in G ## and let ## s(n)x=mx## for some ##m,x##. If ##m=1##, then ##s(n)x=x## implies ##s(n)=1##, which can't happen. Write ##m = s(k)## for some ##k##, then ## s(n)x = s(k)x##. By distributivity we have ##nx+x = kx +x##, which implies ##nx = kx## due to cancellative property of ##+##. Therefore, ##n=k## by induction assumption and ##s(n)=s(k)=m##, as required.
  3. It's often regarded as bad style to write predicate formulae inside sentences. Use display mode for those as you do with (1) and (2).
Otherwise, it's correct.
Likes issacnewton and MatinSAR
Thanks nuuskur. If I write many equations like (1) and (2), it will take lot of space and I may not get any responses.
