Prove No Uniformly Convergent Subsequence: Functional Sequence
In summary, the conversation discusses the proof that the functional sequence {f_n} has no uniformly convergent subsequence. The proof involves showing that for any subsequence f_{n_{j}}, there exists a contradiction when considering the function f(x) = cosx and choosing a specific value of x. The proof also includes ensuring that j is chosen large enough to satisfy the condition for all x.
Arnold1
SOLVED Prove that the functional sequence has no uniformly convergent subsequence -check
\(\displaystyle n \in \mathbb{R}, \ \ f_n \ : \ \mathbb{R} \rightarrow \mathbb{R}, \ \ f_n(x) =\cos nx\)
We want to prove that \(\displaystyle {f_n}\) has no uniformly convergent subsequence.
This is my attempt at proving that:
Suppose that \(\displaystyle f_{n_{j}} \rightarrow f\) uniformly. This means that \(\displaystyle f\) is continuous(because cosnx is) and \(\displaystyle f(0) = \lim _{j \rightarrow +\infty}\cos 0=1\).
Therefore there exists a \(\displaystyle \delta > 0\) s.t. \(\displaystyle f(x) > \frac{1}{2}\) for \(\displaystyle |x|< \delta\).
Hence for \(\displaystyle j\) large enough, the uniform convergence of \(\displaystyle f_{n_{j}}\) tells us that \(\displaystyle |f(x) - f_{n_{j}}(x)|<\frac{1}{2}\)
But for one such \(\displaystyle j\) and \(\displaystyle x=\frac{\pi}{2n_{j}}\) we have
\(\displaystyle \frac{1}{2} < f(x) \le |f(x) - f_{n_{j}}(x)| + |f_{n_{j}}| < \frac{1}{2} + f_{n_{j}} = \frac{1}{2} + 0 = \frac{1}{2}\) and we have a contradiction.
My question is - is everything here correct? I'm just beginning to study functional sequences and I would really appreciate any help.
Thank you.
Re: SOLVED Prove that the functional sequence has no uniformly convergent subsequence -check
It's nice to specify, "for all $x$".
You need $j$ large enough not just so that \(\displaystyle |f(x) - f_{n_{j}}(x)|<\frac{1}{2}\) for all $x$, but also so that \(\displaystyle \frac{\pi}{2n_{j}}<\delta\).
Otherwise, the proof looks very nice.
Ok, I'll do that. Thanks.
FAQ: Prove No Uniformly Convergent Subsequence: Functional Sequence
What is a functional sequence?
A functional sequence is a sequence of functions, where each term in the sequence is a function of a variable x. This means that as the value of x changes, the function also changes.
What does it mean for a functional sequence to be uniformly convergent?
A functional sequence is uniformly convergent if, for any given value of x, the sequence of functions converges to a single limit function at the same rate. This means that the error between each term in the sequence and the limit function is small and does not depend on the value of x.
Why is it important to prove that there is no uniformly convergent subsequence?
Proving that there is no uniformly convergent subsequence is important in understanding the behavior of a functional sequence. If there is no uniformly convergent subsequence, it means that the sequence of functions does not converge to a single limit function at the same rate for all values of x. This can have implications in various areas of mathematics and science, such as in the analysis of algorithms or in the study of differential equations.
How can one prove that there is no uniformly convergent subsequence?
One way to prove that there is no uniformly convergent subsequence is by contradiction. This involves assuming that there is a uniformly convergent subsequence and then showing that this leads to a contradiction. Alternatively, one can also use the definition of uniform convergence and show that it does not hold for any subsequence of the functional sequence.
What are some real-life applications of proving no uniformly convergent subsequence in a functional sequence?
There are several real-life applications of proving no uniformly convergent subsequence in a functional sequence. For example, in computer science, the analysis of algorithms often involves studying the convergence of functional sequences. Proving that there is no uniformly convergent subsequence can help in determining the time complexity of an algorithm and optimizing its performance. Additionally, in the study of differential equations, understanding the behavior of functional sequences is crucial in solving certain types of equations and predicting the behavior of systems in real-world scenarios.
