MHB Prove Positive Fraction + Inverse is ≥2
The discussion centers on proving that the sum of a positive fraction and its inverse is greater than or equal to two. The proof demonstrates that the expression can be rewritten and simplified to show that (a-b)² is always non-negative, confirming the inequality. Participants question the validity of taking the square root of both sides of the inequality, noting that this could lead to incorrect conclusions if a is less than b. The distinction between squaring and square rooting in inequalities is emphasized, particularly the importance of considering absolute values. Overall, the proof is validated, but caution is advised regarding the manipulation of inequalities.
IHateFactorial
Problem: Prove that any positive fraction plus its inverse is greater than or equal to two.
Proof:
$$\frac{a}{b}+\frac{b}{a}\ge2$$
$$\frac{a^2+b^2}{ab}\ge2$$
$${a^2+b^2}\ge2ab$$
$$a^2+b^2 - 2ab\ge0$$
$$a^2 - 2ab + b^2\ge0$$
$$(a-b)^2\ge0$$
This is true for all a and b:
Case 1:
$$a>b\therefore a-b>0; (a-b)^2>0$$
Case 2:
$$a=b\therefore a-b=0; (a-b)^2=0$$
Case 3:
$$a<b\therefore a-b<0; (a-b)^2>0$$
Tadaaaa!?
Is this right?
If so, one question:
$$(a-b)^2\ge0$$
Can't we just square root both sides and get:
$$a-b\ge0$$
I imagine the rules for squares and square roots are different when working with inequalities... HOW are they different?
Mathematics news on Phys.org
Proof:
$${a^2+b^2}\ge2ab$$
$$(a-b)^2\ge0$$
I would have started from the bottom and worked my way up. As it is, you're starting out by assuming what you want to prove is true.
... one question:
$$(a-b)^2\ge0$$
$$a-b\ge0$$
What if $b>a$? In general, $\sqrt{(x-y)^2}=|x-y|$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
