Prove relation between generators and automorphisms of Z/nZ*
In summary, the conversation discusses the concept of automorphic generators and their connection to the automorphisms of groups. It is observed that the minimum number of elements in an automorphic generator appears to be equal to the number of factors of a specific group, and this hypothesis is revised and modified throughout the conversation. The conversation also considers the isomorphic relation between a multiplicative integer mod group and its additive group factors, and how this relates to the concept of automorphic generators. A new hypothesis is proposed and further discussion ensues regarding the mapping of automorphic generators and the homomorphic and automorphic images they create.
jackmell
1,807
54
Hi,
I was wondering if anyone here could help me prove or disprove this empirical observation or explain why there seems to be a connection between automorphic generators described below and the automorphisms of these groups:
Consider the p-group expansion:
##\mathbb{Z}_n^*\cong S_2\times S_{p_2}\times\cdots\times S_{p_n}##.
Now define an automorphic generator ##G=\big<a_1,a_2,\cdots,a_n\big>## of ##\mathbb{Z}_n^*## as a generator meeting the following requirements:
## \displaystyle\bigcap^n \big<a_i\big> =\{1\}\quad \text{and} \quad \displaystyle \prod^n \big<a_i\big> =\mathbb{Z}_n^*
and consider the set ##A=\{\big<b_1,b_2,\cdots,b_n\big>\}## of all automorphic generators in which the generator elements match the orders of the elements of ##G##, that is ##o(a_1)=o(b_1)##, ##o(a_2)=o(b_2)## and so forth. Show or provide a contradiction:
##\begin{aligned}(1)\quad &\big|\operatorname{aut}\mathbb{Z}_n^*\big|=\big|A\big|,\\
(2)\quad &\operatorname{aut}\mathbb{Z}_n^*=\big<G,A\big>,\\
(3)\quad &\text{min}|G|=|S_2|
\end{aligned}
where we interpret ##\big<G,A\big>## as meaning any mapping of a generator ##G## to a set of generator mappings ##A##, and the expression ##\text{min}|G|=|S_2|## reflects the empirical observation that the minimum number of elements of an automorphic generator appears to be equal to the number of factors of ##S_2##.
Ok thanks,
Jack
I'm afraid I have to change this hypothesis a bit and can't edit the first post:
Now define an automorphic generator ##G=\big<a_1,a_2,\cdots,a_n\big>## of ##\mathbb{Z}_n^*## with ## a_i\neq a_j## as a generator meeting the following requirements:
## \displaystyle\prod\limits^n \big|\big<a_i\big>\big|=\big|\mathbb{Z}_n^*\big|,\quad\displaystyle\bigcap\limits_{n} \big<a_i\big>=\{1\}\quad \text{and} \quad \displaystyle\prod\limits^n \big<a_i\big>=\mathbb{Z}_n^*
(3)\quad &\text{min}|G|=|S_2| \quad \text{for}~n>2
\end{aligned}
For example, consider ##\mathbb{Z}_{24}^*## with all elements of order 2 except the identity element. Since the group size is 8, 3 generator elements are required to generate the group. However there are some 3-tuples (a,b,c) which meet the first two requirements of automorphic generators but not the third. Of these tuples, 168 meet all three requirements and lead to the creation of the automorphic set.
I have no choice but to risk looking foolish by changing this again:
Consider the isomorphic relation between a multiplicative integer mod group and it's (non-trivial) additive group factors:
##\mathbb{Z}_n^*\cong \mathbb{Z}_{x_1}\times \mathbb{Z}_{x_2}\times\cdots\times \mathbb{Z}_{x_k}##
for ## n>2## where I have explicitly not factored the group into p-groups. For example:
##\begin{aligned} \mathbb{Z}_{129}^*&\cong \mathbb{Z}_{3}^*\times\mathbb{Z}_{43}^* \\
&\cong \mathbb{Z}_2\times \mathbb{Z}_{42} \\
\end{aligned}
Now, since these are isomorphic, they are actually the same group and since the additive group obviously has elements of orders ##2## and ##42##, that is, elements (1,0) and (0,1) respectively, then both the additive group ##H=\mathbb{Z}_2\times\mathbb{Z}_{42}## and the multiplicative group ##\mathbb{Z}_{129}^*## are generated by elements with these orders and so ##\mathbb{Z}_{n}^*## will always have elements in which the product of the orders of the elements is equal to the size of the group and that the number of such additive factors must be the minimum size of the generator needed to generate ##\mathbb{Z}_n^*##.
That is, given ##\mathbb{Z}_n^*\cong \mathbb{Z}_{x_1}\times \mathbb{Z}_{x_2}\times\cdots\times \mathbb{Z}_{x_k}## there exists ##(a_1,a_2,\cdots,a_k)\in \mathbb{Z}_{n}^*## such that ##o(a_1)=x_1, o(a_2)=x_2,\cdots o(a_k)=x_k## and ##\mathbb{Z}_n^*=\big<a_1,a_2\cdots,a_k\big>## and so obviously, ##\displaystyle\mathop\prod\limits^k o(a_i)=\big|\mathbb{Z}_n^*\big|##. I didn't realize this until now as well as if the product of the orders is equal to the size of the group and the intersection of the orbits is ##\{1\}##, then obviously the generator generates the group without duplication (is exactly equal to it) so I wish to modify my hypothesis:Consider the additive group expansion:
##\mathbb{Z}_n^*\cong \mathbb{Z}_{x_1}\times\mathbb{Z}_{x_2} \cdots\times\ \mathbb{Z}_{x_k}## for ##n>2##.
