Prove L'Hopitals rule using Taylors expansion
  • MHB
  • Thread starter ognik
  • Tags
    Expansion
In summary, by reversing the order of limits, you can show that:$ \lim_{{x}\to{{x}_{0}}}\frac{f\left({x}\right)}{g\left({x}\right)} = \lim_{{x}\to{{x}_{0}}} \frac{f^{'} \left({x}\right)}{g^{'}\left({x}\right)}
ognik
643
I'm given that $ \frac{f\left({x}_{o}\right)}{g\left({x}_{o}\right)} =\frac{0}{0} $ and asked to show that:
$ \lim_{{x}\to{{x}_{0}}}\frac{f\left({x}\right)}{g\left({x}\right)} = \lim_{{x}\to{{x}_{0}}} \frac{f^{'} \left({x}\right)}{g^{'}\left({x}\right)} $
This should be easy, but I suspect I've not got it quite right. Using Taylor (not Maclauren):
$ f\left(x\right) =f\left({x}_{0}\right) + {f}^{'}\left({x}_{0}\right)\left(x - {x}_{0}\right) + {f}^{''}\frac{\left(x-{x}_{0}\right)^2}{2!} + ... $
1) Am I correct to be able to ignore terms in $ x^2 $ and higher powers - because $ \left(x-{x}_{0}\right) $ is very small in the limit?
Then I get $ \lim_{{x}\to{{x}_{0}}} \frac{f\left({x}\right)}{g\left({x}\right)} =
\lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}_{0}\right)\left(x-{x}_{0}\right)} {{g}^{'}\left({x}_{0}\right)\left(x-{x}_{0}\right)} =
\lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}_{0}\right)} {{g}^{'}\left({x}_{0}\right)} $
2) Can I argue, by 'reversing' $ _{{x}\to{{x}_{0}}} $, to let $ \lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}_{0}\right)} {{g}^{'}\left({x}_{0}\right)} =
\lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}\right)} {{g}^{'}\left({x}\right)} $
I get the feeling what I've done is clumsy and there is a better way?
Thanks for reading
Thanks for reading
Yes that's correct. Alternatively you can factor the $x-x_0$ part and cancel it out.
\[\lim_{{x}\to{{x}_{0}}} \frac{f\left({x}\right)}{g\left({x}\right)} =
\lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}_{0}\right)\left(x-{x}_{0}\right)+\frac{f''(x_0)(x-x_0)^2}{2!}+\cdots} {{g}^{'}\left({x}_{0}\right)\left(x-{x}_{0}\right)+\frac{g''(x_0)(x-x_0)^2}{2!}+\cdots} = \lim_{{x}\to{{x}_{0}}} \frac{{f}^{'}\left({x}_{0}\right)+\frac{f''(x_0)(x-x_0)}{2!}+\cdots} {{g}^{'}\left({x}_{0}\right)+\frac{g''(x_0)(x-x_0)}{2!}+\cdots} = \frac{{f}^{'}\left({x}_{0}\right)} {{g}^{'}\left({x}_{0}\right)}\]
If $f'$ and $g'$ are continuous (in other words $f$ and $g$ are continuously differentiable) we have,
\[\lim_{{x}\to{{x}_{0}}} \frac{f\left({x}\right)}{g\left({x}\right)} = \lim_{x\rightarrow x_0}\frac{f'(x)}{g'(x)}\]
Hope this helps. :)
ognik said:
You are welcome. :)
FAQ: Prove L'Hopitals rule using Taylors expansion
What is L'Hopital's rule?
L'Hopital's rule is a mathematical theorem that allows for the evaluation of limits involving indeterminate forms, such as 0/0 or ∞/∞. It states that if the limit of the quotient of two functions is an indeterminate form, then the limit of the quotient of their derivatives is equal to the original limit.
What is Taylor's expansion?
Taylor's expansion is a mathematical tool used to approximate a function at a certain point by using a polynomial expression. It is based on the idea that any infinitely differentiable function can be expressed as the sum of an infinite series of polynomial terms.
How is Taylor's expansion used to prove L'Hopital's rule?
By expressing the numerator and denominator of the original limit as Taylor series, we can use the properties of limits and derivatives to simplify the expression and apply L'Hopital's rule. This allows us to evaluate the limit without having to use the original indeterminate form.
What are the requirements for using L'Hopital's rule?
In order to use L'Hopital's rule, the limit must be in an indeterminate form of 0/0 or ∞/∞. Additionally, the functions involved must be differentiable in a neighborhood around the point of interest and the limit must exist.
Can L'Hopital's rule be used for any limit?
No, L'Hopital's rule can only be used for limits that are in the indeterminate form of 0/0 or ∞/∞. If the limit is not in this form, then other mathematical techniques must be used to evaluate it.
