Prove $|P(a)-P(b)|<\dfrac{1}{2}$ for Algebra Challenge Function $P$
In summary: Danlet :$0\leq b=a\pm k\leq 1$for : $a+k-(a-k)=2k\leq (1-0)=1$or $k \leq \dfrac {1}{2}$then : $|b - a| =|a\pm k -a| =|\pm k| \leq \dfrac {1}{2}$$\therefore |P(b) -P(a)| <|b -a| \leq \dfrac {1}{2}$Sorry for the late reply and thanks Albert for participating, and
anemone
MHB
POTW Director
3,883
115
Let $P$ be a function defined on $[0, 1]$ such that $P(0)=P(1)=1$ and $|P(a)-P(b)|<|a-b|$, for all $a\ne b$ in the interval $[0, 1]$.
Prove that $|P(a)-P(b)|<\dfrac{1}{2}$.
Mathematics news on Phys.org
for simplicity , I will set :$P(x)=x(x-1)+1=(x-\dfrac{1}{2})^2+\dfrac {3}{4}$
then $max(P(a)-P(b))\leq 1-\dfrac {3}{4}<\dfrac {1}{2}$
take $a=1,b=\dfrac {1}{2}$
Are you simply demonstrating an example or is there some way this will generalize to all possible P(x)?
-Dan
[sp]Because is $|P(a) - P (b)|<|a - b|$ for all $a \ne b$ in [0,1] is also $|P' (x)|< 1$ for all x in [0,1] . But is also $\int_{0}^{1} P' (x)\ d x = P(1) - P(0) = 0$ , so that for all a and b in [0,1] is $ |\int_{a}^{b} P'(x)\ d x| = |P(b) - P(a)| \le \frac{1}{2}$...[/sp]
Kind regards$\chi$ $\sigma$
-Dan
In general you can set $P(x)=x^n(x-1)^n+1$
and then find its derivative to get $max(P(x))$ and $min(P(x))$
for $x\in [0,1]$
very clever solution !
but $ |P(b) - P(a)| =\dfrac {1}{2}$ should be excluded , for $a,b \in [0,1]$ and $a\neq b$
this is the same as using probability method:
$\dfrac { |P(b) - P(a)|}{1-0}<\dfrac { |b - a|}{1-0}<\dfrac {1}{2}$
chisigma said:
[sp]so that for all a and b in [0,1] is $ |\int_{a}^{b} P'(x)\ d x| = |P(b) - P(a)| \le \frac{1}{2}$...[/sp]
I'm sorry, \(\displaystyle \chi ~ \sigma\), I can't see how you are getting |b - a| < 1/2 in the last step?
-Dan
-Dan
Sorry for the late reply and thanks Albert for participating, and your explanations and also thanks to chisigma for your solution...
Solution of other:
We consider the following cases:
Case I ($|a-b|\le \dfrac{1}{2}$):
If $|a-b|\le \dfrac{1}{2}$, then
$|P(a)-P(b)|<|a-b|\le\dfrac{1}{2}$, as desired.
Case II ($|a-b|> \dfrac{1}{2}$):
By symmetry, we may assume $a>b$.
Then
$\begin{align*}|P(a)-P(b)|&=|P(a)-P(1)+P(0)-P(b)|\\&\le |P(a)-P(1)|+|P(0)-P(b)|\\&<|a-1|+|0-b|\\&=1-a+b-0\\&=1-(a-b)\\&<\dfrac{1}{2}\end{align*}$
as desired.
FAQ: Prove $|P(a)-P(b)|<\dfrac{1}{2}$ for Algebra Challenge Function $P$
How do you define the Algebra Challenge Function P?
The Algebra Challenge Function P is a mathematical function that takes in two real numbers, a and b, and outputs a real number, P(a). It is commonly used in algebraic problem-solving and is defined as P(a) = 2a + 1.
What is the significance of proving that |P(a)-P(b)| < 1/2?
Proving that |P(a)-P(b)| < 1/2 shows that the Algebra Challenge Function P is a continuous function. This means that for any two real numbers, a and b, the difference between P(a) and P(b) will always be less than 1/2. This property is important in many mathematical applications and problem-solving.
How can you prove that |P(a)-P(b)| < 1/2 for any values of a and b?
To prove that |P(a)-P(b)| < 1/2, we can use the definition of the Algebra Challenge Function P and the properties of real numbers. By substituting the values of a and b into the function, we can manipulate the expression to show that it is always less than 1/2.
Is the statement |P(a)-P(b)| < 1/2 true for all types of numbers, including fractions and irrational numbers?
Yes, the statement |P(a)-P(b)| < 1/2 is true for all types of numbers, including fractions and irrational numbers. This is because the Algebra Challenge Function P is defined for all real numbers and the properties of real numbers hold true for all types of numbers.
Can you provide an example of how proving |P(a)-P(b)| < 1/2 can be used in a real-world problem?
One example of how proving |P(a)-P(b)| < 1/2 can be used in a real-world problem is in calculating the distance between two points on a graph. In this case, a and b represent the x-coordinates of the two points, and P(a) and P(b) represent the y-coordinates. By proving that |P(a)-P(b)| < 1/2, we can show that the distance between the two points is always less than 1/2 units, making the function useful in accurately measuring distances in real-life scenarios.
