Prove Limit of |a_n|^(1/n) = L
  • MHB
  • Thread starter alexmahone
  • Tags
    Limit
In summary: So, it is not possible for $|q_n|=0$.In summary, if $\displaystyle\lim\left|\frac{a_{n+1}}{a_n}\right|=L$, then $\displaystyle\lim |a_n|^{1/n}=L$ holds true. This can be proven by considering the sequence of positive terms $|q_n|$ which converges to $L$, and the sequence of its geometric means which also converges to $L$. Furthermore, if $|q_n|=0$ for some $n$, it would contradict the hypothesis and therefore is not possible.
alexmahone
304
Prove: $\displaystyle \lim\left|\frac{a_{n+1}}{a_n}\right|=L\implies \lim |a_n|^{1/n}=L$.
Denote $q_n=\left|\dfrac{a_{n+1}}{a_n}\right|$. The sequence of positive terms $|q_n|$ converges to $L$, so the sequence if its geometric means also converges to $L$. As $\sqrt[n]{q_0q_1\ldots q_{n-1}}=\sqrt[n]{\dfrac{|a_n|}{|a_0|}}=\dfrac{\sqrt[n]{|a_n|}}{\sqrt[n]{|a_0|}}$, clearly $\sqrt[n]{|a_n|}\to L$ because $\sqrt[n]{|a_0|}\to 1$.
Why is this true?
What if $|q_n|=0$ for some $n$?
We are supposing by hypothesis that $a_{k+1}/a_k$ exists for all $k$. If $q_n=0$ then $a_{n+1}=0$ and this would imply $a_{n+2}/a_{n+1}$ does not exist (contradiction).
But the only hypothesis is $\displaystyle\lim\left|\frac{a_{n+1}}{a_n}\right|=L$. So, $\displaystyle a_0$ (for instance) could be 0.
Then, $a_1/a_0$ is not defined.
FAQ: Prove Limit of |a_n|^(1/n) = L
What is the definition of a limit?
The limit of a sequence is the value that the terms of the sequence approach as the index of the terms approaches infinity.
How do you prove the limit of |a_n|^(1/n) = L?
To prove this limit, you will need to use the definition of a limit and the properties of limits. Start by assuming that the limit L exists and use the definition to show that the sequence |a_n|^(1/n) approaches L as n approaches infinity. Then, use algebraic manipulations and the properties of limits to show that the difference between |a_n|^(1/n) and L approaches 0 as n approaches infinity.
What is the significance of the absolute value in the limit of |a_n|^(1/n) = L?
The absolute value ensures that the limit is positive and takes into account the possibility of negative terms in the sequence. It also allows us to use the properties of limits to simplify the expression and make the proof easier.
Can you prove the limit of |a_n|^(1/n) = L for any sequence?
Yes, the limit of |a_n|^(1/n) = L can be proven for any sequence as long as the sequence converges to a finite limit. However, the steps for proving the limit may vary depending on the specific properties of the sequence.
How is the limit of |a_n|^(1/n) = L related to the convergence of a sequence?
The limit of |a_n|^(1/n) = L is a necessary condition for the convergence of a sequence. If the limit exists and is finite, then the sequence is said to converge. However, the limit alone does not guarantee convergence as there may be other conditions that need to be satisfied as well.
