Prove Inequality: Nonnegative Reals {x}_{1}...{x}_{n} Sum to 1
  • MHB
  • Thread starter Mathick
  • Tags
    Inequality
In summary, we are given a system of nonnegative real numbers {x}_{1}, {x}_{2}, ... , {x}_{n} such that {x}_{1} + {x}_{2} +...+ {x}_{n} =1 where n \geq 2 and we need to prove that the maximum value of these numbers multiplied by the sum of 1 and twice the sum of the minimum values of the pairs of numbers is greater than or equal to 1. For the case n=2, it has been proven that this statement holds by assuming one number is less than or equal to 1/2 and the other is greater than or equal to 1/2. For n=3,
Mathick
23
There are nonnegative real numbers \(\displaystyle {x}_{1}, {x}_{2}, ... , {x}_{n}\) such that \(\displaystyle {x}_{1} + {x}_{2} +...+ {x}_{n} =1 \) where \(\displaystyle n \ge 2\). Prove that
\(\displaystyle \max\left\{{x}_{1},{x}_{2},...,{x}_{n}\right\} \cdot (1+2 \cdot \sum_{1\le i<j\le n}^{}\min\left\{{x}_{i}, {x}_{j}\right\}) \ge 1 \).
I noticed that for \(\displaystyle n=2\) there are \(\displaystyle {x}_{1} + {x}_{2} = 1\) and, not decreasing generality of the task, I assumed that \(\displaystyle {x}_{1} \le {x}_{2}\) . Because sum of two element is equal 1, so one of them must be less or equal \(\displaystyle \frac{1}{2}\) and the other one must be bigger or equal \(\displaystyle \frac{1}{2}\). So \(\displaystyle 0 \le {x}_{1} \le \frac{1}{2} \le {x}_{2} \le 1\). Hence
\(\displaystyle \max\left\{{x}_{1},{x}_{2}\right\} \cdot (1+2 \cdot \sum_{1\le i<j\le 2}^{}\min\left\{{x}_{i}, {x}_{j}\right\})={x}_{2} (1+2{x}_{1})={x}_{2}+2{x}_{1}{x}_{2}\ge{x}_{2}+2\cdot\frac{1}{2}\cdot{x}_{1}={x}_{2}+{x}_{1}=1\)
But now I don't know how to prove it for n elements. Please help!
Hi Mathick, and thanks for setting such a challenging problem in your first post for MHB!I'l start by assuming, as you do, that $x_1 \leqslant x_2\leqslant \ldots \leqslant x_n$, so that $$\begin{aligned} \max\{x_1,\ldots,x_n\}\Bigl(1 + 2\!\!\!\sum_{1\leqslant i<j\leqslant n}\min\{x_i,x_j\}\Bigr) &= x_n\bigl(1 + 2x_{n-1} + 4x_{n-2} + \ldots (2n-2)x_1\bigl) \\ &= (1 - x_1 - x_2 - \ldots x_{n-1}) \bigl(1 + 2x_{n-1} + 4x_{n-2} + \ldots (2n-2)x_1\bigl) \overset{\mathrm{def}}{=} f(x_1,x_2,\ldots,x_{n-1}). \end{aligned}$$We want to show that $f(x_1,x_2,\ldots,x_{n-1}) \geqslant 1$ whenever $0 \leqslant x_1\leqslant x_2 \leqslant \ldots \leqslant x_{n-1} \leqslant 1 - x_1 - x_2 - \ldots - x_{n-1}.$ You have already proved this for the case $n=2$. I have a proof for $n=3$. But I am sure that there should be a better method, because my method does not give any clue about proving the result for larger values of $n$.When $n=3$ we have the function $f(x_1,x_2) = (1-x_1 - x_2)(1+ 4x_1 + 2x_2)$, defined in the triangular region given by the inequalities $0\leqslant x_1\leqslant x_2 \leqslant 1 - x_1 - x_2$.Notice that $x_1$ must lie between $0$ and $x_2$. Suppose that we keep $x_2$ fixed and regard $f(x_1,x_2)$ as a function of $x_1$. Its second partial derivative $\frac{\partial^2f}{\partial x_1^2}$ is $-8$, which is negative. Therefore $f(x_1,x_2)$ is convex downwards on the interval $[0,x_2]$ and hence attains its minimum value at an endpoint of the interval.If $x_1 = 0$ then $x_1$ makes no contribution to $f(x_1,x_2)$. By applying your result for the 2-dimensional case, we can conclude that $f(x_1,x_2) \geqslant 1$ when $x_1 = 0.