Prove Inequality For $x,y,z>0$ When $xyz=1$
  • MHB
  • Thread starter anemone
  • Tags
    Inequality
In summary, the inequality that needs to be proven is x + y + z ≥ 3. The given conditions are that x, y, and z are all greater than 0 and their product xyz is equal to 1. To prove this inequality, you can use the AM-GM inequality, which states that the arithmetic mean of a set of positive numbers is always greater than or equal to the geometric mean of the same set of numbers. This inequality can also be extended to n variables, where n > 3. There are other methods to prove this inequality, such as using the Cauchy-Schwarz inequality or the Rearrangement inequality, but the AM-GM inequality is the most commonly used and simplest method.
anemone
MHB
POTW Director
3,883
115
For $x,\,y,\,z>0$ and $xyz=1$, prove $\sqrt{x^2+1}+\sqrt{y^2+1}+\sqrt{z^2+1}\le\sqrt{2}(x+y+z)$.
Mathematics news on Phys.org
my solution:
let :$A=\sqrt{x^2+1}+\sqrt{y^2+1}+\sqrt{z^2+1}---(1)$
and B=$\sqrt{2}(x+y+z)---(2)$
using :Cauchy Schwarg inequalty or $AP\geq GP$ inequality (both will get the same result)
we have :$A^2\leq 3x^2+3y^2+3z^2+9---(3)$
$B^2\leq 6x^2+6y^2+6z^2=3x^2+3y^2+3z^2+3x^2+3y^2+3z^2---(4)$
but $3x^2+3y^2+3z^2\geq 3\sqrt[3]{27x^2y^2z^2}=9 $(using $AP\geq GP )$ again
$\therefore A^2\leq B^2$
this imples $A\leq B$
Albert said:
my solution:
Hi Albert, thanks for participating..
But I don't think you've completed the proof, Albert...
You stated $3x^2+3y^2+3z^2\geq 3\sqrt[3]{27x^2y^2z^2}=9 $, which I agreed that it holds true for $x,\,y,\,z>0$ and $xyz=1$, but I can't see how that is going to help in proving $A\leq B$...sorry Albert...
compare (3) and (4)
for each pair of x,y,z >0 ,and xyz=1
$A^2 \leq B^2$ always holds
when x=y=z=1 then
$A^2=B^2$ or $A=B$
Albert said:
compare (3) and (4)
when x=y=z=1 then
$A^2=B^2$ or $A=B$
I am also not convinced
x < A, y < B even A < B does not mean x < y
for example 3.5 < 4 and 3.4 < 6 does not mean 3.5 < 3.4
x < y need to be proved
in your case $A^2 < B^2$
let us consider the extreme condition :
$\sqrt {x^2+1}-\sqrt 2 x>0---(1)$
$\sqrt {y^2+1}-\sqrt 2 y>0---(2)$
the maximum value of(1)+(2) approaches 2
by using the given condition $xyz=1$
(that is $x ,y$ approach $0^+$ ,and the value of $z$ very big)
if we can find $z$ and $\sqrt 2 z-\sqrt {z^2+1}>2$
then the statement is true
(this can be done when $z$ appoaches $5.1^-$
Solution of other:
Let $f(x)=\sqrt{2}x-\sqrt{x^2+1}-\dfrac{\sqrt{2}\ln x}{2}$, note that (from graphical method) for $0<x<1$, we have the function $g(x)=\sqrt{2}x-\sqrt{x^2+1}$ lies above the function $h(x)=\dfrac{\sqrt{2}\ln x}{2}$ so $\sqrt{2}x-\sqrt{x^2+1}\ge\dfrac{\sqrt{2}\ln x}{2}$ holds for $0<x\le 1$, equality occurs at $x=1$.
Next, if we could prove $\sqrt{2}x-\sqrt{x^2+1}>\dfrac{\sqrt{2}\ln x}{2}$ for $x>1$, then the result will follow.
By using differentiation method, we find
$f'(x)=\sqrt{2}-\dfrac{x}{\sqrt{x^2+1}}-\dfrac{\sqrt{2}}{2x}=\dfrac{(2x-1)\sqrt{x^2+1}-\sqrt{2}x^2}{x\sqrt{2(x^2+1)}}$,
$f''(x)=\dfrac{1}{\sqrt{2}x^2}-\dfrac{1}{(x^2+1)\sqrt{x^2+1}}$ and $f'(x)=0$ iff $P(x)=(2x-1)\sqrt{x^2+1}-\sqrt{2}x^2=0$.
It's not hard to see $P(1)=0$, and $f''(1)>0$ so $(1,\,0)$ is a minimum point.
Note that $(2x-1)\sqrt{x^2+1}-\sqrt{2}x^2\div (x-1)$ gives $(x-1)(2x^3-2x^2+3x-1)=0$ and since $Q(x)=2x^3-2x^2+3x-1$ is a strictly increasing function beyond $x=1$ we can therefore conclude that $f(x)=\sqrt{2}x-\sqrt{x^2+1}-\dfrac{\sqrt{2}\ln x}{2}\ge 0$ for $x>0$.
Now, for $x,\,y,\,z>0$ and $xyz=1$, we can make the three inequalities as shown below and adding them up gives the desired result.
$\sqrt{2}x-\sqrt{x^2+1}\ge \dfrac{\sqrt{2}\ln x}{2}$
$\sqrt{2}y-\sqrt{y^2+1}\ge \dfrac{\sqrt{2}\ln y}{2}$
$\sqrt{2}z-\sqrt{z^2+1}\ge \dfrac{\sqrt{2}\ln z}{2}$
$\therefore \sqrt{x^2+1}+\sqrt{y^2+1}+\sqrt{z^2+1}\le\sqrt{2}(x+y+z)$.
FAQ: Prove Inequality For $x,y,z>0$ When $xyz=1$
What is the inequality that needs to be proven?
The inequality that needs to be proven is x + y + z ≥ 3.
What are the given conditions for the inequality to hold?
How can I prove this inequality?
To prove this inequality, you can use the AM-GM inequality, which states that the arithmetic mean of a set of positive numbers is always greater than or equal to the geometric mean of the same set of numbers. In this case, the numbers are x, y, and z. By applying this inequality, you can show that x + y + z ≥ 3(xyz)^(1/3), which simplifies to x + y + z ≥ 3 when xyz = 1.
Are there any other methods to prove this inequality?
Yes, there are other methods to prove this inequality, such as using the Cauchy-Schwarz inequality or the Rearrangement inequality. However, the AM-GM inequality is the most commonly used and simplest method to prove this inequality.
Can this inequality be extended to more than three variables?
Yes, this inequality can be extended to n variables, where n > 3. In this case, the inequality becomes x1 + x2 + ... + xn ≥ n(x1x2...xn)^(1/n), where all x values are positive and their product is equal to 1.
