Prove one of the angles of triangle is 60°
In summary, the given information states that the altitudes of the acute triangle $PQR$, $PA$, $QB$, and $RC$, are in a certain ratio. This means that the triangle formed by $9\vec{PA}$, $4\vec{QB}$, and $7\vec{RC}$ is similar to the original triangle $PQR$. Using the cosine rule, it is shown that one of the angles of $PQR$ is $60^{\circ}$. This is a neat solution that was provided by Opalg. Another solution found online also shows that the triangles are similar and that the ratios of their sides are equal, leading to the conclusion that one of the angles of $PQR$
anemone
MHB
POTW Director
3,883
115
Given that $PA,\,QB,\,RC$ are the altitudes of the acute triangle $PQR$ such that $9\vec{PA}+4\vec{QB}+7\vec{RC}=0$.
Show that one of the angles of triangle $PQR$ is $60^{\circ}$.
Mathematics news on Phys.org
[sp]Denote the lengths of the sides of the triangle by $|\vec{QR}| = p$, $|\vec{RP}| = q$, $|\vec{PQ}| = r$, and the lengths of the altitudes by $|\vec{PA}| = a$, $|\vec{QB}| = b$, $|\vec{RC}| = c.$ Then the area of the triangle is $\frac12ap = \frac12bq = \frac12cr$, so that the ratios $\frac1a : \frac1b:\frac1c$ and $p:q:r$ are the same.
If $9\vec{PA}+4\vec{QB}+7\vec{RC}=0$, then the vectors $9\vec{PA}$, $4\vec{QB}$ and $7\vec{RC}$ form a triangle whose sides have lengths in the ratio $9a : 4b : 7c$. Also, each side of this triangle is in a direction perpendicular to the corresponding side of the triangle $PQR$ ($\vec{PA}$ is perpendicular to $\vec{BC}$ and so on), so the two triangles have the same angles and are therefore similar. Thus the lengths of their sides are in the same ratio, so that the ratios $9a : 4b : 7c$ and $\frac1a : \frac1b:\frac1c$ are the same. Therefore $9a^2 = 4b^2 = 7c^2$, or equivalently $p^2 = 9\lambda$, $q^2 = 4\lambda$, $r^2 = 7\lambda$ for some constant $\lambda.$
By the cosine rule in the triangle $PQR$, $\cos R = \dfrac{p^2 + q^2 - r^2}{2pq} = \dfrac{9+4-7}{2\sqrt9\sqrt4} = \dfrac6{12} = \dfrac12$ and hence $\angle R = 60^\circ.$[/sp]
Thank you Opalg for your neat solution!
Alternate solution that I saw somewhere online:
Let $\alpha=\angle QPR,\,\beta=\angle RQP$ and $\gamma=\angle PRQ$ and $a,\,b,\,c$ be the respective magnitudes of vectors $\vec{PA},\,\vec{QB},\,\vec{RC}$.
Taking the dot product of the vector equation with $\vec{QR}$ and note that $\angle BQR=90^{\circ}-\beta$, we find that $4b\sin \gamma=7c\sin \beta$.
Similarly, $9a\sin \gamma=7c\sin \alpha$ and $9a\sin \beta=4b\sin \alpha$.
Using the conventional notation for the sides of the triangle, we have that $p:q:r=\sin alpha:\sin \beta:\sin \gamma=9a:4b:7c$.
However, we also have that twice the area of triangle $PQR$ is equal to $pa=qb=rc$, so that $p:q:r=\dfrac{1}{a}:\dfrac{1}{b}:\dfrac{1}{c}$. Therefore $9a^2=4b^2=7c^2=k$ for some constant $k$.
$\begin{align*}\therefore \cos PRQ&=\dfrac{p^2+q^2-r^2}{2pq}\\&=\dfrac{81a^2+16b^2-49c^2}{72ab}\\&=\dfrac{9k+4k-7k}{12k}\\&=\dfrac{1}{2}\end{align*}$
from which it follows that $\angle R=60^{\circ}$.
FAQ: Prove one of the angles of triangle is 60°
How do you prove that one angle of a triangle is 60°?
To prove that one angle of a triangle is 60°, you can use the fact that the sum of angles in a triangle is 180°. If you know the measures of two angles, you can subtract their sum from 180° to find the measure of the third angle. If the resulting measure is 60°, then you have proven that one angle of the triangle is indeed 60°.
What is the importance of proving the measure of one angle in a triangle?
Proving the measure of one angle in a triangle is important because it helps to establish the properties and relationships of the triangle. It can also help to solve for unknown measures of other angles or sides in the triangle.
Can you use any method to prove that one angle of a triangle is 60°?
Yes, there are multiple methods that can be used to prove that one angle of a triangle is 60°. Some common methods include using the Triangle Sum Theorem, the Pythagorean Theorem, or trigonometric functions.
What if the triangle is not a right triangle, can you still prove that one angle is 60°?
Yes, you can still prove that one angle of a non-right triangle is 60°. As long as you have enough information about the triangle, such as the measures of two angles or the lengths of two sides, you can use various methods to prove the measure of the third angle is 60°.
Is it possible for more than one angle in a triangle to be 60°?
No, it is not possible for more than one angle in a triangle to be 60°. This is because the sum of angles in a triangle is always 180°, so if one angle is 60°, the other two angles must have a combined measure of 120°, leaving no room for another 60° angle.
