Prove # of m-cycles in Sn (symmetric group)
  • Thread starter xsw001
  • Tags
    Group
In summary, the number of m-cycles in Sn can be found by dividing the total number of ways of forming an m-cycle in Sn, which is given by n(n-1)(n-2)...(n-m+1), by the number of a particular m-cycle, which is m. This is because there are n choices for the first element, n-1 choices for the second element, and so on, and n-k+1 choices for the mth element. Therefore, we have a total of n(n-1)(n-2)...(n-m+1) choices to form an m-cycle. To avoid counting too many, we divide by m. This result can be applied to any given n in the
xsw001
37
Prove that if n>=m then the # of m-cycles in Sn is given by [n(n-1)(n-2)...(n-m+1)]/m
The order of Sn is n!. We're counting the # of ways of forming an m-cycle, then divide by the # of a particular m-cycle.
This problem doesn't seem too bad. Initially I was thinking about using the induction proof. But now that I have doubts the induction would even work after I looking at an example since we have to prove for any given n in symmetric group, the # of m-cycles in Sn = [n(n-1)(n-2)...(n-m+1)]/m for all m<=n.
For example if n=5, then
1) m=1, (# of m-cycles in Sn) = 5/1 = 5
2) m=2, (# of m-cycles in Sn) = 5*4/2 = 10
3) m=3, (# of m-cycles in Sn) = 5*4*3/3 = 20
4) m=4, (# of m-cycles in Sn) = 5*4*3*2/4 = 30
5) m=5, (# of m-cycles in Sn) = 5*4*3*2*1/5 = 24
Any helpful tips would be greatly appreciated!
hi xsw001! :wink:
what's the difficulty? :confused:
what are the # of ways of forming an m-cycle (and why)? :smile:
Okay, for any given Sn, there are n elements in Sn {1, 2, ... m,..., n}, so we have n choices for the 1st element, then n-1 choices for the 2nd element, so on and so forth, and we have n-k+1 choices for mth element, etc. So there are total of n(n-1)(n-2)...(n-m+1)choices to form a m-cycle, to count the number of cycles that we have, then we have to divide by m so that we don't count too many.
Can I just explain it out without using induction proof then?
yup! that should do! :smile:
Cool! Thanks tiny-tim!
FAQ: Prove # of m-cycles in Sn (symmetric group)
1. What is an m-cycle in the symmetric group?
An m-cycle in the symmetric group, denoted as Sn, is a permutation of n distinct elements that moves m elements cyclically while leaving the rest unchanged. In other words, it is a cycle of length m within the group of n elements.
2. How do you prove the number of m-cycles in Sn?
To prove the number of m-cycles in Sn, we can use the formula: (n choose m) * (m-1)! This formula takes into account the number of ways to choose m elements from the total of n elements, and then the number of ways to arrange those m elements in a cycle.
3. Can you give an example of an m-cycle in the symmetric group?
Sure, let's take the symmetric group S4, with the elements {1,2,3,4}. An example of a 3-cycle in this group would be (1 3 4), which moves 1 to 3, 3 to 4, and 4 back to 1 while leaving 2 unchanged.
4. How does the number of m-cycles in Sn relate to the size of the symmetric group?
The number of m-cycles in Sn is directly related to the size of the symmetric group. In fact, the total number of m-cycles in Sn is equal to (n choose m) * (m-1)!, which is a fraction of the total number of permutations in Sn, which is n!. This relationship holds true for all values of m and n.
5. What is the significance of understanding the number of m-cycles in the symmetric group?
Understanding the number of m-cycles in the symmetric group is important in various areas of mathematics, such as combinatorics and group theory. It allows us to analyze and understand the structure of permutations within a group, and can also be applied to other mathematical concepts and problems.
