MHB Prove Polynomial Remainder: -2x+5 When Divided by (x-1)(x-2)
  • Thread starter Thread starter gobindo
    Polynomial
The discussion revolves around proving that a polynomial P(x) leaves a remainder of -2x + 5 when divided by (x-1)(x-2). Participants agree that the problem may have been misquoted, suggesting that the remainders for P(1) and P(2) were reversed. By applying the division algorithm and the remainder theorem, they establish a linear function for the remainder. A system of equations is proposed to solve for the parameters of the linear remainder. The consensus is that the correct remainder is indeed -2x + 5.
gobindo
A polynomial P(x) when divided by(x-1) leaves a remainder 1 and when divided by (x-2) leaves a remainder of3. prove that when divided by(x-1(x-2) it leaves a remainder -2x=5.
thank you.
Mathematics news on Phys.org
Re: I'm having trouble with this question:
By the division algorithm, we may state:
$$P(x)=(x-1)(x-2)Q(x)+R(x)$$
We know the remainder must be a linear function (right?), and so we may state:
(1) $$P(x)=(x-1)(x-2)Q(x)+ax+b$$
And from the remainder theorem we know:
$$P(1)=1$$
$$P(2)=3$$
I suspect the problem has been misquoted, since the given remainder is not correct, whether the "=" should be "+" or "-". I am assuming then that the constant remainders have been reversed, and the linear remainder is in fact $-2x+5$. So, we have instead:
$$P(1)=3$$
$$P(2)=1$$
Using the two equations above and (1), we may get a 2 X 2 linear system in the parameters $a$ and $b$, which will have a unique solution. Can you put all of this together?
You are going to win the "most psychic member" award this year... Good call.
-Dan
Here's an alternate approach:
$$\frac{P(x)}{x-2}=Q_2(x)+\frac{1}{x-2}$$
$$\frac{P(x)}{x-1}=Q_1(x)+\frac{3}{x-1}$$
Subtract the second equation from the first:
$$P(x)\left(\frac{1}{x-2}-\frac{1}{x-1} \right)=\left(Q_2(x)-Q_1(x) \right)+\left(\frac{1}{x-2}-\frac{3}{x-1} \right)$$
What do you find upon simplification, and using the definition:
$$Q(x)\equiv Q_2(x)-Q_1(x)$$ ?
thank you mark for the quick response ,also you guessed it right that it was misquoted as =.well done.
$$P(1)=1$$
$$P(2)=3$$
$$P(1)=3$$
$$P(2)=1$$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 48 ·
  • · Replies 29 ·
