Prove lim f(x) as x approaches a is 0?
  • Thread starter jessjolt2
In summary, the problem is asking to prove that the limit as x approaches a of f(x) is 0, given that the limit as x approaches a of f(x)/(x-a) is 3. Using the epsilon-delta theorem, it is shown that if |x-a| is less than a certain value d1, then |f(x)/(x-a) - 3| is less than a certain value E1. This can be rewritten as |f(x)| is less than (E1-3)|x-a|. In order for the limit of f(x) to be 0, it must be a factor of (x-a) in order to cancel out the denominator. However, it cannot be assumed that
jessjolt2
It is given that the limit as x->a of ( f(x)/(x-a) ) is 3. Prove using the espilon-delta theorem of limit that the limit as x->a of f(x) is 0.
so it is known that: |( f(x)/(x-a) ) - 3| < E1 when |x-a| < d1
therefore:
|( f(x)/(x-a) ) - 3| ≤ |f(x)/(x-a)|+3 < E1
|f(x)| < (E1-3)|x-a|
(E1-3)|x-a| ≤ C(E-3)
|x-a| ≤ 1=C
|f(x)| < (E1-3) when d1=min{ 1, (E-3) }
and we have to prove that |f(x)-0| < E when |x-a| < d
so can i just say that:
|f(x)-0| < E2
|f(x)| < E2 when |x-a| < d2
So E2=E1-3 and d2=d1=min{ 1, (E-3) }
So |f(x)-0| < E1-3 when |x-a| < d1
is this right? i am not sure if i am making any logical sense in equating the two epsilons?
my intuition tells me that f(x) is zero at "a" because for f(x)/x-a to have a limit at "a", f(x) must be a factor of (x-a) so as to cancel out with the denominator. so if f(x)=(x-a)(p(x)), then f(a)=0, but i am not sure how to prove that using epsilon-delta, and i am not even sure if f(x) HAS to be a factor of (x-a)...sinx/x after all has a limit at 0 but sinx doesn't cancel with x.
help? :D
The denominator of f(x)/(x- 3) goes to 0 as x goes to 3. If f(x) goes to anything other than 0, then the limit of f(x)/(x-3), as x goes to 3, could not be finite.
It does NOT follow that f(3)= 0 because you are not told that f is continuous there. But that is not asked.
why would it not be finite if f(x) did not go to 0?
specifically i want to know if my proof is right? my professor wants it to be proved using epsilon-delta, not just words..
FAQ: Prove lim f(x) as x approaches a is 0?
What does it mean to prove a limit?
Proving a limit involves showing that a function approaches a certain value as the independent variable approaches a specific value. This value is known as the limit and can be found by analyzing the behavior of the function at that particular point.
How do you prove a limit using the epsilon-delta definition?
The epsilon-delta definition of a limit involves showing that for any small positive value of epsilon, there exists a corresponding positive value of delta such that when the independent variable is within delta units of the limit value, the function values are within epsilon units of the limit value.
Is it possible for a limit to not exist?
Yes, it is possible for a limit to not exist. This can happen if the function approaches different values from the left and right sides of the limit point, or if the function has a jump or discontinuity at the limit point.
Can a limit be negative?
Yes, a limit can be negative. The limit of a function depends on the behavior of the function as the independent variable approaches a certain value, and this behavior can result in a negative limit value.
How is the concept of limit used in real-world applications?
Limits are used in various real-world applications, such as in physics, engineering, and economics, to model and analyze continuous processes. For example, the concept of limit is used in calculus to calculate rates of change and to optimize functions, making it a crucial tool in many fields of science and industry.
