Prove: One of $a, b$ or $c$ is Sum of Other Two
  • MHB
  • Thread starter anemone
  • Tags
    Sum
Therefore, one of $a, b$ or $c$ is the sum of the other two.In summary, If $a, b$ and $c$ are three real numbers such that $|a-b|\ge|c|$, $|b-c|\ge|a|$ and $|c-a|\ge|b|$, then one of $a, b$ or $c$ is the sum of the other two.
anemone
MHB
POTW Director
3,883
115
If $a, b$ and $c$ are three real numbers such that $|a-b|\ge|c|$, $|b-c|\ge|a|$ and $|c-a|\ge|b|$, then prove that one of $a, b$ or $c$ is the sum of the other two.
Mathematics news on Phys.org
Re: Prove a+b=c
My solution
First off, if two are equal then the third is zero and we're done. So we will assume that none are equal. We will assume that $a \le b \le c$ (without loss of generality). Thus, from the three inequalities given we have
$\begin{eqnarray}
a - b \;& \; \le\; & \;c \;& \;\le b-a\\
b - c\; & \;\le\; &\;a &\; \le c-b\\
a - c \;& \;\le\; &\;b & \;\le c-a
\end{eqnarray}.$
From the right hand side of the first inequality we have $a+c \le b$ and the left hand side of the second inequality we have $b \le a + c$ giving the $b=a+c$
Re: Prove a+b=c
Squaring both sides of the inequality of $|a-b|\ge|c|$, we get
$(a-b)^2\ge c^2$
$(a-b)^2-c^2\ge 0$
$(a-b+c)(a-b-c)\ge 0$---(1)
Similarly we have
$(b-c+a)(b-c-a)\ge 0$
$-(b-c+a)(-b+c+a)\ge 0 $
$\rightarrow -(a+b-c)(a-b+c)\ge 0$---(2)
and $(c-a+b)(c-a-b)\ge 0$
$(-c+a-b)(-c+a+b)\ge 0$
$\rightarrow (a-b-c)(a+b-c)\ge 0$---(3)
Multiply these three inequalities yields
$(a-b+c)(a-b-c)(-(a+b-c)(a-b+c))(a-b-c)(a+b-c) \ge 0$
$-(a-b+c)^2(a-b-c)^2(a+b-c)^2 \ge 0$
Apparently, this inequality holds true if either $a-b+c=0 (a+c=b)$ or $a-b-c=0 (b+c=a)$ or $a+b-c=0 (a+b=c)$.
FAQ: Prove: One of $a, b$ or $c$ is Sum of Other Two
What is meant by "Prove: One of $a, b$ or $c$ is Sum of Other Two"?
This statement means that out of three numbers, $a$, $b$, and $c$, one of them can be expressed as the sum of the other two. In other words, one number is equal to the sum of the other two numbers.
Can this statement be proven?
Yes, this statement can be proven using mathematical reasoning and logic.
How can one prove that one of the numbers is the sum of the other two?
One way to prove this statement is by assuming that one number, let's say $a$, is equal to the sum of the other two numbers, $b$ and $c$, and then using algebraic manipulation to show that this assumption is true for all possible values of $a$, $b$, and $c$.
What is the significance of this statement in mathematics?
This statement is significant because it is a fundamental concept in algebra and number theory. It helps us understand the relationships between numbers and how they can be manipulated and combined.
Can this statement be applied to any three numbers?
Yes, this statement can be applied to any three numbers, as long as they follow the rules of arithmetic. However, it may not always be true for all three numbers, as there are exceptions and special cases where this statement does not hold.