$If $x_1 = x_2$ then the function $f(x_2,x_2)$ becomes $(1 - 2x_2)(1 + 6x_2)$, which is again convex downwards and hence attains its minimum value at an endpoint of the interval. We have already dealt with what happens at the lower end of this interval. The upper end is when $x_1=x_2$ has the maximum possible value, which is when $x_1 = x_2 = x_3 = \frac13$. At that point, $f(x_1,x_2) = 1$. Thus $f(x_1,x_2) \geqslant 1$ throughout its domain, and attains the minimum value $1$ at the points $(x_1,x_2,x_3) = \bigl(\frac13,\frac13,\frac13\bigr)$, $\bigl(0,\frac12,\frac12\bigr)$ and $(0,0,1)$.In the general case, the domain of $f(x_1,x_2,\ldots,x_{n-1})$ is given by the inequalities $0 \leqslant x_1\leqslant x_2 \leqslant \ldots \leqslant x_{n-1} \leqslant 1 - x_1 - x_2 - \ldots - x_{n-1}.$ This set is a simplex, with vertices corresponding to $$ (x_1,x_2,\ldots,x_n) = \bigl(\overbrace{0,\ldots,0}^r,\overbrace{\tfrac1{n-r}, \ldots, \tfrac1{n-r} }^{n-r}\bigr) \qquad(0 \leqslant r \leqslant n-1).$$ It seems to me that these must be exactly the points at which $f(x_1,x_2,\ldots,x_{n-1}) = 1$, and that it must be greater than $1$ everywhere else. But I am no closer to finding a proof for that. (Headbang)
FAQ: Prove Inequality: Nonnegative Reals {x}_{1}...{x}_{n} Sum to 1
What does it mean for {x}_{1}, ..., {x}_{n} to sum to 1?
When {x}_{1}, ..., {x}_{n} are nonnegative real numbers, summing to 1 means that their total value is equal to 1. In other words, if we were to add up all the values of {x}_{1}, ..., {x}_{n}, the result would be 1.
How can we prove that {x}_{1}, ..., {x}_{n} sum to 1?
One way to prove that {x}_{1}, ..., {x}_{n} sum to 1 is by using mathematical induction. First, we can prove that it is true for n=2, by substituting in values for {x}_{1} and {x}_{2} and showing that their sum is equal to 1. Then, assuming that it is true for n=k, we can use this as our base case and prove that it is also true for n=k+1. This will show that the statement holds for all natural numbers n.
Why do we need the condition that {x}_{1}, ..., {x}_{n} are nonnegative?
The condition that {x}_{1}, ..., {x}_{n} are nonnegative is necessary because otherwise, the statement would not hold. For example, if even just one of the values was negative, it would be impossible for the sum to equal 1. Additionally, the concept of nonnegative numbers is important in many areas of mathematics and science, so it is often included in mathematical statements.
Is it possible for {x}_{1}, ..., {x}_{n} to sum to a number other than 1?
No, it is not possible for {x}_{1}, ..., {x}_{n} to sum to a number other than 1. This is because 1 is the only number that can be multiplied by any real number and still result in the original number. In other words, 1 is the identity element for multiplication, and therefore, it is the only number that can be used to sum a set of numbers and still result in the same value.
How is this statement used in scientific research?
This statement is often used in scientific research to prove that a set of values represents a proportion or percentage. For example, if we have a set of probabilities for different outcomes of an experiment, we can use this statement to show that they all sum to 1, meaning that they represent all possible outcomes. Additionally, it is often used in statistical analyses to ensure that data is properly normalized.
