Prove limit of complex function 2
In summary, the proof for the limit definition $\lim_{z \to z_0} (z^2 + c) = z_0^2 + c$ involves finding a delta value that satisfies the condition of the definition. This can be done by using the triangle inequality and choosing delta accordingly. Another approach is to rewrite the expression using a term that can be bounded by delta.
complexnumber
62
Prove using limit definition [tex]$\lim_{z \to z_0} (z^2 + c) = z_0^2 +
c$[/tex].
For every [tex]$\varepsilon$[/tex] there should be a [tex]$\delta$[/tex] such that
[tex]
\begin{align*}
\text{if and only if } 0 < |z - z_0| < \delta \text{ then } |(z^2 + c) -
(z_0^2 + c)| < \varepsilon
\end{align*}
[/tex]
Starting from [tex]$ |(z^2 + c) - (z_0^2 + c)| < \varepsilon$[/tex]
[tex]
\begin{align*}
|(z^2 + c) - (z_0^2 + c)| = |z^2 - z_0^2| = |(z+z_0)(z-z_0)| <
\varepsilon
\end{align*}
[/tex]
How can I continue from here?
This is the exact same proof as for the real case, I think. The more flexible approach is to first let [tex]\left|z-z_0\right| < 1[/tex] and then apply the triangle inequality (you may need to use one of the variants of the inequality) to get a bound for [tex]\left|z+z_0\right|[/tex] and then choose delta accordingly. If you want to satisfy two inequalities at the same time, delta will be written as the min of two numbers.
The other way is to apply the triangle inequality directly. Clearly, the [tex]\left|z+z_0\right|[/tex] is the only term that gives us any trouble. Can you rewrite it so that we can use the fact that [tex]\left|z-z_0\right| < \delta[/tex] to our advantage? Hint: you need to add and subtract a term.
FAQ: Prove limit of complex function 2
What is a limit of a complex function?
A limit of a complex function is the value that the function approaches as its input approaches a certain point. In other words, it is the value that the function "approaches" but may not necessarily reach at a specific point.
How do you prove the limit of a complex function?
To prove the limit of a complex function, you must show that as the input approaches a certain point, the output of the function approaches a specific value. This can be done by using the definition of a limit and evaluating the function at values closer and closer to the point in question.
What is the difference between a limit of a complex function and the value of the function at a given point?
A limit of a complex function is the value that the function approaches as its input approaches a certain point, while the value of the function at a given point is the actual output of the function when the input is that specific point.
Can the limit of a complex function exist but the function still be undefined at a certain point?
Yes, it is possible for the limit of a complex function to exist but for the function to be undefined at a certain point. This can occur when the function has a "hole" or a vertical asymptote at that point, meaning that the function is not continuous at that point.
Are there any special cases to consider when proving the limit of a complex function?
Yes, there are a few special cases to consider when proving the limit of a complex function. These include limits involving infinity, limits involving trigonometric functions, and limits involving exponential functions. It is important to use the appropriate techniques and formulas for these special cases.
