Prove $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ w/ $A,B$ Trig III
  • MHB
  • Thread starter sbhatnagar
  • Tags
    Trigonometry
In summary: Therefore, the desired identity holds.In summary, the challenge problem involves proving that for given values of $A$ and $B$, the product $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ is equal to $\frac{1}{2^{n+1}\left( \cos \frac{\pi}{2^{n+2}}-\cos \frac{\pi}{2^{n+1}}\right)}$. This can be proven by using trigonometric identities and reducing the product to a simple expression involving $\cos \frac{\pi}{2}$ and $\cos \pi$.
sbhatnagar
87
Challenge Problem
If $A=\dfrac{\pi}{2^{n+1}}$ and $B=\dfrac{\pi}{2^{n+2}}$, prove that
\[\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)=\frac{1}{2^{n+1}\left( \cos \frac{\pi}{2^{n+2}}-\cos \frac{\pi}{2^{n+1}}\right)}\]
Mathematics news on Phys.org
sbhatnagar said:
Challenge Problem
If $A=\dfrac{\pi}{2^{2^{n+1}}}$ and $B=\dfrac{\pi}{2^{2^{n+2}}}$, prove that
Something wrong here: I think there is one exponent too many in $A$ and $B$, it should be $A=\dfrac{\pi}{2^{n+1}}$ and $B=\dfrac{\pi}{2^{n+2}}$.
sbhatnagar said:
Challenge Problem
try for n = 0
[tex] A = \frac{\pi}{4} , \; B = \frac{\pi}{16} [/tex]
Trying to prove
[tex] \prod_{r = 0 }^n (\cos 2^r A + \cos 2^r B ) = \frac{1}{2^{1}} \left( \cos \frac{\pi}{2^{2}} - \cos \frac{\pi}{2^{1}}\right) [/tex]
By induction on r
when r = 0
[tex]\cos A + \cos B = \frac{1}{2(\cos \frac{\pi}{4} - \cos \frac{\pi}{2} ) } [/tex]
the right hand side [tex] \frac{1}{\sqrt{2}} [/tex]
which is not euqal to the left hand side
Opalg is right. It should have been $A=\frac{\pi}{2^{n+1}}$ and $B=\frac{\pi}{2^{n+2}}$. I am extremely sorry for this blunder.
You want to show that $\displaystyle \bigl( \cos \tfrac{\pi}{2^{n+2}}-\cos \tfrac{\pi}{2^{n+1}}\bigr) \prod_{r=0}^n \bigl(\cos \tfrac{2^r\pi}{2^{n+2}} + \cos \tfrac{2^r\pi}{2^{n+1}}\bigr) = \tfrac1{2^{n+1}}.$ The left side of that is $$ \bigl( \cos \tfrac{\pi}{2^{n+2}}-\cos \tfrac{\pi}{2^{n+1}}\bigr) \bigl(\cos \tfrac{\pi}{2^{n+2}} + \cos \tfrac{\pi}{2^{n+1}}\bigr) \bigl(\cos \tfrac{\pi}{2^{n+1}} + \cos \tfrac{\pi}{2^{n}}\bigr) \bigl(\cos \tfrac{\pi}{2^{n}} + \cos \tfrac{\pi}{2^{n-1}}\bigr) \bigl(\cos \tfrac{\pi}{2^{n-1}} + \cos \tfrac{\pi}{2^{n-2}}\bigr) \cdots \bigl(\cos \tfrac{\pi}{2} + \cos \tfrac{\pi}{4}\bigr).\qquad(**) $$
Use the trig identity $\cos^2\theta = \tfrac12(\cos2\theta+1)$ to write the product of the first two factors in (**) as $$ \bigl( \cos \tfrac{\pi}{2^{n+2}}-\cos \tfrac{\pi}{2^{n+1}}\bigr) \bigl(\cos \tfrac{\pi}{2^{n+2}} + \cos \tfrac{\pi}{2^{n+1}}\bigr) = \cos^2\tfrac{\pi}{2^{n+2}}-\cos^2 \tfrac{\pi}{2^{n+1}} = \tfrac12\bigl( \cos \tfrac{\pi}{2^{n+1}}-\cos \tfrac{\pi}{2^{n}}\bigr).$$ Substitute that into (**) and then repeat the process of combining the first two factors. Each time you do that, it will introduce a factor of 1/2 and decrease by one the number of factors in the product. After doing this $n+1$ times you will be left with $\frac1{2^{n+1}}\bigl( \cos \tfrac{\pi}{2}-\cos \pi\bigr) = \frac1{2^{n+1}}.$
FAQ: Prove $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ w/ $A,B$ Trig III
What is the purpose of proving $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ with $A,B$ Trig III?
The purpose of this proof is to show the relationship between the product of cosine functions with increasing angles and the angles themselves, using trigonometric identities from the third level of trigonometry.
How does the Trig III level differ from other levels of trigonometry?
Trig III, also known as advanced trigonometry, involves more complex trigonometric identities and equations, as well as applications in calculus and other advanced math topics. It builds upon the concepts learned in Trig I and Trig II, which cover basic trigonometric functions and identities.
What are some common techniques used to prove $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ with $A,B$ Trig III?
Some common techniques include using the double angle formula, manipulating equations using trigonometric identities, and using geometric representations of trigonometric functions to simplify expressions.
What are some real-world applications of this proof?
This proof has applications in fields such as physics, engineering, and astronomy. It can be used to analyze the behavior of waves, vibrations, and oscillations in various systems, as well as to model and predict the motion of celestial bodies.
Why is it important to understand and be able to prove $\prod_{r=0}^n (\cos 2^r A + \cos 2^r B)$ with $A,B$ Trig III?
Understanding this proof and its underlying concepts is important for furthering one's knowledge and skills in trigonometry, as well as in related fields such as calculus and physics. It also helps to develop critical thinking and problem-solving abilities, which are valuable in any scientific or mathematical discipline.