Then ##\mathbb{Z}_n^*## has elements with orders ##x_1, x_2,\cdots,x_k##.
Now define an automorphic generator ##G=\big<a_1,a_2,\cdots,a_k\big>## of ##\mathbb{Z}_n^*## with ##o(a_1)=x_1,o(a_2)=x_2,\cdots o(a_k)=a_k## with ##a_i\neq a_j## and meeting the following requirement:
## \quad\displaystyle\bigcap\limits_{n} \big<a_i\big>=\{1\}##.
Let ##A=\{g_i : g_i\; \text{is an automorphic generator}\}##, then prove or find a counter-example for the following:
(2)\quad &\operatorname{aut}\mathbb{Z}_n^*=\{\big<g_i,g_j\big>, j=1,2,\cdots, |A|\},\\
\end{aligned}
where we interpret ##\big<g_i,g_j\big>## as meaning the (bijective) homomorphism generated by the mappings ##g_i\to g_j\;\forall g_j\in A##. And I don't know how to precisely say, ``start with the mapping ##(a_1,a_2,\cdots,a_k)\to (b_1,b_2,\cdots,b_k)##. Now this completely defines a homomorphic image, and in these cases, an automorphic image ##\sigma:\mathbb{Z}_{n}^*\to \mathbb{Z}_n^*## by imposing the requirement ##\sigma(a_1^{e_1}\cdots a_k^{e_k})=\sigma(a_1)^{e_1}\cdots\sigma(a_k)^{e_k}## but that's what I mean.''
I think that's all correct but not 100% sure. Need to study it more.
I hate leaving the last post as I said something that's not correct so I just have to make another one since I can't edit it:
\end{aligned}
That is, given ##\mathbb{Z}_n^*\cong \mathbb{Z}_{x_1}\times \mathbb{Z}_{x_2}\times\cdots\times \mathbb{Z}_{x_k}## there exists ##(a_1,a_2,\cdots,a_k)\in \mathbb{Z}_{n}^*## such that ##o(a_1)=x_1, o(a_2)=x_2,\cdots o(a_k)=x_k## and ##\mathbb{Z}_n^*=\big<a_1,a_2\cdots,a_k\big>## and so obviously, ##\displaystyle\mathop\prod\limits^k o(a_i)=\big|\mathbb{Z}_n^*\big|##. I didn't realize this until now. Also I incorrectly stated in the last post that if we choose the generator described above and if the intersection of the orbits is unity, then it generates the group. That's not correct. We have to check that the product of the orbits generate the group. So I wish to re-state this hypothesis:
##\displaystyle\bigcap\limits_{n} \big<a_i\big>=\{1\}\quad \text{and}\quad \displaystyle\prod\limits^k \big<a_i\big>=\mathbb{Z}_{n}^*##.
\end{aligned}
Ok, I think that's really close to what I want.
I wish to add a corollary to this hypothesis: empirically it appears if we map, between isomorphic groups, an automorphic generator of one group to the set of automorphic generators of the other group, we generate the set of isomorphisms between them.
Therefore, given two isomorphic groups ##\mathbb{Z}_n^*\cong\mathbb{Z}_m^*## and their associated sets of automorphic generators ##A,B## respectively, then:
##\operatorname{isom} \big\{\mathbb{Z}_n^*,\mathbb{Z}_m^*\big\}=\big<a,B\big>,\quad a\in A,\; \forall\; b\in B##
where the notation ##\operatorname{isom} \big\{\mathbb{Z}_n^*,\mathbb{Z}_m^*\big\}## is the set of group isomorphisms.
So I guess I need to prove this too unless I or someone else finds a counter-example.
Here's a simple example: ##\mathbb{Z}_{15}^*\cong \mathbb{Z}_{16}^*## with:
##A=\{\{11,2\},\{11,7\},\{11,8\},\{11,13\},\{14,2\},\{14,7\},\{14,8\},\{14,13\}\}##
##B=\{\{7,3\},\{7,5\},\{7,11\},\{7,13\},\{15,3\},\{15,5\},\{15,11\},\{15,13\}\}##
Then the mappings ## (11,2)\to B## generates the group isomorphisms.
Related to Prove relation between generators and automorphisms of Z/nZ*
What is the definition of generators and automorphisms of Z/nZ*?
Generators and automorphisms are concepts in abstract algebra that pertain to the group structure of the set of integers modulo n, denoted as Z/nZ*. A generator is an element that, when raised to different powers, generates all elements of the group. An automorphism is a bijective function that preserves the group operation and structure.
How are generators and automorphisms related in Z/nZ*?
In Z/nZ*, each generator corresponds to an automorphism. Specifically, the automorphism is determined by the generator's power. For example, if a is a generator of Z/nZ*, then the automorphism corresponding to a^k is defined as a function that maps each element x of Z/nZ* to a^kx (mod n).
Can every automorphism of Z/nZ* be expressed in terms of a generator?
Yes, every automorphism of Z/nZ* can be expressed as a power of a generator. This is because every element in Z/nZ* can be written as a power of a generator, and automorphisms are defined in terms of the group operation, which is also based on the generator.
How do generators and automorphisms impact the structure of Z/nZ*?
Generators and automorphisms play a crucial role in determining the structure and properties of Z/nZ*. They provide a way to represent and manipulate the elements of the group, and their relationships help us understand the underlying patterns and symmetries in Z/nZ*.
Are there any practical applications of the relation between generators and automorphisms in Z/nZ*?
Yes, the concept of generators and automorphisms of Z/nZ* has practical applications in fields such as cryptography and coding theory. These concepts are used to create secure encryption algorithms and error-correcting codes, respectively.
  • Linear and Abstract Algebra
