MHB Prove One-to-One Correspondence Conjugate Subgroups & Cosets N
  • Thread starter Thread starter Kiwi1
    Conjugate
The discussion centers on proving a one-to-one correspondence between the set of conjugates of a subgroup H and the set of cosets of a normal subgroup N. The user presents a solution defining a function f that maps conjugates to cosets, demonstrating that f is both well-defined and bijective by leveraging a previous result (Q7). The solution confirms that if two conjugates are equal, their corresponding cosets are also equal, establishing injectivity and surjectivity. A participant affirms the correctness of the solution and suggests that knowledge of group actions could provide a more concise proof. The discussion concludes with an endorsement of the user's approach to the problem.
Kiwi1
Q. Prove there is a one-to-one correspondence between the set of conjugates of H and the set of cosets of N.
I have a solution to this below but am not sure if it is correct. In particular I am not sure if my definition 'f' is satisfactory. This is self study and not any kind of homework.
I have:
aHa^{-1}=\{axa^{-1}:x\epsilon H\}
N=\{a \epsilon G: axa^{-1} \epsilon H for every x \epsilon H \}
I have proven as part of the previous question:
Q7. For any a,b \epsilon G, aHa^{-1}= bHb^{-1} iff b^{-1}a \epsilon N iff aN=bN
SOLUTION
define the set of conjugates: X=\{aHa^{-1}:a \epsilon G \}
define the set of cosets of N: Y=\{aN:a \epsilon G \}
define f:X \rightarrow Y by f(aHa^{-1})=aN
f is well defined because if aHa^{-1}=bHb^{-1} then aN = bN by Q7.
Surjectivity:
for any aN \epsilon Y
f(aHa^{-1})=aN
where aHa^{-1} \epsilon X
therefore f is surjective
Injectivity:
suppose aN = bN
\therefore f(aHa^{-1})=f(bHb^{-1})
where aHa^{-1}=bHb^{-1} by Q7.
therefore f is injective
There is a bijection f from X to Y so there is a 1:1 correspondence between the members of X and Y.
Is this solution reasonably rigorous?
I have:
SOLUTION
Surjectivity:
f(aHa^{-1})=aN
Injectivity:
suppose aN = bN
Your solution is fine. If you know group actions, then I can tell you a shorter solution.
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 23 ·
