Prove One Root in Interval (0,1) for Equation with Real Numbers
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, to prove the existence of at least one root in the interval (0,1) for an equation with real numbers, we can use the Intermediate Value Theorem. This theorem states that a continuous function must cross the x-axis between two points where it has different signs. A continuous function is one that has a smooth and connected graph with no breaks or jumps. While there are other methods to prove the existence of a root in this interval, the Intermediate Value Theorem may be the most applicable. However, it cannot be used to find the exact value of the root, as other methods must be used for this purpose.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $m,\,n,\,k$ be real numbers such that $m>0$ and $\dfrac{m}{5}+\dfrac{n}{4}+\dfrac{k}{3}=0$.
Prove that the equation $mx^2+nx+k=0$ has one root in the interval $(0,\,1)$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to greg1313 for his correct solution:).
greg1313's solution:
\(\displaystyle \frac m5+\frac n4+\frac k3=0\)
Divide both sides by \(\displaystyle -m\):
\(\displaystyle -\frac 15-\frac{n}{4m}-\frac{k}{3m}=0\)
Using Vieta's formulae for the sum and product of the roots we have
\(\displaystyle -\frac 15+\frac{a+b}{4}-\frac{ab}{3}=0\)
\(\displaystyle 3(a+b)-4ab=\frac{12}{5}\Rightarrow b=\frac{12-15a}{15-20a},\quad0<\frac{12-15a}{15-20a}<1,\quad\forall\,\, a\in\mathbb{R},a\cancel\in(0,1)\)
To show 0 < b < 1 over the intervals \(\displaystyle (-\infty,0]\) and \(\displaystyle [1,\infty)\),
\(\displaystyle f(a)=\frac{12-15a}{15-20a},\quad f'(a)=\frac{-15(15-20a)+20(12-15a)}{(15-20a)^2}=\frac{15}{(15-20a)^2}\)
As its derivative is always positive over the given intervals, \(\displaystyle f(a)\) is strictly increasing over the given intervals.
Now, \(\displaystyle \lim_{a\to-\infty}f(a)=\frac34\) and \(\displaystyle f(0)=\frac45\) so \(\displaystyle 0<b<1\) on \(\displaystyle (-\infty,0]\)
\(\displaystyle \lim_{a\to\infty}f(a)=\frac34\) and \(\displaystyle f(1)=\frac35\) so \(\displaystyle 0<b<1\) on \(\displaystyle [1,\infty)\)
as required.
I will note that if \(\displaystyle a\in(0,1)\) and \(\displaystyle a\ne\frac34\) we are done.
You can also find the proposed solution below:
Let $f(x)=mx^2+nx+k$.
Note that we're given $\dfrac{m}{5}+\dfrac{n}{4}+\dfrac{k}{3}=0$, multiply both sides by the quantity $5\left(\dfrac{4}{5}\right)^2$, we get:
$5\left(\dfrac{4}{5}\right)^2\left(\dfrac{m}{5}+\dfrac{n}{4}+\dfrac{k}{3}\right)=5\left(\dfrac{4}{5}\right)^2(0)$
$\left(\dfrac{4}{5}\right)^2m+\dfrac{4}{5}n+\dfrac{4^2}{3\cdot 5}k=0$
$\left(\dfrac{4}{5}\right)^2m+\dfrac{4}{5}n=-\dfrac{16}{15}k$
$\left(\dfrac{4}{5}\right)^2m+\dfrac{4}{5}n+k=-\dfrac{k}{15}$
In other words, we have
$f\left(\dfrac{4}{5}\right)=\left(\dfrac{4}{5}\right)^2m+\dfrac{4}{5}n+k=-\dfrac{k}{15}$ and $f(0)=m(0)^2+n(0)+k=k$
Since $f$ is a continuous function over all real $x$, and $f(0)f\left(\dfrac{4}{5}\right)=k\left(-\dfrac{1}{15}k\right)=-\dfrac{k^2}{15}\le 0$, Intermediate value theorem tells us that there is a root in the interval $\left(0,\,\dfrac{4}{5}\right]\subset (0,\,1)$, and we're done.
FAQ: Prove One Root in Interval (0,1) for Equation with Real Numbers
How do you prove that there is at least one root in the interval (0,1) for an equation with real numbers?
To prove that there is at least one root in the interval (0,1) for an equation with real numbers, we can use the Intermediate Value Theorem. This theorem states that if a continuous function f(x) has different signs at two points a and b, then there must exist a point c between a and b where the function crosses the x-axis (i.e. a root). We can use this theorem to prove the existence of a root in the interval (0,1) by checking the signs of f(0) and f(1).
Can you explain the Intermediate Value Theorem in simpler terms?
The Intermediate Value Theorem states that if a continuous function has different signs at two points, then it must cross the x-axis (i.e. have a root) between those two points. In other words, if a function starts above the x-axis and ends below the x-axis (or vice versa), it must cross the x-axis at least once in between.
What is a continuous function?
A continuous function is a function that has no "breaks" or "jumps" in its graph. In other words, the graph of a continuous function can be drawn without lifting the pencil from the paper. This means that the function has a smooth and connected graph with no gaps or holes.
Are there any other methods to prove the existence of a root in the interval (0,1) for an equation with real numbers?
Yes, there are other methods that can be used to prove the existence of a root in the interval (0,1) for an equation with real numbers. Some common methods include using the Mean Value Theorem, the Bolzano-Weierstrass Theorem, or the Bisection Method. These methods may be more or less applicable depending on the specific equation and its properties.
Can the Intermediate Value Theorem be used to find the exact value of the root in the interval (0,1)?
No, the Intermediate Value Theorem only guarantees the existence of a root in the interval (0,1), but it does not provide the exact value of the root. To find the exact value, we would need to use other methods such as numerical approximation or algebraic manipulation.
