Prove Integral Equality of Polynomials Degree 2 & 3
In summary, to prove the integral equality of polynomials with degrees 2 and 3, the fundamental theorem of calculus can be used. The steps involved include finding the antiderivatives, evaluating them at the endpoints, and taking the difference. Other methods such as substitution, integration by parts, or trigonometric substitution can also be used. However, the fundamental theorem of calculus is the most commonly used. Specific conditions must be met for the equality to hold, including continuity of the function and antiderivatives. This proof can also be extended to polynomials with higher degrees.
anemone
MHB
POTW Director
3,883
115
Let $f(x)$ be a polynomial of degree 2 and $g(x)$ a polynomial of degree 3 such that $f(x)=g(x)$ at some three distinct equally spaced points $a,\,\dfrac{a+b}{2}$ and $b$. Prove that $\int_{a}^{b} f(x)\,dx=\int_{a}^{b} g(x)\,dx$.
Mathematics news on Phys.org
My solution:
WLOG, let's orient a new coordinate system such that:
\(\displaystyle f(-c)=g(-c)\)
\(\displaystyle f(0)=g(0)=0\)
\(\displaystyle f(c)=g(c)\)
Hence, we find that:
\(\displaystyle f(x)=u_2x^2+\left(u_1c^2+u_3\right)x\)
\(\displaystyle g(x)=u_1x^3+u_2x^2+u_3x\)
Now, we require:
\(\displaystyle \int_{-c}^0 g(x)-f(x)\,dx=\int_0^c f(x)-g(x)\,dx\)
which, using the FTOC, reduces to:
\(\displaystyle G(-c)-F(-c)=G(c)-F(c)\)
Thus, we require:
\(\displaystyle h(x)=G(x)-F(x)\)
to be an even function. Using $f$ and $g$, we find:
\(\displaystyle G(x)-F(x)=\left(\frac{u_1}{4}x^4+\frac{u_2}{3}x^3+\frac{u_3}{2}x^2\right)-\left(\frac{u_2}{3}x^3+\frac{u_1c^2+u_3}{2}x^2\right)=\frac{u_1}{4}x^4-\frac{u_1c^2}{2}x^2\)
Shown as desired.
MarkFL said:
My solution:
Now, we require:
Thus, we require:
Shown as desired.
Well done, MarkFL! Your solution is equally elegant as the one I have at hand and since both solutions differ a little, I'll hence share it here:
For simplicity, we translate the origin to the midpoint of the interval $(a,\,b)$.
Let $k=\dfrac{b-a}{2}$, $F(x)=f\left(x+\dfrac{a+b}{2} \right)$ and $G(x)=g\left(x+\dfrac{a+b}{2} \right)$ then we have
1. $F(-k)=f(a)=g(a)=G(-k)$
2. $F(0)=f\left(\dfrac{a+b}{2} \right)=g\left(\dfrac{a+b}{2} \right)=G(0)$
3. $F(k)=f(b)=g(b)=G(k)$.
Also, $\int_{a}^{b} f(x)\,dx=\int_{-k}^{k} F(x)\,dx$ and $\int_{a}^{b} g(x)\,dx=\int_{-k}^{k} G(x)\,dx$.
So it suffices to show that $\int_{-k}^{k} F(x)\,dx=\int_{-k}^{k} G(x)\,dx$.
We then let $P(x)=F(x)-G(x)$. Then $P(x)$ is a polynomial of degree 3 with zeros at $-k,\,0$ and $k$ so for some constant $c$,
$P(x)=cx(x-k)(x+k)=cx(x^2-k^2)$.
From the above, we see that $P$ is an odd function, and therefore $\int_{-k}^{k} P(x)\,dx=0$ and we're done.
FAQ: Prove Integral Equality of Polynomials Degree 2 & 3
How can we prove the integral equality of polynomials with degrees 2 and 3?
To prove the integral equality of polynomials with degrees 2 and 3, we can use the fundamental theorem of calculus. This theorem states that the integral of a function over a closed interval is equal to the difference of the antiderivatives of the function evaluated at the endpoints of the interval.
What are the steps involved in proving the integral equality of polynomials with degrees 2 and 3?
The steps involved in proving the integral equality of polynomials with degrees 2 and 3 include finding the antiderivatives of the polynomials, evaluating them at the endpoints of the interval, and then taking the difference of these values. This will show that the integral of the polynomials over the interval is equal to the difference of their antiderivatives at the endpoints.
Can the integral equality of polynomials with degrees 2 and 3 be proven using other methods?
Yes, there are other methods that can be used to prove the integral equality of polynomials with degrees 2 and 3. These include using the substitution rule, integration by parts, or trigonometric substitution. However, the fundamental theorem of calculus is the most commonly used method for this proof.
Are there any specific conditions that must be met for the integral equality of polynomials with degrees 2 and 3 to hold?
Yes, the fundamental theorem of calculus requires that the function being integrated is continuous over the interval and that the antiderivatives of the function exist and are continuous over the interval as well. If these conditions are met, then the integral equality of polynomials with degrees 2 and 3 will hold.
Can the integral equality of polynomials with degrees 2 and 3 be extended to polynomials with higher degrees?
Yes, the fundamental theorem of calculus can be extended to polynomials with any degree. The only difference is that the antiderivatives of higher-degree polynomials may be more complex, but the same principle of evaluating them at the endpoints and taking their difference still applies.
