MHB Prove: Positive Integer n Sum Equation
The discussion focuses on proving the equation for the sum of a series of positive integers: 1 + 5 + 9 + 13 + ... + (4n - 3) = n/2(4n - 2) using mathematical induction. The base case for n=1 is verified successfully, showing that the equation holds true. The induction hypothesis is established, and the next step involves demonstrating that if the equation holds for n, it also holds for n+1. The participants successfully derive the expression for n+1, confirming the induction step. The proof is completed, establishing the validity of the equation for all positive integers n.
markosheehan
prove by induction for all positive integers n: 1+5+9+13+...+(4n-3)= n/2(4n-2)
i tried this by trying to prove n/2(4n-2)+ (4(k+1)-3) = k+1/2(4(k+1)-2) but it did not work out for me.
Mathematics news on Phys.org
Okay, so our induction hypothesis $P_n$ is:
$$\sum_{k=1}^{n}(4k-3)=\frac{n}{2}(4n-2)=n(2n-1)$$
First we should verify that the base case $P_1$ is true:
$$\sum_{k=1}^{1}(4n-3)=(1)(2(1)-1)$$
$$4(1)-3=2-1$$
$$1=1\quad\checkmark$$
Okay, the base case is true. So, for our induction step, let's write:
$$\sum_{k=1}^{n}(4k-3)+4(n+1)-3=n(2n-1)+4(n+1)-3$$
Incorporating the added term into the sum on the left, we have:
$$\sum_{k=1}^{n+1}(4k-3)=n(2n-1)+4(n+1)-3$$
So, what we need to do is demonstrate:
$$n(2n-1)+4(n+1)-3=(n+1)(2(n+1)-1)$$
Can you proceed?
thanks
$$n(2n-1)+4(n+1)-3=2n^2+3n+1=(2n+1)(n+1)=(n+1)(2(n+1)-1)$$
Thus, we may state:
$$\sum_{k=1}^{n+1}(4k-3)=(n+1)(2(n+1)-1)$$
This is $P_{n+1}$, which we have derived from $P_n$, thereby completing the proof by induction. :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
